1.使用你的方法:git pull bitbucket fireprime:fireprime提示
Already up-to-date. 2.使用你提供的附件,现象一样 3.我的目的是我的串口线,内核打印到一部分就停止了,用firefly官方固件解包的内核就串口能正常输出,一直到进入系统。 目前我的串口打印停止在下面这个位置 [ 1.076138] ohci-rockchip 101e0000.u***: RK OHCI Host Controller [ 1.076193] ohci-rockchip 101e0000.u***: new USB bus registered, assigned bus number 2 [ 1.076279] ohci-rockchip 101e0000.u***: irq 64, io mem 0x101e0000 [ 1.137041] u*** u***2: New USB device found, idVendor=1d6b, idProduct=0001 [ 1.137076] u*** u***2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.137103] u*** u***2: Product: RK OHCI Host Controller [ 1.137127] u*** u***2: Manufacturer: Linux 3.10.0 ohci_hcd [ 1.137151] u*** u***2: SerialNumber: 101e0000.u*** [ 1.138099] hub 2-0:1.0: USB hub found [ 1.138161] hub 2-0:1.0: 1 port detected [ 1.138774] u***core: registered new interface driver cdc_acm [ 1.138801] cdc_acdel driver for USB modems and ISDN adapters [ 1.138920] u***core: registered new interface driver u***lp [ 1.139013] u***core: registered new interface driver cdc_wdm [ 1.139157] u***core: registered new interface driver u***-storage [ 1.139239] u***core: registered new interface driver ums-alauda [ 1.139318] u***core: registered new interface driver ums-cypress [ 1.139421] u***core: registered new interface driver ums-datafab [ 1.139501] u***core: registered new interface driver ums_eneub6250 [ 1.139580] u***core: registered new interface driver ums-freecom [ 1.139661] u***core: registered new interface driver ums-isd200 [ 1.139740] u***core: registered new interface driver ums-jumpshot [ 1.139819] u***core: registered new interface driver ums-karma [ 1.139897] u***core: registered new interface driver ums-onetouch [ 1.139977] u***core: registered new interface driver ums-sddr09 [ 1.140055] u***core: registered new interface driver ums-sddr55 [ 1.140133] u***core: registered new interface driver ums-u***at [ 1.140333] u***core: registered new interface driver u***serial [ 1.140423] u***core: registered new interface driver u***serial_generic [ 1.140492] u***serial: USB Serial support registered for generic [ 1.140575] u***core: registered new interface driver option [ 1.140643] u***serial: USB Serial support registered for GSM modem (1-port) [ 1.140861] u***core: registered new interface driver trancevibrator [ 1.140885] u***20_otg: version 3.10a 21-DEC-2012 [ 1.141561] e3500040 [ 1.141589] Core Release: 2.91a [ 1.141610] Setting default values for core params [ 1.141880] Using Buffer DMA mode [ 1.141904] Periodic Transfer Interrupt Enhancement - disabled [ 1.141924] Multiprocessor Interrupt Enhancement - disabled [ 1.141945] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 1.141964] ^^^^^^^^^^^^^^^^^Device Mode [ 1.141991] Dedicated Tx FIFOs mode [ 1.142026] pcd_init otg_dev = de1c3d40 [ 1.142359] u***20_otg 10180000.u***: DWC OTG Controller [ 1.142419] u***20_otg 10180000.u***: new USB bus registered, assigned bus number 3 [ 1.142483] u***20_otg 10180000.u***: irq 42, io mem 0x00000000 [ 1.142611] u*** u***3: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.142643] u*** u***3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.142669] u*** u***3: Product: DWC OTG Controller [ 1.142693] u*** u***3: Manufacturer: Linux 3.10.0 dwc_otg_hcd [ 1.142718] u*** u***3: SerialNumber: 10180000.u*** [ 1.143656] hub 3-0:1.0: USB hub found [ 1.143716] hub 3-0:1.0: 1 port detected [ 1.144348] u***20_host: version 3.10a 21-DEC-2012 [ 1.145294] u***core: registered new interface driver xpad [ 1.145413] u***core: registered new interface driver u***_acecad [ 1.145513] u***core: registered new interface driver aip |
基于米尔瑞芯微RK3576核心板/开发板的人脸疲劳检测应用方案
1767 浏览 0 评论
2288 浏览 1 评论
1955 浏览 1 评论
3294 浏览 1 评论
4095 浏览 1 评论
GMT+8, 2025-1-13 18:03 , Processed in 0.467419 second(s), Total 40, Slave 34 queries .
