李萍
7年用户 1448经验值
如何对Android 7.1 RK3288 Wifi进行调试呢
如何对Android 7.1 RK3288 Wifi进行调试呢?
回帖(1)
王文
2022-3-4 16:29:03
【平台信息】
CPU:RK3288
Android:7.1
Linux:4.4
WIFI&BT:AP6255
【硬件连接】
1、芯片介绍
【代码梳理】
1、内核配置:
cd kernel;make ARCH=arm menuconfig
Device Drivers —>
[] Network device support —>
] Wireless LAN —>
生成配置文件:
kernel/arch/arm/configs/rockchip_defconfig
CONFIG_WLAN=y
CONFIG_WIFI_LOAD_DRIVER_WHEN_KERNEL_BOOTUP=y
CONFIG_RKWIFI=y
CONFIG_AP6210=y
CONFIG_RKWIFI_26M=y
2、Dts配置
1) arch/arm/boot/dts/rk3288.dtsi
        sdio: rksdmmc@ff0d0000 {
                compatible = "rockchip,rk_mmc", "rockchip,rk32xx-sdmmc";
                reg = <0xff0d0000 0x4000>;
                interrupts = ;
                #address-cells = <1>;
                #size-cells = <0>;
                pinctrl-names = "default","idle";
                pinctrl-0 = <&sdio0_clk &sdio0_cmd &sdio0_bus4>;
                pinctrl-1 = <&sdio0_gpio>;
                clocks = <&clk_sdio0>, <&clk_gates8 4>;
                clock-names = "clk_mmc", "hclk_mmc";
                num-slots = <1>;
                fifo-depth = <0x100>;
                bus-width = <4>;  /* 4线模式 */
                tune_reg***ase = <0x208>;
                cru_reg***ase = <0x1d8>;
                cru_reset_offset = <1>;
2) arch/arm/boot/dts/rk3288-n1904.dts
    wireless-wlan {
         compatible = "wlan-platdata";
        /* wifi_chip_type - wifi chip define
        * bcmwifi ==> like ap6xxx, rk90x;
        * rtkwifi ==> like rtl8188xx, rtl8723xx,rtl8812auv;
        * esp8089 ==> esp8089;
        * other   ==> for other wifi;
        wifi_chip_type = "ap6212"; /* 海华和正基模组兼容,realtek需要按实际修改 */
        sdio_vref = <1800>; //1800mv or 3300mv,支持SDIO3.0的模组IO一定要接1.8V,SDIO2.0 1.8V/3.3V都可以
                            //需要根据实际硬件连接设置对应的电压
        //keep_wifi_power_on;
        //power_ctrl_by_pmu;
        power_pmu_regulator = "act_ldo3";
        power_pmu_enable_level = <1>; //1->HIGH, 0->LOW
        //vref_ctrl_enable;
        //vref_ctrl_gpio = <&gpio0 GPIO_A2 GPIO_ACTIVE_HIGH>;
        vref_pmu_regulator = "act_ldo3";
        vref_pmu_enable_level = <1>; //1->HIGH, 0->LOW
        WIFI,poweren_gpio = <&gpio4 GPIO_D4 GPIO_ACTIVE_HIGH>;  //WL_REG_ON,wifi模组pin12
        WIFI,host_wake_irq = <&gpio4 GPIO_D6 GPIO_ACTIVE_HIGH>; //WL_HOST_WAKE,wifi模组pin13
        //WIFI,reset_gpio = <&gpio0 GPIO_A2 GPIO_ACTIVE_LOW>;
        status = "okay";
&sdio {
                clock-frequency = <50000000>;
                clock-freq-min-max = <200000 50000000>;
                supports-highspeed;
                supports-sdio;
                ignore-pm-notify;
                keep-power-in-suspend;
                //cap-sdio-irq;
                status = "okay";
3) arch/arm/boot/dts/rk3288-pinctrl.dts
        pinctrl: pinctrl@ff770000 {
                gpio4_sdio0 {
                                // SDIO四线接口配置
                                sdio0_clk: sdio0_clk {
                rockchip,pins = ;
                rockchip,pull = ;
                rockchip,drive = ;
                //rockchip,tristate = ;
                    sdio0_cmd: sdio0_cmd {
                        rockchip,pins = ;
                        rockchip,pull = ;
                        rockchip,drive = ;
                    sdio0_bus4: sdio0-bus-width4 {
                        rockchip,pins = ,
                        rockchip,pull = ;
                        rockchip,drive = ;
                                //连接wifi模组pin12(WL_REG_ON)
                                sdio0_pwr: sdio0-pwren{
                                        //rock3288-rk3288.h #define SDIO0_PWREN 0x4d41(bank4、offset:c1、func1)
                        rockchip,pins = ;
                        rockchip,pull = ;
                        rockchip,drive = ;
                                //连接wifi模组pin13(WL_HOST_WAKE)
                                sdio0_intn: sdio0-intn{
                                        //rock3288-rk3288.h #define SDIO0_INTN 0x4d61(bank4、offset:d6、func1)
                        rockchip,pins = ;
                        rockchip,pull = ;
                        rockchip,drive = ;
RK808 PMU芯片的RTC CLK32KOUT2信号接到AP6212芯片SUSCLK_IN脚输入时钟
2、驱动介绍
kernel/.config文件CONFIG_AP6210=y
wifi 驱动路径:kernel/net/rfkill/rfkill-wlan.c
wifi驱动代码:drivers/net/wireless/rockchip_wlan/
【调试过程】
查看芯片
/sys/bus/sdio/devices/mmc1:0001:3 $ dmesg | grep “card at address”
查看Wifi芯片型号
rk3288:/ $ cat /sys/class/rkwifi/chip
[ 267.558874] Current WiFi chip is AP6255.
查看Wifi日志打印
logcat | grep WifiHW
