登录
cherr番茄
12年用户
905经验值
私信
关注
RK3399 Android8.1系统的DDR阻抗匹配出现问题怎么办呢
开启该帖子的消息推送
RK3399
Android系统
DDR阻抗匹配出现问题怎么办呢?
怎样去解决RK3399 Android8.1系统的
DDR存在兼容性问题呢?
武彩霞
2022-3-7 10:34:39
Platform: RK3399
OS: Android 8.1
DDR型号:K4F6E3S4HM-MGCJ
现象:
1.程序下载会卡住,偶尔可以下载成功
2.开机后UBOOT阶段可以正常运行,进入kernel阶段会产生EL3报错,具体log放在下方
3.开机后随机产生kernel panic,位置不固定,log放在下方
EL3报错部分log
Unhandled Exception in EL3.
x30 = 0x0000000000045004
x0 = 0x0f1e2d3c4b5a6978
x1 = 0x00000000ff3b1fd0
x2 = 0x0000000000000018
x3 = 0x0000000000000018
x4 = 0x0000000000000018
x5 = 0x0000000000000000
x6 = 0x0000000000000000
x7 = 0x0000000000000000
x8 = 0x0000000003011908
x9 = 0x0000000000010080
x10 = 0x0000000000020f88
x11 = 0x0000000000000400
x12 = 0x000000000000000a
x13 = 0x000000000000000f
x14 = 0x0000000000000002
x15 = 0x0000000000000004
x16 = 0x0000000008000000
x17 = 0x0000000000000000
x18 = 0x0000000000800000
x19 = 0x0f1e2d3c4b5a6978
x20 = 0x000000000004b0c0
x21 = 0x0f1e2d3c4b5a6978
x22 = 0x00000000000419e9
x23 = 0x0000000000041000
x24 = 0x000000000004b0d0
x25 = 0x0000000000000001
x26 = 0x00000000ff8c2000
x27 = 0x0000000000000110
x28 = 0x0000000000000110
x29 = 0x00000000000468c0
Kernel panic部分log
[ 58.541477] Unable to handle kernel paging request at virtual address fffff7c000210830
[ 58.549571] pgd = ffffffc09687c000
[ 58.553019] [fffff7c000210830] *pgd=0000000000000000, *pud=0000000000000000
[ 58.560101] Internal error: Oops: 96000004 [#1] PREEMPT SMP
[ 58.565678] Modules linked in:
[ 58.568752] CPU: 5 PID: 1571 Comm: dex2oat Not tainted 4.4.167 #408
[ 58.575018] Hardware name: rockchip,android (DT)
[ 58.579630] task: ffffffc096831b00 task.stack: ffffffc096988000
[ 58.585554] PC is at iput+0xb0/0x1f0
[ 58.589128] LR is at iput+0x40/0x1f0
[ 58.592707] pc : [
] lr : [
] pstate: 60400145
[ 58.600103] sp : ffffffc09698bcc0
[ 58.603415] x29: ffffffc09698bcc0 x28: ffffffc096831b00
[ 58.608756] x27: ffffff8008ba4000 x26: 0000000000000000
[ 58.614100] x25: 0000000000000001 x24: 0000000000080040
[ 58.619434] x23: 0000000000080060 x22: ffffff8009345458
[ 58.624773] x21: fffff7c000210800 x20: ffffffc098b70838
[ 58.630116] x19: ffffffc098b707b0 x18: 0000000000000000
[ 58.635450] x17: 0000000000000000 x16: ffffff80080a37d4
[ 58.640789] x15: 0000000000000000 x14: 00000000ba09eda1
[ 58.646128] x13: 00000000ffee8d48 x12: 0000000000000001
[ 58.651462] x11: 00000000ffe01000 x10: 0000000000000000
[ 58.656797] x9 : ffffff8009338880 x8 : ffffff8009338880
[ 58.662134] x7 : 0000000000000000 x6 : 0000000000000000
[ 58.667472] x5 : 0000000000000000 x4 : 0000000000000000
[ 58.672812] x3 : 0000000000000000 x2 : 0000000000000000
[ 58.678167] x1 : 0000000000000000 x0 : 0000000000000000
调试过程:
1.kernel中修改DTS降低EMMC速率至50M,仍然会kernel panic
修改方法:
root@ubuntu:~/rd_rk3399_LPDDR4_8.1_SDK/kernel/arch/arm64/boot/dts/rockchip# vi rk3399-vop-clk-set.dtsi
&sdhci {
assigned-clocks = <&cru SCLK_EMMC>;
assigned-clock-parents = <&cru PLL_GPLL>;
assigned-clock-rates = <200000000>;//将此处200修改为50
2.降低DDR频率为400M,但是无法进入系统,无法查看是否降低成功。
3.增加LPDDR4供电电压,由1.1V修改为1.17V,现象不变
4.关闭CPU及GPU变频,抬高CPU及GPU电压,现象不变
5.测量DDR核心供电的电源纹波,在20mv左右,测量CPU及GPU电源,纹波都在30mv以下,板子上的其他电源纹波也在40mv内,所以确定供电纹波不存在问题
6.因为存在EL3报错,所以怀疑DDR存在兼容性问题,修改DDR启动文件,将
rk3399_ddr_800MHz_v1.19.bin修改为
rk3399_ddr_800MHz_v1.24.bin,系统成功启动,可以进入安卓,不过依然存在一跑软件就发生kernel panic
root@ubuntu:~/rd_rk3399_LPDDR4_8.1_SDK/u-boot/tools/rk_tools/RKBOOT# vi RK3399MINIALL.ini
[CHIP_NAME]
NAME=RK330C
[VERSION]
MAJOR=1
MINOR=24
[CODE471_OPTION]
NUM=1
Path1=tools/rk_tools/bin/rk33/rk3399_ddr_800MHz_v1.24.bin
Sleep=1
[CODE472_OPTION]
NUM=1
Path1=tools/rk_tools/bin/rk33/rk3399_u***plug_v1.24.bin
[LOADER_OPTION]
NUM=2
LOADER1=FlashData
LOADER2=FlashBoot
FlashData=tools/rk_tools/bin/rk33/rk3399_ddr_800MHz_v1.24.bin
FlashBoot=tools/rk_tools/bin/rk33/rk3399_miniloader_v1.24.bin
[OUTPUT]
PATH=rk3399_loader_v1.24.124.bin
7.基本可以定位DDR的问题,修改DDR启动文件后,通过参考瑞芯微DDR开发文档,关闭DDR变频功能,尝试降低DDR频率到400M,依然会产生kernel panic
8.确定DDR硬件设计存在问题,尝试调整DDR的ODT(On-Die Termination),也就是调整阻抗,实现阻抗匹配,但是瑞芯微没有提供RK3399的deskew自动扫描工具,无法计算出具体的值
9.因为我们使用的是LPDDR4,所以修改如下如下内容,尝试了修改dq_odt值,现象有所改善,但是依然不够稳定。但是可以确定是DDR的阻抗匹配出现了问题
root@ubuntu:~/rd_rk3399_LPDDR4_8.1_SDK/kernel/arch/arm64/boot/dts/rockchip# vi rk3399-dram-default-timing.dtsi
lpddr4_odt_dis_freq = <800>;
lpddr4_drv =
;//240
lpddr4_dq_odt =
;//40
lpddr4_ca_odt =
;//DIS
phy_lpddr4_ca_drv =
;//40
phy_lpddr4_ck_cs_drv =
;//40 ok
phy_lpddr4_dq_drv =
;//60
phy_lpddr4_odt =
;//40 ok
10。查看RK3399核心板的PCB,发现底层dq差分线的参考平面不完整,有跨平面的现象,如下图,高亮部分为第五层的GND,红色走线为BOTTOM层DDR走线,部分走线有跨3个平面的现象,所以确认是PCB设计问题。
11.优化PCB使第五层GND的完整,DDR的参考平面能够是一个完整的地平面。
总结
1.DDR的问题确实比较棘手,这次调试过程中压力也比较大,脑子里每天都在想是哪里出现了问题,导致自己的生活状态完全失调,希望以后自己能够调整好状态,能够更好的应对压力
2.由于公司仪器有限,无法直接测量DDR的眼图,给问题排查带来了很大的阻碍,有实力的公司可以直接查看眼图定位问题
3.目前PCB改版已经完成,调试结果还要等待板子焊接完成才能实验,后续会更新结果 。
Platform: RK3399
OS: Android 8.1
现象:
1.程序下载会卡住,偶尔可以下载成功
EL3报错部分log
Kernel panic部分log
[ 58.592707] pc : [
] lr : [
] pstate: 60400145
调试过程:
修改方法:
&sdhci {
[CHIP_NAME]
NAME=RK330C
[VERSION]
MAJOR=1
MINOR=24
[CODE471_OPTION]
NUM=1
Sleep=1
[CODE472_OPTION]
NUM=1
[LOADER_OPTION]
NUM=2
LOADER1=FlashData
LOADER2=FlashBoot
[OUTPUT]
lpddr4_drv =
;//240
lpddr4_dq_odt =
;//40
lpddr4_ca_odt =
;//DIS
phy_lpddr4_ca_drv =
;//40
;//40 ok
phy_lpddr4_dq_drv =
;//60
phy_lpddr4_odt =
;//40 ok
总结
rotate(-90deg);
回复
相关问答
RK3399
Android系统
RK3399
开发板
Android8.1
系统
具有哪些特性
呢
2022-03-07
1084
如何在
RK3399
Android8.1
上实现APK静默安装功能
呢
2022-02-15
1491
RK3399
RK
3328
Android
9.0设置
系统
时间失败该
怎么办
呢
2022-03-09
2054
rk3399
android8.1
可以默认输出1024*768p60分辨率吗?求高人指点,酬谢。
2023-03-05
2220
怎样去设置
RK
3326
Android8.1
系统
的默认语言
呢
2022-02-17
1222
怎样去解决
RK3399
系统
经常卡死的问题
呢
2022-02-18
3343
如何实现
ANDROID
8.1+RK3399
开机自动关闭锁屏的设计
呢
2022-03-07
2385
RK
3288W
Android8.1
的SDK忘记执行代码更新指令
怎么办
呢
2022-03-03
1344
RK3399
Pro
8.1
编译遇到的问题及其解决办法
2022-02-11
2632
android8.1
virtualBox 虚拟机 Ubuntu 18.04是怎样修改分区表的
2022-03-07
1165
登录/注册
20万+
工程师都在用,
免费
PCB检查工具
无需安装、支持浏览器和手机在线查看、实时共享
查看
点击登录
登录更多精彩功能!
英国威廉希尔公司网站
william hill官网 版块
小组
免费开发板试用
ebook
直播
搜索
登录
