张伟
7年用户 1634经验值
RK3288系统CPU的频率调节策略是什么
RK3288系统CPU的频率调节策略是什么?
怎样去修改RK3288系统CPU的频率调节策略呢?
回帖(1)
李龙
2022-3-10 10:54:32
Platform: Rockchip
OS: Android 6.0
Kernel: 3.10.92
CPU的频率调节策略:
1. Performance. 不考虑耗电,只用最高频率。
2. Interactive. 直接上最高频率,然后看CPU负荷慢慢降低。
3. Powersave. 通常以最低频率运行,流畅度会受影响,一般不会用这个吧!
4. Userspace. 可以在用户空间手动调节频率。
5. Ondemand. 定期检查负载,根据负载来调节频率。
开机默认策略在 defconfig中定义:
CONFIG_CPU_FREQ_DEFAULT_GOV_INTERACTIVE=y
当defconfig中同时定义多个时,会按照如下代码顺序覆盖前者
cpufreq.h
#ifdef CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE
#define CPUFREQ_DEFAULT_GOVERNOR    (&cpufreq_gov_performance)
#elif defined(CONFIG_CPU_FREQ_DEFAULT_GOV_POWERSAVE)
extern struct cpufreq_governor cpufreq_gov_powersave;
#define CPUFREQ_DEFAULT_GOVERNOR    (&cpufreq_gov_powersave)
#elif defined(CONFIG_CPU_FREQ_DEFAULT_GOV_USERSPACE)
extern struct cpufreq_governor cpufreq_gov_userspace;
#define CPUFREQ_DEFAULT_GOVERNOR    (&cpufreq_gov_userspace)
#elif defined(CONFIG_CPU_FREQ_DEFAULT_GOV_ONDEMAND)
extern struct cpufreq_governor cpufreq_gov_ondemand;
#define CPUFREQ_DEFAULT_GOVERNOR    (&cpufreq_gov_ondemand)
#elif defined(CONFIG_CPU_FREQ_DEFAULT_GOV_CONSERVATIVE)
extern struct cpufreq_governor cpufreq_gov_conservative;
#define CPUFREQ_DEFAULT_GOVERNOR    (&cpufreq_gov_conservative)
#elif defined(CONFIG_CPU_FREQ_DEFAULT_GOV_INTERACTIVE)
extern struct cpufreq_governor cpufreq_gov_interactive;
#define CPUFREQ_DEFAULT_GOVERNOR    (&cpufreq_gov_interactive)
#endif
调用处:
cpufreq.c
static int cpufreq_add_dev(...)
  policy->governor = CPUFREQ_DEFAULT_GOVERNOR;
除了在defconfig可以设置外,在init_xxx.rc中也可以修改掉:
write /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor interactive
查看修改后的策略:
#cat sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
