WCH沁恒单片机
熊本熊
9年用户 1441经验值
擅长:处理器/DSP
ch32v1 linux x64工具链解压后文件属性不对是什么原因?
这个压缩包明显从windows打包的。有人用过吗,一个一个目录改太烦躁了!
```sh
[calvin RISC-V Embedded GCC/bin] -> pwd
/opt/MRS_Toolchain_Linux_x64_V1.10/Toolchain/RISC-V Embedded GCC/bin
[calvin RISC-V Embedded GCC/bin] -> ls -l
total 32972
-rw-r--r-- 1 calvin calvin      17 Jun 16 01:47 libexpat.so.1
-rw-r--r-- 1 calvin calvin  232760 May 25 01:16 libexpat.so.1.6.7
-rw-r--r-- 1 calvin calvin      14 Jun 16 01:47 libfl.so.2
-rw-r--r-- 1 calvin calvin   17152 May 25 01:16 libfl.so.2.0.0
-rw-r--r-- 1 calvin calvin      16 Jun 16 01:47 libgmp.so.10
-rw-r--r-- 1 calvin calvin  643224 May 28 22:40 libgmp.so.10.3.2
-rw-r--r-- 1 calvin calvin      17 Jun 16 01:47 libiconv.so.2
-rw-r--r-- 1 calvin calvin  992280 May 28 22:40 libiconv.so.2.6.0
-rw-r--r-- 1 calvin calvin      16 Jun 16 01:47 liblzma.so.5
-rw-r--r-- 1 calvin calvin  159880 May 28 22:40 liblzma.so.5.2.3
-rw-r--r-- 1 calvin calvin      16 Jun 16 01:47 libmpfr.so.4
-rw-r--r-- 1 calvin calvin  401640 May 28 22:40 libmpfr.so.4.1.6
-rw-r--r-- 1 calvin calvin 2542824 May 25 01:16 libpython2.7.so.1.0
-rw-r--r-- 1 calvin calvin      13 Jun 16 01:47 libz.so.1
-rw-r--r-- 1 calvin calvin  104904 May 28 22:40 libz.so.1.2.8
-rw-r--r-- 1 calvin calvin  626872 May 25 01:16 riscv-none-embed-addr2line
-rw-r--r-- 1 calvin calvin  573376 May 25 01:16 riscv-none-embed-ar
-rw-r--r-- 1 calvin calvin  918504 May 25 01:15 riscv-none-embed-as
-rw-r--r-- 1 calvin calvin  714984 May 25 01:16 riscv-none-embed-c++
-rw-r--r-- 1 calvin calvin   96560 May 25 01:16 riscv-none-embed-c++filt
-rw-r--r-- 1 calvin calvin  714984 May 25 01:16 riscv-none-embed-cpp
-rw-r--r-- 1 calvin calvin   35584 May 25 01:15 riscv-none-embed-elfedit
-rw-r--r-- 1 calvin calvin  714984 May 25 01:16 riscv-none-embed-g++
-rw-r--r-- 1 calvin calvin  714984 May 25 01:16 riscv-none-embed-gcc
-rw-r--r-- 1 calvin calvin  714984 May 25 01:16 riscv-none-embed-gcc-8.2.0
-rw-r--r-- 1 calvin calvin   31136 May 25 01:16 riscv-none-embed-gcc-ar
-rw-r--r-- 1 calvin calvin   31136 May 25 01:15 riscv-none-embed-gcc-nm
-rw-r--r-- 1 calvin calvin   31136 May 25 01:16 riscv-none-embed-gcc-ranlib
-rw-r--r-- 1 calvin calvin  367976 May 25 01:15 riscv-none-embed-gcov
-rw-r--r-- 1 calvin calvin  265472 May 25 01:15 riscv-none-embed-gcov-dump
-rw-r--r-- 1 calvin calvin  290144 May 25 01:15 riscv-none-embed-gcov-tool
-rw-r--r-- 1 calvin calvin 6302240 May 25 01:15 riscv-none-embed-gdb
-rw-r--r-- 1 calvin calvin    3270 May 25 01:10 riscv-none-embed-gdb-add-index
-rw-r--r-- 1 calvin calvin    3270 May 25 01:15 riscv-none-embed-gdb-add-index-py
-rw-r--r-- 1 calvin calvin 6651928 May 25 01:16 riscv-none-embed-gdb-py
-rw-r--r-- 1 calvin calvin  693528 May 25 01:15 riscv-none-embed-gprof
-rw-r--r-- 1 calvin calvin 1348936 May 25 01:16 riscv-none-embed-ld
-rw-r--r-- 1 calvin calvin 1348936 May 25 01:16 riscv-none-embed-ld.bfd
-rw-r--r-- 1 calvin calvin  639800 May 25 01:15 riscv-none-embed-nm
-rw-r--r-- 1 calvin calvin  765784 May 25 01:15 riscv-none-embed-objcopy
-rw-r--r-- 1 calvin calvin  977016 May 25 01:16 riscv-none-embed-objdump
-rw-r--r-- 1 calvin calvin  573376 May 25 01:15 riscv-none-embed-ranlib
-rw-r--r-- 1 calvin calvin  543696 May 25 01:16 riscv-none-embed-readelf
-rw-r--r-- 1 calvin calvin  552888 May 25 01:15 riscv-none-embed-size
-rw-r--r-- 1 calvin calvin  552984 May 25 01:15 riscv-none-embed-strings
-rw-r--r-- 1 calvin calvin  765816 May 25 01:16 riscv-none-embed-strip
回帖(1)
李巍
2022-5-25 11:09:23
上述问题官网最新版已解决,更新到最新版即可
