扫一扫,分享给好友
用 rga 加速处理
cmake编译rga的时候出现以下问题
我已经按照linux-rga里的README修改了buildroot.cmake里的以下配置 1. 指定TOOLCHAIN_HOME为交叉编译工具的路径 2. 指定CMAKE_C_COMPILER为gcc编译命令的路径 3. 指定CMAKE_CXX_COMPILER为g++编译命令的路径 请问这个问题有什么解决方法吗? decatur@ubuntu:~/rv1126_rv1109_linux_release_20211022/external/linux-rga/build$ ../cmake-linux.sh default to Release build for GCC builds RGA is compiling with cmake Generated version.h set buildroot toolchain -- The C compiler identification is GNU 6.3.1 -- The CXX compiler identification is GNU 6.3.1 -- Check for working C compiler: /home/decatur/rv1126_rv1109_linux_release_20211022/prebuilts/gcc/linux-x86/arm/gcc-linaro-6.3.1-2017.05-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-gcc -- Check for working C compiler: /home/decatur/rv1126_rv1109_linux_release_20211022/prebuilts/gcc/linux-x86/arm/gcc-linaro-6.3.1-2017.05-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-gcc -- works -- Detecting C compiler ABI info -- Detecting C compiler ABI info - done -- Detecting C compile features -- Detecting C compile features - done -- Check for working CXX compiler: /home/decatur/rv1126_rv1109_linux_release_20211022/prebuilts/gcc/linux-x86/arm/gcc-linaro-6.3.1-2017.05-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-g++ -- Check for working CXX compiler: /home/decatur/rv1126_rv1109_linux_release_20211022/prebuilts/gcc/linux-x86/arm/gcc-linaro-6.3.1-2017.05-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-g++ -- works -- Detecting CXX compiler ABI info -- Detecting CXX compiler ABI info - done -- Detecting CXX compile features -- Detecting CXX compile features - done CMake Error at CMakeLists.txt:83 (install): install TARGETS given no LIBRARY DESTINATION for shared library target "rga". -- Configuring incomplete, errors occurred! See also "/home/decatur/rv1126_rv1109_linux_release_20211022/external/linux-rga/build/CMakeFiles/CMakeOutput.log". make: *** 没有指明目标并且找不到 makefile。 停止。 |
不是使用cmake直接编译的,是在buildroot系统里面添加rga配置编译。直接编译会找不到库文件
请问1126如何接入视频进行检测?
基于米尔瑞芯微RK3576核心板/开发板的人脸疲劳检测应用方案
1776 浏览 0 评论
2364 浏览 1 评论
2028 浏览 1 评论
3366 浏览 1 评论
4125 浏览 1 评论
GMT+8, 2025-1-15 04:38 , Processed in 0.443556 second(s), Total 46, Slave 40 queries .
