问题描述及复现步骤:
问题描述:AIO-3588SJD4开发板,800W CAM-8MS1M摄像头,DM-M10R800 V2显示模组,初次上电测试过程中有如下疑问:
1、公版buildroot固件是否集成了Wayland 桌⾯环境以及基础 Qt 应⽤?
烧写官方给的固件之后,系统能正常起来,但屏幕只有背光花纹亮,没有桌面应用,请问buildroot是否集成进去了如qcamera、qplayer等基础的应用?
2、camera测试例程报错
同样烧写官方固件之后,运行 ./rockchip_test/rockchip_test.sh,摄像头打不开,换输入口,3个MIPI输入口现象一致,报错信息如下(MIPI_D/C-PHY1-CSI0 ):
// log start
root@RK3588:/rockchip-test/camera#
root@RK3588:/rockchip-test/camera# ./camera_rkisp_test.sh
Setting pipeline to PAUSED ...
[ 60.018861] xc7160 7-001b: xc7160 res wxh: 1920x1080@30fps
Using mplane plugin for capture
Pipeline is live and does not need PREROLL ...
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error.
Additional debug info:
../libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming stopped, reason not-negotiated (-4)
Execution ended after 0:00:00.002754792
Setting pipeline to NULL ...
[ 61.313663] xc7160 7-001b: xc7160_write_array: write xc7160 array reg 0xfffd failed
Freeing pipeline ...
// log end
