买的firefly核心板,自己做的底板,在调试WIFI 蓝牙模块是WIFI部分正常,蓝牙一直打印[ 20.616207] Current WiFi chip is AP6212A. [ 21.033236] Current WiFi chip is AP6212A. [ 21.037746] Current WiFi chip is AP6212A. [ 21.042265] [BT_RFKILL]: bt shut off power [ 21.583890] [BT_RFKILL]: ENABLE UART_RTS [ 21.692179] [BT_RFKILL]: DISABLE UART_RTS [ 21.692322] [BT_RFKILL]: bt turn on power [ 22.919473] force_usb_mode_store 0->0 [ 23.985809] [BT_RFKILL]: bt shut off power [ 28.135514] Current WiFi chip is AP6212A. [ 28.251134] Current WiFi chip is AP6212A. [ 28.252074] Current WiFi chip is AP6212A. [ 28.252883] [BT_RFKILL]: bt shut off power [ 28.796613] [BT_RFKILL]: ENABLE UART_RTS [ 28.904895] [BT_RFKILL]: DISABLE UART_RTS [ 28.905091] [BT_RFKILL]: bt turn on power [ 31.204131] [BT_RFKILL]: bt shut off power [ 35.399195] Current WiFi chip is AP6212A. [ 35.516746] Current WiFi chip is AP6212A. [ 35.517848] Current WiFi chip is AP6212A. [ 35.518754] [BT_RFKILL]: bt shut off power [ 36.068299] [BT_RFKILL]: ENABLE UART_RTS [ 36.176504] [BT_RFKILL]: DISABLE UART_RTS [ 36.176664] [BT_RFKILL]: bt turn on power 各位大神请问这是什么问题呢 |
这个应该是硬件哪个地方有问题导致的,先排查一下硬件
谢谢 是硬件问题导致的
基于米尔瑞芯微RK3576核心板/开发板的人脸疲劳检测应用方案
1434 浏览 0 评论
1556 浏览 1 评论
1241 浏览 1 评论
2575 浏览 1 评论
3782 浏览 1 评论
GMT+8, 2025-1-3 03:57 , Processed in 0.627090 second(s), Total 71, Slave 55 queries .
