威廉希尔官方网站 设计william hill官网
山中老虎
8年用户 933经验值
擅长:制造/封装
[资料]
W50267ASZ8_sstc_halfbridge_gerber的资料分享
描述
带 IRFP460 MOSFET 的固态特斯拉线圈半桥板。
物料清单:
项目 数量 参考值 LibPart 封装
C1 1u 设备:C
C2 1u 设备:C
D1 1N4002 二极管:1N4002 二极管_THT:D_DO-41_SOD81_P10.16mm_Horizo​​ntal
D2 1N4002 二极管:1N4002 二极管_THT:D_DO-41_SOD81_P10.16mm_Horizo​​ntal
D3 P6K12CA 设备:D_TVS 二极管_THT:D_DO-201AE_P15.24mm_Horizo​​ntal
D4 P6K12CA 设备:D_TVS 二极管_THT:D_DO-201AE_P15.24mm_Horizo​​ntal
D5 MUR1560 MUR1560:MUR1560 MUR1560:TO508P997X444X1905-2
D6 MUR1560 MUR1560:MUR1560 MUR1560:TO508P997X444X1905-2
D7 1.5KE440A 二极管:1.5KExxA 二极管_THT:D_DO-201AE_P15.24mm_Horizo​​ntal
D8 1.5KE440A 二极管:1.5KExxA 二极管_THT:D_DO-201AE_P15.24mm_Horizo​​ntal
D9 MUR440 二极管:1.5KExxA 二极管_THT:D_DO-201AE_P15.24mm_Horizo​​ntal
D10 MUR440 二极管:1.5KExxA 二极管_THT:D_DO-201AE_P15.24mm_Horizo​​ntal
H1 安装孔机械:安装孔安装孔:安装孔_4.3mm_M4
H2 安装孔机械:安装孔安装孔:安装孔_4.3mm_M4
H3 安装孔机械:安装孔安装孔:安装孔_4.3mm_M4
H4安装孔机械:安装孔安装孔:安装孔_4.3mm_M4
H5 MountingHole_Pad 机械:MountingHole_Pad 安装孔:MountingHole_4.3mm_M4_DIN965_Pad
H6 MountingHole_Pad 机械:MountingHole_Pad 安装孔:MountingHole_4.3mm_M4_DIN965_Pad
H7 C2_B 机械:MountingHole_Pad 安装孔:MountingHole_4.3mm_M4_DIN965_Pad
H8 C1_A 机械:MountingHole_Pad 安装孔:MountingHole_4.3mm_M4_DIN965_Pad
H9 C1_B 机械:MountingHole_Pad 安装孔:MountingHole_4.3mm_M4_DIN965_Pad
H10 C2_A 机械:MountingHole_Pad 安装孔:MountingHole_4.3mm_M4_DIN965_Pad
H11 VGND 机械:MountingHole_Pad 安装孔:MountingHole_4.3mm_M4_DIN965_Pad
H12 +350V 机械:MountingHole_Pad 安装孔:MountingHole_4.3mm_M4_DIN965_Pad
J1 GDT 连接器:Conn_01x02_Male TerminalBlock:TerminalBlock_bornier-2_P5.08mm
Q1 IRFP460 IRFP460:IRFP460 IRFP460:TO546P1587X531X2511-3
Q2 IRFP460 IRFP460:IRFP460 IRFP460:TO546P1587X531X2511-3
R1 10 设备:R 电阻器_THT:R_Axial_DIN0414_L11.9mm_D4.5mm_P15.24mm_Horizo​​ntal
R2 10 设备:R 电阻器_THT:R_Axial_DIN0414_L11.9mm_D4.5mm_P15.24mm_Horizo​​ntal
R3 10 设备:R 电阻器_THT:R_Axial_DIN0414_L11.9mm_D4.5mm_P15.24mm_Horizo​​ntal
R4 10 设备:R 电阻器_THT:R_Axial_DIN0414_L11.9mm_D4.5mm_P15.24mm_Horizo​​ntal
R5 220 设备:R 电阻器_THT:R_Axial_DIN0414_L11.9mm_D4.5mm_P15.24mm_Horizo​​ntal
R6 220 设备:R 电阻器_THT:R_Axial_DIN0414_L11.9mm_D4.5mm_P15.24mm_Horizo​​ntal
R7 100k 设备:R 电阻器_THT:R_Axial_DIN0414_L11.9mm_D4.5mm_P15.24mm_Horizo​​ntal
R8 100k 设备:R 电阻器_THT:R_Axial_DIN0414_L11.9mm_D4.5mm_P15.24mm_Horizo​​ntal
R9 100k 设备:R 电阻器_THT:R_Axial_DIN0414_L11.9mm_D4.5mm_P15.24mm_Horizo​​ntal
R10 100k 设备:R 电阻器_THT:R_Axial_DIN0414_L11.9mm_D4.5mm_P15.24mm_Horizo​​ntal
T1 Transformer_1P_2S Device:Transformer_1P_2S custom_parts:Gate Drive Transformer Half Bridge
PCB
