之前成功编译过几次Android,近期只修改了kernel和uboot,然后回头编译Android时,发现有如下错误。 尝试过 BoardConfig.mk 加BUILD_BROKEN_DUP_RULES := true,但又会出其他问题。 [ 46% 128/277] including hardware/rockchip/libhwjpeg/Android.mk 。.. [ 48% 133/277] including hardware/rockchip/omx_il/Android.mk 。.. date: Unknown option ‘R’ (see “date --help”) cp: .git/hooks/pre-commit: No such file or directory tools/hooks .git/hooks [ 99% 276/277] finishing build rules 。.. packages/apps/Camera2/Android.mk: warning: “Camera2 (app:platform) should [100% 277/277] writing build rules 。.. FAILED: build/make/core/Makefile:900: error: overriding commands for 15:45:50 ckati failed with: exit status 1 |
5个回答
具体修改了什么,回退修改后是否可以编译成功
我回退试一下,还有个问题咨询下,我修改了dts,编译kernel后会boot的dtb会更新,但是recovery里面的dtb不会同步变化,需要怎么操作重新打包recovery,以便更新里面的dtb
回退还是不行
如何回退,是通过git reset吗,是否是删除out目录再编译
基于米尔瑞芯微RK3576核心板/开发板的人脸疲劳检测应用方案
2825 浏览 0 评论
2928 浏览 1 评论
2412 浏览 1 评论
3750 浏览 1 评论
4497 浏览 1 评论
GMT+8, 2025-1-28 14:06 , Processed in 0.660380 second(s), Total 78, Slave 62 queries .
