问题描述及复现步骤:请问进入到maskrom模式然后烧录固件:
sudo upgrade_tool uf ITX-3588J_Android12_HDMI_220830.img
Program Data in /home/zhang/.config/upgrade_tool
Loading firmware.。.
Support Type:RK3588 FW Ver:c.0.00 FW Time:2022-08-30 08:29:28
Loader ver:1.0b Loader Time:2022-08-29 18:15:38
Upgrade firmware ok.
固件烧录完成后,串口打印到如下信息,然后卡住不动了,可能是什么问题?
DDR Version V1.07 20220412
LPDDR4X, 2112MHz
channel[0] BW=16 Col=10 Bk=8 CS0 Row=17 CS=1 Die BW=16 Size=2048MB
channel[1] BW=16 Col=10 Bk=8 CS0 Row=17 CS=1 Die BW=16 Size=2048MB
channel[2] BW=16 Col=10 Bk=8 CS0 Row=17 CS=1 Die BW=16 Size=2048MB
channel[3] BW=16 Col=10 Bk=8 CS0 Row=17 CS=1 Die BW=16 Size=2048MB
change to F1: 528MHz
change to F2: 1068MHz
change to F3: 1560MHz
change to F0: 2112MHz
out
U-Boot SPL board init
U-Boot SPL 2017.09 (Aug 29 2022 - 18:14:55)
unknown raw ID phN
unrecognized JEDEC id bytes: 00, 00, 00
Trying to boot from MMC2
Card did not respond to voltage select!
mmc_init: -95, time 12
spl: mmc init failed with error: -95
Trying to boot from MMC1
Trying fit image at 0x4000 sector
## Verified-boot: 0
## Checking atf-1 0x00040000 。.. sha256(581130cddd.。.) + OK
## Checking uboot 0x00200000 。.. sha256(15714d1d95.。.) + OK
## Checking fdt 0x003284b8 。.. sha256(c07f4a4d71.。.) + OK
## Checking atf-2 0x000f0000 。.. sha256(6a00298af8.。.) + OK
## Checking atf-3 0xff100000 。.. sha256(71c3a5841b.。.) + OK
## Checking atf-4 0xff001000 。.. sha256(2301cf73be.。.) + OK
## Checking optee 0x08400000 。.. sha256(603cfbd25d.。.) + OK
Jumping to U-Boot(0x00200000) via ARM Trusted Firmware(0x00040000)
Total: 129.433 ms
