我之前试用Qt在其它的板子上运行过一个秒表程序,代码编写过程 见://www.obk20.com/d/1891115.html
先来看下在EASY EAI Nano板子中的运行效果:
程序基本上不需要改,只需要调整一下布局已经各个控件的字体大小即可。
表盘界面:
void Widget::paintEvent(QPaintEvent *event)
int side = qMin(width(), height());
QPainter painter(this);
painter.setRenderHint(QPainter::Antialiasing);
painter.translate(width()/2, height()*3/10); //画图的基准位置
painter.scale(side/300.0, side/300.0); //随窗口尺寸自动缩放
//表盘(3个同心圆)
for (int i=0; i<PANEL_RADIUS_NUM; i++)
QBrush brush(stPanelParaArr[i].color);
QPen pen(stPanelParaArr[i].color);
painter.setBrush(brush);
painter.setPen(pen);
painter.drawEllipse(-stPanelParaArr[i].radius, -stPanelParaArr[i].radius, 2*stPanelParaArr[i].radius, 2*stPanelParaArr[i].radius);
//秒的刻度
painter.setPen(secondColor);
for (int i = 0; i < 60; i++)
if ((i % 5) == 0)
painter.drawLine(PANEL_RADIUS3-8, 0, PANEL_RADIUS3, 0);
QFont font("TimesNewRoman", SEC_NUM_SIZE);
painter.setFont(font);
painter.drawText(-SEC_NUM_SIZE, -(CLOCK_RADIUS-15), 4*SEC_NUM_SIZE, 4*SEC_NUM_SIZE, Qt::AlignHCenter, QString::number(i==0? 60 : i));
else
painter.drawLine(PANEL_RADIUS3-5, 0, PANEL_RADIUS3, 0);
//秒再细分5个格
for (int j = 0; j < 5; j++)
painter.rotate(6.0/5);
if (j != 4)
painter.drawLine(PANEL_RADIUS3-2, 0, PANEL_RADIUS3, 0);
//分钟的刻度
painter.setPen(minuteColor);
for (int k = 0; k < 30; k++)
if ((k % 5) == 0)
painter.rotate(-90.0);
painter.drawLine(PANEL_RADIUS4-8, 0, PANEL_RADIUS4, 0);
painter.rotate(90.0);
QFont font("TimesNewRoman", MIN_NUM_SIZE);
painter.drawText(-MIN_NUM_SIZE, -(PANEL_RADIUS4-10), 4*MIN_NUM_SIZE, 4*MIN_NUM_SIZE, Qt::AlignHCenter, QString::number(k==0? 30 : k));
else
painter.drawLine(PANEL_RADIUS4-4, 0, PANEL_RADIUS4, 0);
painter.rotate(12.0);
//分钟的表针
painter.setPen(Qt::NoPen);
painter.setBrush(minuteColor);
painter.save();
painter.rotate(12.0 * (time.minute() + time.second() / 60.0));
painter.drawConvexPolygon(minuteHand, 3);
painter.restore();
//秒钟的表针
painter.setBrush(secondColor);
painter.save();
//painter.rotate(6.0 * time.second());
painter.rotate(6.0 * (time.second()+time.msec()/1000.0));
painter.drawConvexPolygon(secondHand, 3);
painter.restore();
painter.end();
按键回调处理:
void Widget::on_Btn_Start_toggled(bool checked)
if (checked)
timer.start(ADD_TIME_MSEC);
lastTime = QTime::currentTime();//记录时间戳
ui->Btn_Start->setText("暂停");
ui->Btn_Reset->setEnabled(false);
ui->Btn_Hit->setEnabled(true);
else
timer.stop();
ui->Btn_Start->setText("继续");
ui->Btn_Reset->setEnabled(true);
ui->Btn_Hit->setEnabled(false);
void Widget::on_Btn_Reset_clicked()
m_iHitCnt = 0;
timer.stop();
time.setHMS(0,0,0,0);
ui->Txt_ShowTime->setText("00:00:00");
ui->Txt_ShowItem->clear();
ui->Btn_Start->setText("开始");
ui->Btn_Start->setChecked(false);
void Widget::on_Btn_Hit_clicked()
QString temp;
m_iHitCnt++;
temp.sprintf("--计次 %d--", m_iHitCnt);
ui->Txt_ShowItem->setFontPointSize(7);
ui->Txt_ShowItem->append(temp);
ui->Txt_ShowItem->setFontPointSize(9);
ui->Txt_ShowItem->append(time.toString("[mm:ss.zzz]"));
首先的使用qmake生成Makefile,进入程序源码目录,执行qmake指令:
/home/xxpcb/myTest/imx6ull/otherlib/qt/qt-everywhere-src-5.12.9/arm-qt/bin/qmake
成功执行之后,就可以看到自动生成的Makefile文件,然后执行make指令进行编译
然后将编译的文件复制到EASY EAI Nano板子中运行即可,演示效果见文末视频
本篇测试了EASY EAI Nano板子中Qt程序,因为EASY EAI Nano板子已经配置了Qt的运行环境,如果之前有已经写好的Qt程序,对见面布局稍加修改,就可以在EASY EAI Nano板子中运行。
