王平
7年用户 1347经验值
RK3288 android7.1.2多4g模块gps功能调试
rk3288 android7.1.2 多4g模块gps功能调试
1、修改gps库名,每个4g模块单独对应一个gps库
gps.default.so->gps.me3630.so
2、在rild服务中添加sys.gps.module系统属性,标志当前获取的4g模块
hardware/ril/rild/rild.c
[url=home.php?mod=space&uid=1999721]@@[/url] -50,6 +50,7 @@
#define REFERENCE_RIL_SIMCOM_SIM7600CE_PATH "/system/lib/libreference-ril-sim7600ce.so"
#define REFERENCE_RIL_HUAWEI_ME909S_PATH "/system/lib/libreference-ril-me909s.so"
#define REFERENCE_RIL_NEOWAY_N720_PATH "/system/lib/libreference-ril-n720.so"
+#define LIB_GPS_PROPERTY "sys.gps.module"
static void usage(const char *argv0) {
fprintf(stderr, "Usage: %s -l [-- ]\n", argv0);
exit(EXIT_FAILURE);
@@ -218,6 +219,9 @@ int main(int argc, char **argv) {
case ZTE_MODEM:
case ZTE_ME3630:
rilLibPath = REFERENCE_RIL_ZTE_ME3630_PATH;
 /*by set sys.gps.module property to let gps jni choose the right gps lib*/
 property_set(LIB_GPS_PROPERTY, "me3630");
 ALOGD("setprop sys.gps.module for me3630 gps");
   break;
   case SIMCOM_SIM7600:
@@ -230,6 +234,9 @@ int main(int argc, char **argv) {
case NEOWAY_N720:
	rilLibPath = REFERENCE_RIL_NEOWAY_N720_PATH;
 property_set(LIB_GPS_PROPERTY, "n720");
 ALOGD("setprop sys.gps.module for n720 gps");
            break;
3、根据4g模块标志,指定调用的gps库
hardware/libhardware/hardware.c
@@ -189,6 +190,32 @@ int hw_get_module_by_class(const char *class_id, const char *inst,
if(strncmp(class_id, "gps", 3) == 0){
ALOGD("gps-jni start found gps lib now!");
char gps_prop_name[PATH_MAX] = {0};
int chance = 10;/*10 tiems try*/
do{
chance--;
ALOGE("gps-jni property sys.gps.module not exit !");
sleep(1);
}while((property_get("sys.gps.module", gps_prop_name, NULL) <= 0) && (chance >= 0));
if(strncmp(gps_prop_name, "n720", 4) == 0){
if (hw_module_exists(path, sizeof(path), name, "n720") == 0) {
ALOGD("gps-jni found neoway n720 gps lib!");
goto found;
}else if(strncmp(gps_prop_name, "me3630", 6 ) == 0){
if (hw_module_exists(path, sizeof(path), name, "me3630") == 0) {
ALOGD("gps-jni found me3630 gps lib!");
goto found;
}else {
ALOGE("gps-jni no property gps lib found, will use gps.defualt.so");
}+ /add by hjh, use to find right gps lib for different 4g&gps modules end/
原作者:小忽悠0011
