问题描述及复现步骤:
通过v4l2-ctl对摄像头进行取流测试,但输出文件大小为0,没有保存任何数据。
使用SDK版本为:rk3588_repo_sdk_v1.0.2a.7z, Bundle:rk3588-v1.0.2a-to-v1.0.2b.7z; rk3588-v1.0.2b-to-v1.0.2c.7z
编译为BuildRoot系统和Debian系统测试结果相同。
测试命令如下:
v4l2-ctl -d /dev/video0 --set-fmt-video=width=640,height=480,pixelformat=NV12 --stream-mmap=3 --stream-to=/tmp/out2.yuv --stream-count=20 --stream-poll --verbose
输出结果:
VIDIOC_QUERYCAP: ok
VIDIOC_G_FMT: ok
VIDIOC_S_FMT: ok
Format Video Capture Multiplanar:
Width/Height : 640/480
Pixel Format : 'NV12' (Y/CbCr 4:2:0)
Field : None
Number of planes : 1
Flags :
Colorspace : Default
Transfer Function : Default
YCbCr/HSV Encoding: Default
Quantization : Default
Plane 0 :
Bytes per Line : 640
Size Image : 460800
VIDIOC_REQBUFS returned 0 (Success)
VIDIOC_QUERYBUF returned 0 (Success)
VIDIOC_QBUF returned 0 (Success)
VIDIOC_STREAMON returned 0 (Success)
cap dqbuf: 0 seq: 0 bytesused: 460800 ts: 3662.352325 delta: 3662352.325 ms (ts-monotonic, ts-src-eof)
cap dqbuf: 1 seq: 1 bytesused: 460800 ts: 3662.385671 (ts-monotonic, ts-src-eof)
cap dqbuf: 2 seq: 2 bytesused: 460800 ts: 3662.418945 (ts-monotonic, ts-src-eof)
cap dqbuf: 0 seq: 3 bytesused: 460800 ts: 3662.452362 (ts-monotonic, ts-src-eof)
cap dqbuf: 1 seq: 4 bytesused: 460800 ts: 3662.485613 fps: 30.01 (ts-monotonic, ts-src-eof)
cap dqbuf: 2 seq: 5 bytesused: 460800 ts: 3662.518964 fps: 30.00 (ts-monotonic, ts-src-eof)
cap dqbuf: 0 seq: 6 bytesused: 460800 ts: 3662.552390 fps: 29.99 (ts-monotonic, ts-src-eof)
cap dqbuf: 1 seq: 7 bytesused: 460800 ts: 3662.585610 fps: 30.01 (ts-monotonic, ts-src-eof)
cap dqbuf: 2 seq: 8 bytesused: 460800 ts: 3662.618955 fps: 30.00 (ts-monotonic, ts-src-eof)
cap dqbuf: 0 seq: 9 bytesused: 460800 ts: 3662.652361 fps: 30.00 (ts-monotonic, ts-src-eof)
cap dqbuf: 1 seq: 10 bytesused: 460800 ts: 3662.685610 fps: 30.00 (ts-monotonic, ts-src-eof)
cap dqbuf: 2 seq: 11 bytesused: 460800 ts: 3662.719061 fps: 29.99 (ts-monotonic, ts-src-eof)
cap dqbuf: 0 seq: 12 bytesused: 460800 ts: 3662.752365 fps: 30.00 (ts-monotonic, ts-src-eof)
cap dqbuf: 1 seq: 13 bytesused: 460800 ts: 3662.785607 fps: 30.00 (ts-monotonic, ts-src-eof)
cap dqbuf: 2 seq: 14 bytesused: 460800 ts: 3662.818992 fps: 30.00 (ts-monotonic, ts-src-eof)
cap dqbuf: 0 seq: 15 bytesused: 460800 ts: 3662.852359 fps: 30.00 (ts-monotonic, ts-src-eof)
cap dqbuf: 1 seq: 16 bytesused: 460800 ts: 3662.885608 fps: 30.00 (ts-monotonic, ts-src-eof)
cap dqbuf: 2 seq: 17 bytesused: 460800 ts: 3662.918945 fps: 30.00 (ts-monotonic, ts-src-eof)
cap dqbuf: 0 seq: 18 bytesused: 460800 ts: 3662.952395 fps: 30.00 (ts-monotonic, ts-src-eof)
cap dqbuf: 1 seq: 19 bytesused: 460800 ts: 3662.985658 fps: 30.00 (ts-monotonic, ts-src-eof)
