在can设备树的修改成功后,利用QT5的QCanBusDevice模块创建一个can的调试模块(注意这个例程是由野火linux_can摘抄而来,自己做了一点修改)
直接上代码:socketcan.pro:
QT += core gui serialbus
greaterThan(QT_MAJOR_VERSION, 4): QT += widgets
CONFIG += c++11
# The following define makes your compiler emit warnings if you use
# any Qt feature that has been marked deprecated (the exact warnings
# depend on your compiler). Please consult the documentation of the
# deprecated API in order to know how to port your code away from it.
DEFINES += QT_DEPRECATED_WARNINGS
# You can also make your code fail to compile if it uses deprecated APIs.
# In order to do so, uncomment the following line.
# You can also select to disable deprecated APIs only up to a certain version of Qt.
#DEFINES += QT_DISABLE_DEPRECATED_BEFORE=0x060000 # disables all the APIs deprecated before Qt 6.0.0
SOURCES += \
main.cpp \
mainwindow.cpp
HEADERS += \
mainwindow.h
# Default rules for deployment.
qnx: target.path = /tmp/$${TARGET}/bin
else: unix:!android: target.path = /opt/$${TARGET}/bin
!isEmpty(target.path): INSTALLS += target
mainwindow.h:
Copyright © Deng Zhimao Co., Ltd. 1990-2021. All rights reserved.
* @projectName 04_socketcan
* [url=home.php?mod=space&uid=2666770]@Brief[/url] mainwindow.h
* [url=home.php?mod=space&uid=40524]@author[/url] Deng Zhimao
* @email 1252699831@qq.com
* [url=home.php?mod=space&uid=191254]@net[/url] www.openedv.com
* @date 2021-03-15
#ifndef MAINWINDOW_H
#define MAINWINDOW_H
#include <QMainWindow>
#include <QCanBusDevice>
#include <QCanBus>
#include <QPushButton>
#include <QTextBrowser>
#include <QLineEdit>
#include <QVBoxLayout>
#include <QLabel>
#include <QComboBox>
#include <QGridLayout>
#include <QMessageBox>
#include <QDebug>
class MainWindow : public QMainWindow
Q_OBJECT
public:
MainWindow(QWidget *parent = nullptr);
~MainWindow();
private:
/* CAN设备 */
QCanBusDevice *canDevice;
/* 用作接收数据 */
QTextBrowser *textBrowser;
/* 用作发送数据 */
QLineEdit *lineEdit;
/* 按钮 */
QPushButton *pushButton[2];
/* 下拉选择盒子 */
QComboBox *comboBox[3];
/* 标签 */
QLabel *label[4];
/* 垂直布局 */
QVBoxLayout *vboxLayout;
/* 网络布局 */
QGridLayout *gridLayout;
/* 主布局 */
QWidget *mainWidget;
/* 设置功能区域 */
QWidget *funcWidget;
/* 布局初始化 */
void layoutInit();
/* 插件类型项初始化 */
void pluginItemInit();
/* 比特率项初始化 */
void bitrateItemInit();
private slots:
/* 发送消息 */
void sendFrame();
/* 接收消息 */
void receivedFrames();
/* 插件发生改变 */
void pluginChanged(int);
/* 处理can错误 */
void canDeviceErrors(QCanBusDevice::CanBusError) const;
/* 连接或者断开can */
void connectDevice();
#endif // MAINWINDOW_H
main.cpp:
#include "mainwindow.h"
#include <QApplication>
int main(int argc, char *argv[])
QApplication a(argc, argv);
MainWindow w;
w.show();
return a.exec();
mainwindow.cpp
* @brief mainwindow.cpp
* @author Deng Zhimao
* @net www.openedv.com
* @date 2021-03-15
#include <QGuiApplication>
#include <QScreen>
MainWindow::MainWindow(QWidget *parent)
: QMainWindow(parent)
/* 使用系统指令比特率初始化CAN,默认为500000bits/s */
system("ifconfig can0 down");
system("ip link set up can0 type can bitrate 500000 restart-ms 100");
/* 布局初始化 */
layoutInit();
/* 可用插件初始化 */
pluginItemInit();
/* 可用接口项初始化 */
pluginChanged(comboBox[0]->currentIndex());
/* 比特率项初始化 */
bitrateItemInit();
MainWindow::~MainWindow()
static QString frameFlags(const QCanBusFrame &frame)
/* 格式化接收到的消息 */
QString result = QLatin1String(" --- ");
if (frame.hasBitrateSwitch())
result[1] = QLatin1Char('B');
if (frame.hasErrorStateIndicator())
result[2] = QLatin1Char('E');
if (frame.hasLocalEcho())
result[3] = QLatin1Char('L');
return result;
/* 发送消息 */
void MainWindow::sendFrame()
if (!canDevice)
return;
/* 读取QLineEdit的文件 */
QString str = lineEdit->text();
QByteArray data = 0;
QString strTemp = nullptr;
/* 以空格分隔lineEdit的内容,并存储到字符串链表中 */
QStringList strlist = str.split(' ');
for (int i = 1; i < strlist.count(); i++) {
strTemp = strTemp + strlist[i];
/* 将字符串的内容转为QByteArray类型 */
data = QByteArray::fromHex(strTemp.toLatin1());
bool ok;
/* 以16进制读取要发送的帧内容里第一个数据,并作为帧ID */
int framId = strlist[0].toInt(&ok, 16);
QCanBusFrame frame = QCanBusFrame(framId, data);
/* 写入帧 */
canDevice->writeFrame(frame);
/* 接收消息 */
void MainWindow::receivedFrames()
if (!canDevice)
return;
/* 读取帧 */
while (canDevice->framesAvailable()) {
const QCanBusFrame frame = canDevice->readFrame();
QString view;
if (frame.frameType() == QCanBusFrame::ErrorFrame)
view = canDevice->interpretErrorFrame(frame);
else
view = frame.toString();
const QString time = QString::fromLatin1("%1.%2 ")
.arg(frame.timeStamp()
.seconds(), 10, 10, QLatin1Char(' '))
.microSeconds() / 100, 4, 10, QLatin1Char('0'));
const QString flags = frameFlags(frame);
/* 接收消息框追加接收到的消息 */
textBrowser->insertPlainText(time + flags + view + "\n");
textBrowser->moveCursor(QTextCursor::End);
void MainWindow::layoutInit()
/* 获取屏幕的分辨率,Qt官方建议使用这
* 种方法获取屏幕分辨率,防上多屏设备导致对应不上
* 注意,这是获取整个桌面系统的分辨率
QList <QScreen *> list_screen = QGuiApplication::screens();
/* 如果是ARM平台,直接设置大小为屏幕的大小 */
#if __arm__
/* 重设大小 */
this->resize(list_screen.at(0)->geometry().width(),
list_screen.at(0)->geometry().height());
#else
/* 否则则设置主窗体大小为800x480 */
this->resize(800, 480);
#endif
/* 对象初始化 */
textBrowser = new QTextBrowser();
lineEdit = new QLineEdit();
vboxLayout = new QVBoxLayout();
funcWidget = new QWidget();
mainWidget = new QWidget();
gridLayout = new QGridLayout();
/* QList链表,字符串类型 */
QList <QString> list1;
list1<<"插件类型:"<<"可用接口:"<<"比特率bits/sec:";
for (int i = 0; i < 3; i++) {
label[i] = new QLabel(list1[i]);
/* 设置最小宽度与高度 */
label[i]->setMinimumSize(120, 30);
label[i]->setMaximumHeight(50);
/* 自动调整label的大小 */
label[i]->setSizePolicy(QSizePolicy::Expanding,
QSizePolicy::Expanding);
/* 将label[i]添加至网格的坐标(0, i) */
gridLayout->addWidget(label[i], 0, i);
label[3] = new QLabel();
label[3]->setMaximumHeight(30);
comboBox[i] = new QComboBox();
comboBox[i]->setMinimumSize(120, 30);
comboBox[i]->setMaximumHeight(50);
/* 自动调整label的大小 */
comboBox[i]->setSizePolicy(QSizePolicy::Expanding,
/* 将comboBox[i]添加至网格的坐标(1, i) */
gridLayout->addWidget(comboBox[i], 1, i);
/* QList链表,字符串类型 */
QList <QString> list2;
list2<<"发送"<<"连接CAN";
for (int i = 0; i < 2; i++) {
pushButton[i] = new QPushButton(list2[i]);
pushButton[i]->setMinimumSize(120, 30);
pushButton[i]->setMaximumHeight(50);
/* 自动调整label的大小 */
pushButton[i]->setSizePolicy(QSizePolicy::Expanding,
/* 将pushButton[0]添加至网格的坐标(i, 3) */
gridLayout->addWidget(pushButton[i], i, 3);
pushButton[0]->setEnabled(false);
/* 布局 */
vboxLayout->addWidget(textBrowser);
vboxLayout->addWidget(lineEdit);
funcWidget->setLayout(gridLayout);
vboxLayout->addWidget(funcWidget);
vboxLayout->addWidget(label[3]);
mainWidget->setLayout(vboxLayout);
this->setCentralWidget(mainWidget);
/* 设置文本 */
textBrowser->setPlaceholderText("系统时间 帧ID 长度 数据");
lineEdit->setText("123 aa 77 66 55 44 33 22 11");
label[3]->setText(tr("未连接!"));
connect(pushButton[1], SIGNAL(clicked()),
this, SLOT(connectDevice()));
connect(pushButton[0], SIGNAL(clicked()),
this, SLOT(sendFrame()));
/* 从系统中读取可用的插件,并显示到comboBox[0] */
void MainWindow::pluginItemInit()
comboBox[0]->addItems(QCanBus::instance()->plugins());
for (int i = 0; i < QCanBus::instance()->plugins().count(); i++) {
if (QCanBus::instance()->plugins().at(i) == "socketcan")
comboBox[0]->setCurrentIndex(i);
connect(comboBox[0], SIGNAL(currentIndexChanged(int)),
this, SLOT(pluginChanged(int)));
/* 插件类型改变 */
void MainWindow::pluginChanged(int)
QList<QCanBusDeviceInfo> interfaces;
comboBox[1]->clear();
/* 当我们改变插件时,我们同时需要将可用接口,从插件类型中读取出来 */
interfaces = QCanBus::instance()
->availableDevices(comboBox[0]->currentText());
for (const QCanBusDeviceInfo &info : qAsConst(interfaces)) {
comboBox[1]->addItem(info.name());
/* 初始化一些常用的比特率,can的比特率不是随便设置的,有相应的计算公式 */
void MainWindow::bitrateItemInit()
const QList<int> rates = {
10000, 20000, 50000, 100000, 125000,
250000, 500000, 800000, 1000000
for (int rate : rates)
comboBox[2]->addItem(QString::number(rate), rate);
/* 默认初始化以1000000比特率 */
comboBox[2]->setCurrentIndex(6);
/* 连接或断开CAN */
void MainWindow::connectDevice()
if (pushButton[1]->text() == "连接CAN") {
/* Qt中的QCanBusDevice::BitRateKey不能设置比特率 */
QString cmd1 = tr("ifconfig %1 down")
.arg(comboBox[1]->currentText());
QString cmd2 =
tr("ip link set up %1 type can bitrate %2 restart-ms 100")
.arg(comboBox[2]->currentText());
/* 使用系统指令以设置的比特率初始化CAN */
system(cmd1.toStdString().c_str());
system(cmd2.toStdString().c_str());
QString errorString;
/* 以设置的插件名与接口实例化canDevice */
canDevice = QCanBus::instance()->
createDevice(comboBox[0]->currentText(),
comboBox[1]->currentText(),
&errorString);
if (!canDevice) {
label[3]->setText(
tr("Error creating device '%1', reason: '%2'")
.arg(comboBox[0]->currentText())
.arg(errorString));
return;
/* 连接CAN */
if (!canDevice->connectDevice()) {
label[3]->setText(tr("Connection error: %1")
.arg(canDevice->errorString()));
delete canDevice;
canDevice = nullptr;
return;
connect(canDevice, SIGNAL(framesReceived()),
this, SLOT(receivedFrames()));
connect(canDevice,
SIGNAL(errorOccurred(QCanBusDevice::CanBusError)),
this,
SLOT(canDeviceErrors(QCanBusDevice::CanBusError)));
/* 将连接信息插入到label */
label[3]->setText(
tr("插件类型为: %1, 已连接到 %2, 比特率为 %3 kBit/s")
.arg(comboBox[2]->currentText().toInt() / 1000));
pushButton[1]->setText("断开CAN");
/* 使能/失能 */
pushButton[0]->setEnabled(true);
comboBox[0]->setEnabled(false);
comboBox[1]->setEnabled(false);
comboBox[2]->setEnabled(false);
} else {
if (!canDevice)
return;
/* 断开连接 */
canDevice->disconnectDevice();
delete canDevice;
pushButton[1]->setText("连接CAN");
comboBox[0]->setEnabled(true);
comboBox[1]->setEnabled(true);
comboBox[2]->setEnabled(true);
void MainWindow::canDeviceErrors(QCanBusDevice::CanBusError error) const
/* 错误处理 */
switch (error) {
case QCanBusDevice::ReadError:
case QCanBusDevice::WriteError:
case QCanBusDevice::ConnectionError:
case QCanBusDevice::ConfigurationError:
case QCanBusDevice::UnknownError:
label[3]->setText(canDevice->errorString());
break;
default:
break;
编译后生成socketcan上传给开发板,运行程序:
[root@ok3568:/test]# ./socket_can
QStandardPaths: wrong permissions on runtime directory /var/run, 7755 instead of 7700
[ 956.007316] IPv6: ADDRCONF(NETDEV_CHANGE): can0: link becomes ready
qt.qpa.wayland: No shell integration named "xdg-shell" found
到此,我们在OK3568上用python跟QT、C、shell都实现了对CAN总线的操作。可以说这款芯片,对can的支持非常好,特别适合在汽车领域,或者是工程机领域。
