根据
STM32H745xI/G 数据表,64MHz HSI 在室温下的精度为 +/- 0.3 MHz,即 +/- 0.5%。
在测试期间,我注意到大约 10-20% 的 UART 字符被丢弃。然后我查看示波器上的信号,发现频率已关闭。
将系统时钟重定向到 MCO2 (PC9) 并在示波器上测量后,我发现了问题:
STM32H745芯片上的HSI RC (64 MHz) off 4%!!“工厂校准”就这么多了。
我在这里错过了什么吗?
时钟初始化(480MHz):
- /** Initializes the CPU, AHB and APB busses clocks
- RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
- RCC_OscInitStruct.HSIState = RCC_HSI_DIV1;
- RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT;
- RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
- RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI;
- RCC_OscInitStruct.PLL.PLLM = 32;
- RCC_OscInitStruct.PLL.PLLN = 480;
- RCC_OscInitStruct.PLL.PLLP = 2;
- RCC_OscInitStruct.PLL.PLLQ = 2;
- RCC_OscInitStruct.PLL.PLLR = 2;
- RCC_OscInitStruct.PLL.PLLRGE = RCC_PLL1VCIRANGE_1;
- RCC_OscInitStruct.PLL.PLLVCOSEL = RCC_PLL1VCOWIDE;
- RCC_OscInitStruct.PLL.PLLFRACN = 0;
- if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK) {
- Error_Handler();
- RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_SYSCLK
- | RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2 | RCC_CLOCKTYPE_D3PCLK1
- | RCC_CLOCKTYPE_D1PCLK1;
- RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
- RCC_ClkInitStruct.SYSCLKDivider = RCC_SYSCLK_DIV1;
- RCC_ClkInitStruct.AHBCLKDivider = RCC_HCLK_DIV2;
- RCC_ClkInitStruct.APB3CLKDivider = RCC_APB3_DIV2;
- RCC_ClkInitStruct.APB1CLKDivider = RCC_APB1_DIV2;
- RCC_ClkInitStruct.APB2CLKDivider = RCC_APB2_DIV2;
- RCC_ClkInitStruct.APB4CLKDivider = RCC_APB4_DIV2;
- if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_4) != HAL_OK) {
- Error_Handler();
MCO 初始化:
- HAL_RCC_MCOConfig(RCC_MCO2, RCC_MCO2SOURCE_SYSCLK, RCC_MCODIV_10);
测得的频率为 45.99 MHz,与应有的 48 MHz 相差 -4.2%。
如果我改成 400MHz,结果是一样的。-4.2% 从它应该是什么。
