ST意法半导体
王秀珍
7年用户 1400经验值
怎么去解决STM32CubeIDE 1.5.0崩溃的问题呢?
我无法将现有项目导入工作区。这是我尝试选择根目录时的错误日志:
  • eclipse.buildId=Version 1.5.0
  • java.version=1.8.0_272
  • java.vendor=AdoptOpenJDK
  • BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
  • Command-line arguments:  -os linux -ws gtk -arch x86_64
  • org.eclipse.ui.workbench
  • Error
  • Mon Nov 23 11:08:37 CET 2020
  • Unhandled event loop exception
  • org.eclipse.swt.SWTError: No more handles
  •         at org.eclipse.swt.SWT.error(SWT.java:4749)
  •         at org.eclipse.swt.SWT.error(SWT.java:4638)
  •         at org.eclipse.swt.SWT.error(SWT.java:4609)
  •         at org.eclipse.swt.widgets.Dialog.error(Dialog.java:202)
  •         at org.eclipse.swt.widgets.DirectoryDialog.openNativeChooserDialog(DirectoryDialog.java:139)
  •         at org.eclipse.swt.widgets.DirectoryDialog.open(DirectoryDialog.java:123)
  •         at org.eclipse.ui.internal.wizards.datatransfer.WizardProjectsImportPage.handleLocationDirectoryButtonPressed(WizardProjectsImportPage.java:1209)
  •         at org.eclipse.ui.internal.wizards.datatransfer.WizardProjectsImportPage$7.widgetSelected(WizardProjectsImportPage.java:726)
  •         at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:252)
  •         at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:89)
  •         at org.eclipse.swt.widgets.Display.sendEvent(Display.java:5685)
  •         at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1423)
  •         at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4953)
  •         at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:4446)
  •         at org.eclipse.jface.window.Window.runEventLoop(Window.java:823)
  •         at org.eclipse.jface.window.Window.open(Window.java:799)
  •         at org.eclipse.ui.internal.handlers.WizardHandler$Import.executeHandler(WizardHandler.java:151)
  •         at org.eclipse.ui.internal.handlers.WizardHandler.execute(WizardHandler.java:280)
  •         at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:283)
  •         at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:97)
  •         at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
  •         at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
  •         at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
  •         at java.lang.reflect.Method.invoke(Method.java:498)
  •         at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:58)
  •         at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:319)
  •         at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:253)
  •         at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:173)
  •         at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:156)
  •         at org.eclipse.core.commands.Command.executeWithChecks(Command.java:488)
  •         at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:487)
  •         at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:213)
  •         at org.eclipse.ui.internal.handlers.LegacyHandlerService.executeCommand(LegacyHandlerService.java:389)
  •         at org.eclipse.ui.internal.handlers.LegacyHandlerService.executeCommand(LegacyHandlerService.java:366)
  •         at org.eclipse.ui.internal.views.helpers.EmptyWorkspaceHelper$ImportAction.run(EmptyWorkspaceHelper.java:393)
  •         at org.eclipse.ui.internal.views.helpers.EmptyWorkspaceHelper$1.linkActivated(EmptyWorkspaceHelper.java:275)
  •         at org.eclipse.ui.forms.widgets.AbstractHyperlink.handleActivate(AbstractHyperlink.java:215)
  •         at org.eclipse.ui.forms.widgets.AbstractHyperlink.handleMouseUp(AbstractHyperlink.java:309)
  •         at org.eclipse.ui.forms.widgets.AbstractHyperlink.lambda$3(AbstractHyperlink.java:117)
  •         at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1158)
  •         at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:338)
  •         at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1047)
  •         at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:155)
  •         at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:658)
  •         at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:557)
  •         at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:154)
  •         at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:150)
  •         at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:203)
  •         at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137)
  •         at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107)
  •         at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401)
  •         at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:255)
  •         at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:657)
  •         at org.eclipse.equinox.launcher.Main.basicRun(Main.java:594)
  •         at org.eclipse.equinox.launcher.Main.run(Main.java:1447)
  •         at org.eclipse.equinox.launcher.Main.main(Main.java:1420)
有什么提示吗?
回帖(1)
王雪
2023-1-12 15:20:53
我在我们支持的 Linux 发行版 Ubuntu® LTS 18.04、LTS 20.04、Fedora® 29 和 Fedora® 31 上运行了一些导入测试。但是,我无法重现该问题,所以我猜测它可能是Mint 特有的东西,但我没有该发行版的测试环境,因为我们不正式支持它。
您是否有其他操作系统可以尝试用例,看看您是否遇到同样的问题?
