我尝试将具有 ESP8266 内核的 ESP-wroom-02 配置为 SPI 从设备。但是除了技术参考 ESP8266 之外,没有找到太多关于 SPI 配置的信息。该项目有一个 arduino nano iot 33 (samd21g18 arm-m0) 作为与 Slave ESP8266
通信的主机。
我用逻辑分析仪检查了主机发送数据和时钟,但从机没有响应。我还测试了使用 arduino uno 作为从站,并与 arduino iot SPI Master 一起工作。
引脚设置:
- 在 ESP 上:IO14->SCK、IO12->MISO、IO13->MOSI、IO15->CS
- 在 Arduino 上:D12->MISO、D13->SCK、D11->MOSI、D10->CS
从代码:
主例程
代码:
全选#include "hspiESP8266.h"
#include
using namespace std;
#define MISO 12
#define MOSI 13
extern uint8_t bdata[LENGTH];
char c = 'c';
bdata[0] = (uint8_t)c;
void setup() {
Serial.begin(115200);
pinMode(MISO, OUTPUT);
pinMode(MOSI, INPUT);
HSPISlave SPIS;
attachInterrupt(digitalPinToInterrupt(SYNC), sync_isr, FALLING);
SPIS.begin();
void loop() {
delay(100);
Serial.println((data[0] << 16));
头文件
代码:全选#include "hspiESP8266.h"
volatile bool data_ready = false; // set by HSPI interrupt handler when data is received
volatile bool new_readings = false; // set by sync pin interrupt when readings are extracted from raw data
CACHE_RAM_ATTR sync_isr();
void ICACHE_RAM_ATTR _hspi_slave_isr_handler(void *);
uint8_t* read_hspi(){
return bdata;
void ICACHE_RAM_ATTR _hspi_slave_isr_handler(void *) {
uint32_t istatus = SPIIR;
if(istatus & (1 << SPII1)) { //SPI1 ISR
uint32_t status = SPI1S;
SPI1S &= ~(0x3E0); //disable interrupts
SPI1S |= SPISSRES; //reset
SPI1S &= ~(0x1F); //clear interrupts
SPI1S |= (0x3E0); //enable interrupts
if(status & SPISWBIS) {
uint8_t *p = bdata;
for(int i = 0; i < LENGTH / 4; i++) {
uint32_t dword = SPI1W(i);
*p++ = dword;
*p++ = dword >> 8;
*p++ = dword >> 16;
*p++ = dword >> 24;
data_ready = true;
} else if(istatus & (1 << SPII0)) { //SPI0 ISR
SPI0S &= ~(0x3ff);//clear SPI ISR
} else if(istatus & (1 << SPII2)) {} //I2S ISR
void ICACHE_RAM_ATTR sync_isr() { // Sync pin interrupt on falling edge
SPI1S |= SPISSRES; // Reset HSPI slave
SPI1S &= ~SPISSRES;
SPI1CMD = SPICMDUSR; // Start HSPI slave
static bool glitch = false;
if(data_ready) { // If a data has been received by the HSPI
data_ready = false;
if( glitch) { // reject samples that have been shifted right by noise on the clock line?
glitch = false; // sample accepted
new_readings = true; // new raw readings ready
else
glitch = true; // only reject one sample
//contructor
HSPISlave::HSPISlave(){
void HSPISlave::begin(){
pinMode(SCK, SPECIAL); // Both inputs in slave mode
pinMode(MOSI, SPECIAL);
SPI1C = 0; // SPI_CTRL_REG MSB first, single bit data mode.
SPI1S = SPISE | SPISBE | SPISCD | 0x3E0;// SPI_SLAVE_REG, set slave mode, WR/RD BUF enable, CMD define, enable interrupts
SPI1U = SPIUSSE; // SPI_USER_REG. SPI_CK_I_EDGE
SPI1CLK = 0; // SPI_CLOCK_REG
SPI1U1 = 7 << SPILADDR; // SPI_USER1_REG, set address LENGTH to 8 bits
SPI1U2 = 7 << SPILCOMMAND; // SPI_USER2_REG, set command LENGTH to 8 bits
SPI1S1 = (LENGTH * 8 - 1) << SPIS1LBUF; // SPI_SLAVE1_REG, SPI_SLV_BUF_BITLEN = 12 bytes
SPI1S3 = 0xF1F200F3; // SPI_SLAVE3_REG,, Define command 0 to be write buffer, others something doesn't match
SPI1P = 1 << 19; // SPI_PIN_REG, Clock idle high, seems to cause contension on the clock pin if set to idle low.
ETS_SPI_INTR_ATTACH(_hspi_slave_isr_handler, 0);
ETS_SPI_INTR_ENABLE();
void HSPISlave::end(){
SPI1S |= SPISSRES;
SPI1CMD = 0;
pinMode(SCK, INPUT); // Return to inputs to avoid glicthing the PZEM-021 during reset
void HSPISlave::INTreset(){
void HSPISlave::reset(){
SPI1S &= ~SPISSRES;
