乐鑫技术交流
挽你何用
9年用户 894经验值
擅长:电源/新能源 MEMS/传感技术
led pwm在light-sleep模式下没有PWM输出是怎么回事?
ledc 配置如下, led pwm在light-sleep模式下没有PWM输出。
在切换rtc_clk_slow_freq_set(RTC_SLOW_FREQ_8MD256)后,PWM输出才正常,但是电流明显增大。
请问,是否可以在rtc_clk_slow_freq_set(RTC_SLOW_FREQ_32K_XTAL)条件下,进入light-sleep后正常工作?
回帖(1)
张秀梅
2023-3-3 14:30:17
// Prepare and then apply the LEDC PWM timer configuration
        ledc_timer_config_t ledc_timer = {
                .speed_mode       = LEDC_LOW_SPEED_MODE,
                .timer_num        = LEDC_TIMER_1,
                .duty_resolution  = LEDC_TIMER_9_BIT,
                .freq_hz          = 8000,  // Set output frequency at 8 kHz
                .clk_cfg          = LEDC_USE_RTC8M_CLK
        // Prepare and then apply the LEDC PWM channel configuration
        ledc_channel_config_t ledc_channel = {
                .channel        = LEDC_CHANNEL_3,
                .timer_sel      = LEDC_TIMER_1,
                .intr_type      = LEDC_INTR_DISABLE,
                .gpio_num       = 5,
                .duty           = 0, // Set duty to 0%
                .hpoint         = 0,
                .flags.output_invert = 1
