乐鑫技术交流
李芳
7年用户 1462经验值
ESP32 A2DP发送音频流到I2S从机报错怎么解决?
芯片为ESP32,A2DP发送音频流到I2S从机,I2S流配置为
#define I2S_STREAM_CFG() {
    .type = AUDIO_STREAM_WRITER,
    .i2s_config = {
        .mode = I2S_MODE_SLAVE | I2S_MODE_TX | I2S_MODE_RX,
        .sample_rate = 44100,
        .bits_per_sample = 32,
        .channel_format = I2S_CHANNEL_FMT_RIGHT_LEFT,
        .communication_format = I2S_COMM_FORMAT_STAND_MSB,
        .intr_alloc_flags = ESP_INTR_FLAG_LEVEL2 | ESP_INTR_FLAG_IRAM,
        .dma_buf_count = 2,
        .dma_buf_len = 256,
        .tx_desc_auto_clear = true,
        .use_apll = false,
        .fixed_mclk = 0,
                .mclk_multiple = 0,
    .i2s_port = I2S_NUM_0,
    .use_alc = false,
    .volume = 0,
    .out_rb_size = 4096,
    .task_stack = 4096,
    .task_core = 1,
    .task_prio = 23,
    .stack_in_ext = false,
    .multi_out_num = 0,
    .uninstall_drv = true,
    .need_expand = true,
    .expand_src_bits = 16,
左声道存在很严重的杂音,
将配置中修改 .channel_format = I2S_COMM_FORMAT_STAND_MSB,直接出错:
W (10580) BT_APPL: new conn_srvc id:19, app_id:1
W (11196) A2DP_STREAM: discard a2dp(0x3ffda894) sink pkt, A2DP_STREAM_QUEUE_SIZE value needs to be expanded
W (11203) A2DP_STREAM: discard a2dp(0x3ffda894) sink pkt, A2DP_STREAM_QUEUE_SIZE value needs to be expanded
W (11296) A2DP_STREAM: discard a2dp(0x3ffda894) sink pkt, A2DP_STREAM_QUEUE_SIZE value needs to be expanded
W (11302) A2DP_STREAM: discard a2dp(0x3ffda894) sink pkt, A2DP_STREAM_QUEUE_SIZE value needs to be expanded
