NXP MCU 技术william hill官网
陈韵瑄
7年用户 970经验值
IMX8MP ISI.0 MIPI-CSI2摄像头采集问题求解
我有一个内核版本为 5.4.70 的 IMX8MP 处理器。
我正在尝试将相机连接到 csi0(相机 --> mipi csi 0 --> isi0 --> /dev/video0)。
在另一个输入(相机 --> mipi csi 1 --> isi0 --> /dev/video1)上,它可以在相同的设置下正常工作。
可能是什么问题呢?
camera_0: camera_0_mipi@3e {
        compatible = "camera_0";
        reg = <0x3e>;
        pinctrl-names = "default";
        pinctrl-0 = <&pinctrl_csi0_rst>, <&pinctrl_csi0_pwn>;
        csi_id = <0>;
        reset-gpios = <&gpio3 19 GPIO_ACTIVE_LOW>;
        enable-gpios = <&gpio3 20 GPIO_ACTIVE_HIGH>;
        mipi_csi;
        status = "okay";
        port {
                camera_mipi_0_ep: endpoint {
                        bus-type = <4>;
                        data-lanes = <1 2 3 4>;
                        clock-lanes = <0>;
                        remote-endpoint = <&mipi_csi0_ep>;
camera_1: camera_1_mipi@3c {
        compatible = "camera_1";
        reg = <0x3c>;
        pinctrl-0 = <&pinctrl_csi1_rst>, <&pinctrl_csi1_pwn>;
        csi_id = <1>;
        reset-gpios = <&gpio1 6 GPIO_ACTIVE_LOW>;
        enable-gpios = <&gpio2 11 GPIO_ACTIVE_HIGH>;
        mipi_csi;
        status = "okay";
        port {
                camera_mipi_1_ep: endpoint {
                        bus-type = <4>;
                        clock-lanes = <0>;
                        remote-endpoint = <&mipi_csi1_ep>;
&mipi_csi_0 {
        #address-cells = <1>;
        #size-cells = <0>;
        status = "okay";
        port@0 {
                reg = <0>;
                mipi_csi0_ep: endpoint {
                        remote-endpoint = <&camera_mipi_0_ep>;
                        data-lanes = <4>;
                        csis-hs-settle = <13>;
                        csis-clk-settle=<2>;
                        csis-wclk;
&mipi_csi_1 {
        #size-cells = <0>;
        status = "okay";
        port@1 {
                reg = <1>;
                mipi_csi1_ep: endpoint {
                        remote-endpoint = <&camera_mipi_1_ep>;
                        data-lanes = <4>;
                        csis-wclk;
&cameradev {
        status = "okay";
&isi_0 {
        status = "okay";
        cap_device {
                status = "okay";
//        m2m_device {
//                status = "okay";
&isi_1 {
        status = "okay";
        cap_device {
                status = "okay";
&isp_0 {
    status = "disabled";
&isp_1 {
&dewarp_0 {
