你好
我们正在尝试使用 FRWY-LS1046A 板启用对 Infineon SLB9670 TPM 2.0 模块的支持。 我们修改了spi的设备树: &dspi { status = "okay"; tpm0: slb9670@0 { #address-cells = <1>; #size-cells = <1>; compatible = "infineon,slb9670"; reg = <0>; spi-max-frequency = <1000000>; }; }; 并启用 kenel 选项: CONFIG_HW_RANDOM_TPM=y CONFIG_TCG_TPM=y CONFIG_TCG_TIS_CORE=y CONFIG_TCG_TIS_SPI=y CONFIG_TCG_INFINEON=y CONFIG_SECURITYFS=y 当前 TPM 由内核找到,并且 /dev/tpm0 设备已创建: $> dmesg | grep tpm [ 2.477519] tpm_tis_spi spi0.0: 2.0 TPM (device-id 0x9B, rev-id 22) [ 2.488946] tpm tpm0: A TPM error (256) occurred attempting the self test [ 2.496570] tpm tpm0: starting up the TPM manually $> ls -la /dev/tpm* crw------- 1 root root 10, 224 Jul 21 19:00 /dev/tpm0 crw------- 1 root root 253, 65536 Jul 21 19:00 /dev/tpmrm0 但是当我尝试使用 tpm2-tools 时问题出现了,我每次都收到这个错误: rmt:error(2.0): command code not supported 例如。: $> tpm2_create -C primary.ctx -L pcr.policy -i seal.dat -u seal.pub -r seal.priv -c seal.ctx -Q WARNING:esys:src/tss2-esys/api/Esys_CreateLoaded.c:355:Esys_CreateLoaded_Finish() Received TPM Error ERROR:esys:src/tss2-esys/api/Esys_CreateLoaded.c:129:Esys_CreateLoaded() Esys Finish ErrorCode (0x000b0143) ERROR: Esys_CreateLoaded(0xB0143) - rmt:error(2.0): command code not supported ERROR: Unable to run tpm2_create 或者: $> tpm2_encryptdecrypt -c key.ctx -o secret.enc secret.dat WARNING:esys:src/tss2-esys/api/Esys_EncryptDecrypt2.c:322:Esys_EncryptDecrypt2_Finish() Received TPM Error ERROR:esys:src/tss2-esys/api/Esys_EncryptDecrypt2.c:107:Esys_EncryptDecrypt2() Esys Finish ErrorCode (0x000b0143) WARNING:esys:src/tss2-esys/api/Esys_EncryptDecrypt.c:328:Esys_EncryptDecrypt_Finish() Received TPM Error ERROR:esys:src/tss2-esys/api/Esys_EncryptDecrypt.c:110:Esys_EncryptDecrypt() Esys Finish ErrorCode (0x000b0143) ERROR: Esys_EncryptDecrypt(0xB0143) - rmt:error(2.0): command code not supported ERROR: Unable to run tpm2_encryptdecrypt 怎么了?这是与系统/库或内核相关的问题吗? |
1946个成员聚集在这个小组
36485 浏览 0 评论
5521 浏览 1 评论
6158 浏览 1 评论
6853 浏览 0 评论
4280 浏览 0 评论
676浏览 2评论
662浏览 2评论
670浏览 2评论
755浏览 2评论
885浏览 2评论
GMT+8, 2025-1-14 07:20 , Processed in 0.814746 second(s), Total 44, Slave 38 queries .
