我有一个 ESP-Prog 连接到 TTGO T8 ESP32 板(仅限 JTAG 接口)。一旦我初始化 sd 卡,我就无法调试应用程序。
以下是有效的日志(无 SD 卡):
$ openocd -f interface/ftdi/esp32_devkitj_v1.cfg -f target/esp32.cfg
Open On-Chip Debugger v0.11.0-esp32-20221026 (2022-10-26-14:47)
Licensed under GNU GPL v2
For bug reports, read
adapter speed: 20000 kHz
Info : Listening on port 6666 for tcl connec
tions
Info : Listening on port 4444 for telnet connections
Info : ftdi: if you experience problems at higher adapter clocks, try the command "ftdi tdo_sample_edge falling"
Info : clock speed 20000 kHz
Info : JTAG tap: esp32.cpu0 tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1)
Info : JTAG tap: esp32.cpu1 tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1)
Info : starting gdb server for esp32.cpu0 on 3333
Info : Listening on port 3333 for gdb connections
Info : [esp32.cpu0] Debug controller was reset.
Info : [esp32.cpu0] Core was reset.
Info : [esp32.cpu1] Debug controller was reset.
Info : [esp32.cpu1] Core was reset.
Info : [esp32.cpu0] Target halted, PC=0x4008C192, debug_reason=00000000
Info : [esp32.cpu0] Reset cause (1) - (Power on reset)
Info : [esp32.cpu1] Target halted, PC=0x4008C192, debug_reason=00000000
Info : [esp32.cpu1] Reset cause (14) - (CPU1 reset by CPU0)
