NXP MCU 技术william hill官网
youyoulan
12年用户 1140经验值
为什么无法在ubuntu20.04上使用flex builder构建tsntool?
当我在 ubuntu20.04 上使用 flex builder 编译 tsntool 时,发现无法访问“的错误我读了另一篇文章那个来源。 codeaurora.org 停止服务了,那么现在有什么办法可以编译 tsntool 吗?
hingw@ubuntu:~/ls1028/flexbuild_lsdk2108$ flex-builder -c tsntool
COMPONENT: tsntool
make: Entering directory '/home/hingw/ls1028/flexbuild_lsdk2108'
make[1]: Entering directory '/home/hingw/ls1028/flexbuild_lsdk2108/packages/apps'
Building tsntool ...
Cloning into '/home/hingw/ls1028/flexbuild_lsdk2108/components/apps/networking/tsntool'...
fatal: unable to accessCould not resolve host: source.codeaurora.org
make[1]: *** [/home/hingw/ls1028/flexbuild_lsdk2108/packages/apps/networking/tsntool.mk:11: tsntool] Error 128
make[1]: Leaving directory '/home/hingw/ls1028/flexbuild_lsdk2108/packages/apps'
make: *** [Makefile:25: tsntool] Error 2
make: Leaving directory '/home/hingw/ls1028/flexbuild_lsdk2108'
另外,我在github上看到tsntool源码包,编译器说明指定了一个kernal源码路径,这个路径应该填什么?
1. Libraries requirement
   Libraries libnl-3.0, libtermcap, libreadline libcjson are needed.
2. How to compile the tsntool:
2.1 Setup cross compile environment
2.2 Compile binary:
    > source source_arm64.sh
    > make
    The tsntool and libtsn.so will be generated.
