NXP MCU 技术william hill官网
任凭风吹
9年用户 976经验值
擅长:可编程逻辑 电源/新能源 MEMS/传感技术 制造/封装 模拟技术
S32K312可以在运行时将PTC2更改为EIRQ[2]吗?
我在引脚初始化配置中将 PTC2 设置为 CAN RX 模式。
我可以在运行时将 PTC2 更改为 EIRQ[2] 吗?
无需更改引脚初始化配置。
而且,在运行时回到 CAN RX 模式?
谢谢
const Siul2_Port_Ip_PinSettingsConfig g_pin_mux_InitConfigArr0[NUM_OF_CONFIGURED_PINS0] =
        .base                        = IP_SIUL2,
        .pinPortIdx                  = 66u,
        .mux                         = PORT_MUX_AS_GPIO,
        .safeMode                    = PORT_SAFE_MODE_DISABLED,
        .inputFilter                 = PORT_INPUT_FILTER_DISABLED,
        .driveStrength               = PORT_DRIVE_STRENTGTH_DISABLED,
        .pullConfig                  = PORT_INTERNAL_PULL_NOT_ENABLED,
        .slewRateCtrlSel             = PORT_SLEW_RATE_SLOWEST,
        .pullKeep                    = PORT_PULL_KEEP_DISABLED,
        .invert                      = PORT_INVERT_DISABLED,
        .inputBuffer                 = PORT_INPUT_BUFFER_ENABLED,
        .outputBuffer                = PORT_OUTPUT_BUFFER_DISABLED,
        .adcInterleaves              = { MUX_MODE_NOT_AVAILABLE, MUX_MODE_NOT_AVAILABLE },
        .inputMuxReg                 = {
                                         0u
        .inputMux                    = {
                                         PORT_INPUT_MUX_ALT1,
                                         PORT_INPUT_MUX_NO_INIT,
