端口未关闭,需要检查SR寄存器的状态,然后再根据当前状态执行相应操作,不知道你是客户端还是服务器,但是原理是一样的。这里贴一下官方例程:
int32_t loopback_tcps(uint8_t sn, uint8_t* buf, uint16_t port)
int32_t ret;
uint16_t size = 0, sentsize=0;
#ifdef _LOOPBACK_DEBUG_
uint8_t destip[4];
uint16_t destport;
#endif
switch(getSn_SR(sn))
case SOCK_ESTABLISHED :
if(getSn_IR(sn) & Sn_IR_CON)
getSn_DIPR(sn, destip);
destport = getSn_DPORT(sn);
printf("%d:Connected - %d.%d.%d.%d : %d\r\n",sn, destip[0], destip[1], destip[2], destip[3], destport);
#endif
setSn_IR(sn,Sn_IR_CON);
if((size = getSn_RX_RSR(sn)) > 0) // Don't need to check SOCKERR_BUSY because it doesn't not occur.
if(size > DATA_BUF_SIZE) size = DATA_BUF_SIZE;
ret = recv(sn, buf, size);
if(ret <= 0) return ret; // check SOCKERR_BUSY & SOCKERR_XXX. For showing the occurrence of SOCKERR_BUSY.
size = (uint16_t) ret;
sentsize = 0;
while(size != sentsize)
ret = send(sn, buf+sentsize, size-sentsize);
if(ret < 0)
close(sn);
return ret;
sentsize += ret; // Don't care SOCKERR_BUSY, because it is zero.
break;
case SOCK_CLOSE_WAIT :
//printf("%d:CloseWait\r\n",sn);
#endif
if((ret = disconnect(sn)) != SOCK_OK) return ret;
printf("%d:Socket Closed\r\n", sn);
#endif
break;
case SOCK_INIT :
printf("%d:Listen, TCP server loopback, port [%d]\r\n", sn, port);
#endif
if( (ret = listen(sn)) != SOCK_OK) return ret;
break;
case SOCK_CLOSED:
//printf("%d:TCP server loopback start\r\n",sn);
#endif
if((ret = socket(sn, Sn_MR_TCP, port, 0x00)) != sn) return ret;
//printf("%d:Socket opened\r\n",sn);
#endif
break;
default:
break;
return 1;
int32_t ret;
uint8_t destip[4];
uint16_t destport;
#endif
#endif
sentsize = 0;
if(ret < 0)
close(sn);
return ret;
break;
#endif
#endif
break;
case SOCK_INIT :
#endif
break;
case SOCK_CLOSED:
#endif
#endif
break;
default:
break;
return 1;
