乐鑫技术交流
张国厚
7年用户 1383经验值
求助,win10 vscode编译esp-at失败,请问有对应最新版的教程吗?
用下面网页的教程安装流程,安装成功,
使用ESP-IDF launch GUI configation tool失败,停留在 ESP-IDF :Menuconfig: loading initial values.. 提示窗口。
输出显示:
---------------------------ERROR--------------------------
CMake Error at CMakeLists.txt:9 (string):
-----------------------END OF ERROR-----------------------
  string no output variable specified
CMake Error at CMakeLists.txt:13 (string):
  string begin index: 9 is out of range 0 - 0
CMake Error at CMakeLists.txt:14 (string):
  string sub-command STRIP requires two arguments.
CMake Error at CMakeLists.txt:15 (string):
silence:0 sdkconfig:C:/ESP/esp-at/module_config/module__default/sdkconfig.defaults
CMake Error at CMakeLists.txt:49 (include):
  include could not find load file:
    C:/ESP/esp-at/esp-idf/tools/cmake/project.cmake
-- The C compiler identification is unknown
使用ESP-IDE Build project,也失败,终端窗口提示
> Executing task: cmake -G Ninja .. <
-- The CXX compiler identification is unknown
CMake Error at CMakeLists.txt:51 (project):
  No CMAKE_C_COMPILER could be found.
  Tell CMake where to find the compiler by setting either the environment
  variable "CC" or the CMake cache entry CMAKE_C_COMPILER to the full path to
  the compiler, or to the compiler name if it is in the PATH.
  No CMAKE_CXX_COMPILER could be found.
  variable "CXX" or the CMake cache entry CMAKE_CXX_COMPILER to the full path
  to the compiler, or to the compiler name if it is in the PATH.
-- Configuring incomplete, errors occurred!
See also "C:/ESP/esp-at/build/CMakeFiles/CMakeOutput.log".
See also "C:/ESP/esp-at/build/CMakeFiles/CMakeError.log".
终端进程“C:\WINDOWS\System32\WindowsPowerShell\v1.0\powershell.exe -Command cmake -G Ninja ..”已终止,退出代码: 1。
终端将被任务重用,按任意键关闭。
command 编译,使用 ./build.py menuconfig 命令也无法成功。
请问是不是当前版本的安装流程不同?
哪里有对应当前版本 esp-at 使用 vscode 的esp-idf扩展编译的教程?
