请问有人遇到过这种烧录失败的问题吗?同个板子同个固件前几次烧录还是ok的
raise FatalError(msg)
__main__.FatalError: Serial data stream stopped: Possible serial noise or corruption.
During handling of the above exception, another exception occurred:
Traceback (most recent call last):
File "d:\Espressif\frameworks\esp-idf-v4.4.2\components\esptool_py\esptool\esptool.py", line 5399, in <module>
_main()
File "d:\Espressif\frameworks\esp-idf-v4.4.2\components\esptool_py\esptool\esptool.py", line 5392, in _main
main()
File "d:\Espressif\frameworks\esp-idf-v4.4.2\components\esptool_py\esptool\esptool.py", line 4824, in main
operation_func(esp, args)
File "d:\Espressif\frameworks\esp-idf-v4.4.2\components\esptool_py\esptool\esptool.py", line 4019, in write_flash
esp.flash_defl_block(block, seq, timeout=timeout)
File "d:\Espressif\frameworks\esp-idf-v4.4.2\components\esptool_py\esptool\esptool.py", line 143, in inner
return func(*args, **kwargs)
File "d:\Espressif\frameworks\esp-idf-v4.4.2\components\esptool_py\esptool\esptool.py", line 931, in flash_defl_block
self.check_command("write compressed data to flash after seq %d" % seq,
File "d:\Espressif\frameworks\esp-idf-v4.4.2\components\esptool_py\esptool\esptool.py", line 495, in check_command
val, data = self.command(op, data, chk, timeout=timeout)
File "d:\Espressif\frameworks\esp-idf-v4.4.2\components\esptool_py\esptool\esptool.py", line 484, in command
self._port.timeout = saved_timeout
File "d:\Espressif\python_env\idf4.4_py3.8_env\lib\site-packages\serial\serialutil.py", line 372, in timeout
self._reconfigure_port()
File "d:\Espressif\python_env\idf4.4_py3.8_env\lib\site-packages\serial\serialwin32.py", line 222, in _reconfigure_port
raise SerialException(
serial.serialutil.SerialException: Cannot configure port, something went wrong. Original message: PermissionError(13, '设备不识别此命令。', None, 22)
