全志科技
文小二
2年用户 895经验值
擅长:嵌入式技术 处理器/DSP 控制/MCU
100ASK百问网 全志D1s/T113-s3开发板 适配ov5640教程
本实验采用百问网的100ASK_T113-PRO Base V1.1 ,
D1s也可以参考进行修改并适配。
本实验所需的文件(含tina根文件系统、SD镜像、设备树、内核配置文件)供大家对比参考:source.zip
1.硬件配置
查看百问网提供的T113开发板原理图100ASK_T113-Pro_Base-SCH.pdf
通过查看到第3页的摄像头原理图
在这里插入图片描述
①将PE引脚使用跳线帽连接至CSI引脚。
在这里插入图片描述
②根据所使用的摄像头,利用跳线帽,使AVDD、DVDD、DIOVDD选择不同的电压
在这里插入图片描述
我所使用的是ov5640,使用2.8V的AVDD、1.5V的DVDD、2.8V的DIOVDD
在这里插入图片描述
③根据摄像头的引脚信息,上接至T113开发板的DVP接口
在这里插入图片描述
2.修改设备树
注意:T113中的网口和CSI接口复用,注意设备树中网口的PE的复用功能需要修改为CSI的PE的复用功能。
文件名:sun8iw20p1-t113-100ask-t113-pro.dts
文件目录:buildroot_100ask_t113-pro/buildroot/output/build/linux-origin_master/arch/arm/boot/dts/
&vind0 {
	csi_top = <378000000>;
	csi_isp = <327000000>;
	status = "okay"; /* enable twi and ver1 spi-nand max freq 30M */
	actuator0: actuator@5809450 {
		device_type = "actuator0";
		actuator0_name = "ad5820_act";
		actuator0_slave = <0x18>;
		actuator0_af_pwdn = <>;
		actuator0_afvdd = "afvcc-csi";
		actuator0_afvdd_vol = <2800000>;
		status = "okay";
	flash0: flash@5809460 {
		device_type = "flash0";
		flash0_type = <2>;
		flash0_en = <>;
		flash0_mode = <>;
		flash0_flvdd = "";
		flash0_flvdd_vol = <>;
		device_id = <0>;
		status = "okay";
	sensor0: sensor@5809470 {
		reg = <0x0 0x05809470 0x0 0x10>;
		device_type = "sensor0";
		compatible = "allwinner,sunxi-sensor";
		sensor0_mname = "ov5640";
		sensor0_twi_cci_id = <2>;
		sensor0_twi_addr = <0x78>;
		sensor0_mclk_id = <0>;
		sensor0_pos = "rear";
		sensor0_isp_used = <0>;
		sensor0_fmt = <0>;
		sensor0_stby_mode = <0>;
		sensor0_vflip = <0>;
		sensor0_hflip = <0>;
		sensor0_iovdd-supply = <>;
		sensor0_iovdd_vol = <1800000>;
		sensor0_avdd-supply = <>;
		sensor0_avdd_vol = <2800000>;
		sensor0_dvdd-supply = <>;
		sensor0_dvdd_vol = <1500000>;
		sensor0_power_en = <>;
		sensor0_reset = <>;
		//sensor0_reset = <&pio PE 15 GPIO_ACTIVE_LOW>;
		//sensor0_pwdn = <&pio PE 14 GPIO_ACTIVE_LOW>;
		//sensor0_reset = <&pio PE 13 GPIO_ACTIVE_LOW>;
		sensor0_pwdn = <>;
		sensor0_sm_vs = <>;
		flash_handle = <&flash0>;
		act_handle = <&actuator0>;
		device_id = <0>;
		status  = "okay";
	sensor1:sensor@5809480 {
		device_type = "sensor1";
		sensor1_mname = "ov5647";
		sensor1_twi_cci_id = <3>;
		sensor1_twi_addr = <0x6c>;
		sensor1_mclk_id = <1>;
		sensor1_pos = "front";
		sensor1_isp_used = <0>;
		sensor1_fmt = <0>;
		sensor1_stby_mode = <0>;
		sensor1_vflip = <0>;
		sensor1_hflip = <0>;
		sensor1_iovdd-supply = <>;
		sensor1_iovdd_vol = <>;
		sensor1_avdd-supply = <>;
		sensor1_avdd_vol = <>;
		sensor1_dvdd-supply = <>;
		sensor1_dvdd_vol = <>;
		sensor1_power_en = <>;
		sensor1_reset = <&pio PE 7 GPIO_ACTIVE_LOW>;
		sensor1_pwdn = <&pio PE 6 GPIO_ACTIVE_LOW>;
		status	= "disabled";
	vinc0:vinc@5809000 {
		vinc0_csi_sel = <0>;
		vinc0_mipi_sel = <0xff>;
		vinc0_isp_sel = <0>;
		vinc0_isp_tx_ch = <0>;
		vinc0_tdm_rx_sel = <0xff>;
		vinc0_rear_sensor_sel = <0>;
		vinc0_front_sensor_sel = <0>;
		vinc0_sensor_list = <0>;
		status = "okay";
	vinc1:vinc@5809200 {
		vinc1_csi_sel = <0>;
		vinc1_mipi_sel = <0xff>;
		vinc1_isp_sel = <0>;
		vinc1_isp_tx_ch = <1>;
		vinc1_tdm_rx_sel = <0xff>;
		vinc1_rear_sensor_sel = <0>;
		vinc1_front_sensor_sel = <1>;
		vinc1_sensor_list = <0>;
文件名:sun8iw20p1.dtsi
vind0: vind@5800800 {
			compatible = "allwinner,sunxi-vin-media", "simple-bus";
			#address-cells = <2>;
			#size-cells = <2>;
			ranges;
			device_id = <0>;
			csi_top = <336000000>;
			reg = <0x0 0x05800800 0x0 0x200>,
				<0x0 0x05800000 0x0 0x800>;
			clocks = <&ccu CLK_CSI_TOP>, <&ccu CLK_PLL_VIDEO1_2X>,
				<&ccu CLK_CSI0_MCLK>, <&dcxo24M>, <&ccu CLK_PLL_VIDEO1>,
				<&ccu CLK_BUS_CSI>, <&ccu CLK_MBUS_CSI>;
			clock-names = "csi_top", "csi_top_src",
					"csi_mclk0", "csi_mclk0_24m", "csi_mclk0_pll",
					"csi_bus", "csi_mbus";
			resets = <&ccu RST_BUS_CSI>;
			reset-names = "csi_ret";
			pinctrl-names = "mclk0-default", "mclk0-sleep";
			pinctrl-0 = <&csi_mclk0_pins_a>;
			pinctrl-1 = <&csi_mclk0_pins_b>;
			status = "okay";
			csi0: csi@5801000{
				compatible = "allwinner,sunxi-csi";
				reg = <0x0 0x05801000 0x0 0x1000>;
				interrupts = <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH>;
				pinctrl-names = "default","sleep";
				pinctrl-0 = <&csi0_pins_a>;
				pinctrl-1 = <&csi0_pins_b>;
				device_id = <0>;
				iommus = <&mmu_aw 1 1>;
				status = "okay";
			isp0: isp@5809410 {
				compatible = "allwinner,sunxi-isp";
				reg = <0x0 0x05809410 0x0 0x10>;
				device_id = <0xfe>;
				status = "okay";
			isp1: isp@5809420 {
				reg = <0x0 0x05809420 0x0 0x10>;
				device_id = <0xff>;
				status = "okay";
			scaler0: scaler@5809430 {
				compatible = "allwinner,sunxi-scaler";
				reg = <0x0 0x05809430 0x0 0x10>;
				device_id = <0xfe>;
				status = "okay";
			scaler1: scaler@5809440 {
				reg = <0x0 0x05809440 0x0 0x10>;
				device_id = <0xff>;
				status = "okay";
				compatible = "allwinner,sunxi-actuator";
				reg = <0x0 0x05809450 0x0 0x10>;
				compatible = "allwinner,sunxi-flash";
				reg = <0x0 0x05809460 0x0 0x10>;
				flash0_type = <2>;
				flash0_en = <>;
				flash0_mode = <>;
				flash0_flvdd = "";
				device_id = <0>;
				sensor0_fmt = <0>;
				sensor0_iovdd_vol = <>;
				sensor0_avdd_vol = <>;
				sensor0_dvdd_vol = <>;
				sensor0_reset = <&pio PE 9 GPIO_ACTIVE_LOW>;
				sensor0_pwdn = <&pio PE 8 GPIO_ACTIVE_LOW>;
				sensor0_sm_vs = <>;
				device_id = <0>;
				status	= "okay";
			sensor1: sensor@5809480 {
				reg = <0x0 0x05809480 0x0 0x10>;
				sensor1_fmt = <0>;
				sensor1_sm_vs = <>;
				flash_handle = <>;
				act_handle = <>;
				device_id = <1>;
				status	= "okay";
			vinc0: vinc@5809000 {
				compatible = "allwinner,sunxi-vin-core";
				device_type = "vinc0";
				reg = <0x0 0x05809000 0x0 0x200>;
				interrupts = <GIC_SPI 95 IRQ_TYPE_LEVEL_HIGH>;
				device_id = <0>;
				status = "okay";
			vinc1: vinc@5809200 {
				device_type = "vinc1";
				reg = <0x0 0x05809200 0x0 0x200>;
				interrupts = <GIC_SPI 96 IRQ_TYPE_LEVEL_HIGH>;
				vinc1_isp_sel = <1>;
				vinc1_front_sensor_sel = <0>;
				device_id = <1>;
				status = "okay";
3.修改内核配置
在buildroot目录下,输入
make linux-menuconfig
在这里插入图片描述
进入内核配置界面中的下面目录:
│ -> Device Drivers
│ -> Multimedia support
在这里插入图片描述
对于Media USB Adapters:
在这里插入图片描述
对于V4L platform devices:
在这里插入图片描述
对于SUNXI platform devices:
在这里插入图片描述
对于Memory-to-memory multimedia devices:
在这里插入图片描述
修改完成后,保存并退出。
在这里插入图片描述
4.重新编译和烧写
在buildroot目录下执行
make linux-rebuild
在这里插入图片描述
执行完成后,再打包生成SD卡镜像,输入
make -j4
在这里插入图片描述
5.使用tina的根文件系统启动
将烧录到sd卡的t113系统挂载到ubuntu中 使用 df -h 查看分区
在这里插入图片描述
进入分区
cd /media/book/dd79b15c-ce3f-4d2d-8a75-437303b2df61/
拷贝lib中的驱动到桌面备用
sudo cp -rf lib/modules/5.4.61 ~/Desktop
删除全部文件
sudo rm -rf *
在这里插入图片描述
将source文件夹中的tina_rootfs目录下的rootfs.img拷贝到Ubuntu中,解压tina系统
unsquashfs  rootfs.img
在这里插入图片描述
拷贝tina系统中的文件到当前目录
sudo cp /home/book/squashfs-root/* ./ -rfd
进入lib/modules目录下删除5.4.61文件夹
cd lib/modules/
sudo rm -rf 5.4.61
将5.4.61文件夹拷贝回去
sudo cp ~/Desktop/5.4.61/ ./ -rf
从虚拟机中弹出SD卡。
6.使用camerademo测试
将SD卡插入T113开发板,上电启动。启动界面如下:
在这里插入图片描述
进入sunxi-vin目录:
cd /lib/modules/5.4.61/kernel/drivers/media/platform/sunxi-vin/
装载vin_io.ko驱动
在这里插入图片描述
进入sensor目录:
cdcd modules/sensor/
装载ov5640.ko驱动:
insmod ov5640.ko
在这里插入图片描述
回到sunxi-vin目录:
在这里插入图片描述
装载vin_v4l2.ko驱动:
insmod vin_v4l2.ko
在这里插入图片描述
注意:上述大部分打印信息为我调试时加的打印,与自带驱动无关,全志自带的驱动程序是正常。
插入U盘或无系统的TF卡将获取到的图片提取出来查看。
挂载U盘。
在这里插入图片描述
mount /dev/sda1 /mnt/
使用camerademo拍摄照片,存放到U盘内
camerademo NV21 640 480 30 bmp  /mnt 5
在这里插入图片描述
卸载U盘分区
umount /mnt/
拔下u盘,插入电脑中,即可查看到刚刚在T113开发板上使用ov5640拍摄的5张照片
在这里插入图片描述
原贴链接:https://bbs.aw-ol.com/topic/2589/
资源获取、问题讨论可以到全志在线开发者社区进行:https://www.aw-ol.com
全志及开发者最新动态可以关注全志在线微信公众号
