Cypress技术william hill官网
陈遂
12年用户 12经验值
擅长:RF/无线
Wi-Fi在汽车中的应用_Wi-Fi in Automation
作者:N.Venkatesh,副总裁,高级技术部
Redpine Signals 公司 Kapil Rai 高级总监,赛普拉斯系统方案部 赛普拉斯半导体
Electronic and electrical equipment in the home or commercial buildings have largely been discrete and independent systems – control and management of lighting, temperature, access as well as various alARMs have been carried out by separate control mechanisms. The field of domotics deals with the automation of these systems and recently has been receiving increasing attention:
家用或商业建筑中的电子和电气设备在很大程度上是离散和独立的系统,照明、温度、访问以及各警报控制和管理都是单独的控制机制。Domotics 涉及了这些系统的自动化,最近已逐渐受到重视。
• HVAC control is used to manage temperature and humidity in various parts of a building at various times through, for example, a thermostat accessible over the Internet
• Lighting control systems automatically turn on or off lights in a room, or control brightness and color to create various ambiences
• The operation of appliances such as washers, dryers, and sprinklers can be controlled to take advantage of variations in the cost of utilities
• Data read from sensors monitoring for gas leaks, breakage of glass, intrusion, movement, and smoke can be used to quickly meet required safety measures while raising an appropriate level of alarm
• HVAC 控制可以在不同时间不同地区管理温度和湿度,可以通过互联网进行自动调温控制
• 照明控制系统可以自动打开或关闭室内灯光,或者控制亮度和颜色来营造各种氛围
• 某些设备如洗衣机,烘干机,和洒水器的操作可控制以发挥其成本优势
• 读取传感器监控数据(如气体泄漏,玻璃破碎,入侵,运动,和烟雾)可快速满足所需的安全检测,同时提高警报等级
游客,如果您要查看本帖隐藏内容请回复
回帖(1)
欧阳奕涛
2012-12-15 11:59:32
正好需要
