开发环境:
RT-Thread Studio:v2.2.7
开发板:RA8D1 Vision Board开发板
MCU:R7FA8D1BHEC337AS02
1、定时器简介
硬件定时器一般有 2 种工作模式,定时器模式和计数器模式。不管是工作在哪一种模式,实质都是通过内部计数器模块对脉冲信号进行计数。下面是定时器的一些重要概念。
本定时器设备框架内部会自动处理硬件定时器超时的问题,例如16位定时器在1MHz的频率下最大只能维持65.535ms。但是在本定时器框架下,用户可以将定时器的溢出时间设置为例如500ms,框架内部会自动处理硬件溢出问题。当时间达到500ms后,框架会调用用户预先设置好的回调函数。
| 函数 | 描述 |
| rt_device_find | 查找设备 |
| rt_device_open | 打开设备 |
| rt_device_set_rx_indicate | 设置超时回调函数 |
| rt_device_control | 设置定时器模式 |
| rt_device_write | 设置定时器参数 |
| rt_device_read | 获取定时器当前值 |
2、FS配置
3、HWTIMER代码实现
int hwtimer_sample(void)
rt_err_t ret = RT_EOK;
rt_hwtimerval_t timeout_s;
rt_device_t hw_dev = RT_NULL;
rt_hwtimer_mode_t mode;
rt_uint32_t freq = 1875000; /* 1Mhz */
hw_dev = rt_device_find(HWTIMER_DEV_NAME);
if (hw_dev == RT_NULL)
rt_kprintf("hwtimer sample run failed! can't find %s device!\n", HWTIMER_DEV_NAME);
return -RT_ERROR;
ret = rt_device_open(hw_dev, RT_DEVICE_OFLAG_RDWR);
if (ret != RT_EOK)
rt_kprintf("open %s device failed!\n", HWTIMER_DEV_NAME);
return ret;
rt_device_set_rx_indicate(hw_dev, timeout_cb);
rt_device_control(hw_dev, HWTIMER_CTRL_FREQ_SET, &freq);
mode = HWTIMER_MODE_PERIOD;
ret = rt_device_control(hw_dev, HWTIMER_CTRL_MODE_SET, &mode);
if (ret != RT_EOK)
rt_kprintf("set mode failed! ret is :%d\n", ret);
return ret;
/* Example Set the timeout period of the timer */
timeout_s.sec = 1; /* secend */
timeout_s.usec = 0; /* microsecend */
if (rt_device_write(hw_dev, 0, &timeout_s, sizeof(timeout_s)) != sizeof(timeout_s))
rt_kprintf("set timeout value failed\n");
return -RT_ERROR;
/* read hwtimer value */
rt_device_read(hw_dev, 0, &timeout_s, sizeof(timeout_s));
rt_kprintf("Read: Sec = %d, Usec = %d\n", timeout_s.sec, timeout_s.usec);
return ret;
MSH_CMD_EXPORT(hwtimer_sample, hwtimer sample);
static rt_err_t timeout_cb(rt_device_t dev, rt_size_t size)
rt_kprintf("this is hwtimer timeout callback fucntion!\n");
rt_kprintf("tick is :%d !\n", rt_tick_get());
return RT_EOK;
3、测试验证
