龙芯技术社区
gjianw217
10年用户 688经验值
擅长:嵌入式技术 控制/MCU RF/无线
[2K系列]
官方,网盘openharmony的文件系统有问题(20240723)?
1 下载网盘中的文件系统
md5sum /mnt/hgfs/share/openharmony-rootfs.img
87d2d53b0ecfd95ca2457a4c52ee234a /mnt/hgfs/share/openharmony-rootfs.img
2 按照文档《广东龙芯2K0300蜂鸟板用户手册V0.99》将其烧录到TF卡上
3 启动打印如下错误
1)uboot仍用板卡原始的,
2)关键打印
开始:sending SIGSEGV to update_system for invalid read access from 0000000000000000
接着:Failed to set param 'const.build.characteristics' error:107
后面:sending SIGSEGV to xxxxxxxxxxx for invalid read access from 0000000000000000
最后
mmc1: card 0001 removed
3)完整打印
LoongArch Initializing ...
RAM(Cache AS RAM) Initializing ...
Lock Scache Done.
Copy spl code to locked scache...
Jump to board_init_f...
Enter board_init_f...
 _     __   __  _  _  ___  ___  __  _  _    /   ___  __  \
 |    |  | |  | |\ | | __ [__  |  | |\ |    |  | __ |  \ |
 |___ |__| |__| | \| |__] ___] |__| | \|    \  |__] |__/ /
============ddr4 init and training done!========
Trying to boot from BootSpace
U-boot start ...
U-Boot 2022.04-v2.1.0-00429-g33df0614 (Jun 17 2024 - 18:01:41 +0800), Build: jenkins-u-boot-2022.04-2k300-mini-dp-19
CPU:   LA264
Speed: Cpu @ 997 MHz/ Mem @ 800 MHz/ Bus @ 200 MHz
Model: loongson-2k300
Board: LS2K300-MINI-DP
DRAM:  512 MiB
512 MiB
Jump to board_init_r....
Core:  35 devices, 19 uclasses, devicetree: board
SF: Detected gd25q80 with page size 256 Bytes, erase size 4 KiB, total 1 MiB
bdinfo is in spi-flash
MMC:   mmc_init: -110, time 2180
emmc@0x16140000: 0 (eMMC), mmc@0x16148000: 1 (SD)
Loading Environment from SPIFlash... OK
frame buffer addr: 0x900000000dc00000
In:    serial
Out:   serial vidconsole
Err:   serial vidconsole
Net:   eth0: ethernet@0x16020000
************************** Notice **************************
Press c to enter u-boot console, m to enter boot menu
Bus ehci@0x16080000: USB EHCI 1.00
Bus ohci@0x16088000: USB OHCI 1.0
Bus otg@0x16040000: dwc2_usb otg@0x16040000: Core Release: 2.93a
USB DWC2
scanning bus ehci@0x16080000 for devices... 1 USB Device(s) found
scanning bus ohci@0x16088000 for devices... 1 USB Device(s) found
scanning bus otg@0x16040000 for devices... 1 USB Device(s) found
Autoboot in 0 seconds
--if mmc0 --fmt ext4 --sym /boot/uImage
--of ram --fmt  --sym
--extra 0x0
loading...
loaded&burning 8830259 bytes ...
load&burn 8830259 finished
## Booting kernel from Legacy Image at 9000000003000000 ...
   Image Name:   Linux-5.10.0.lsgd-ga7f3115b8c73
   Image Type:   LoongArch Linux Kernel Image (gzip compressed)
   Data Size:    8830195 Bytes = 8.4 MiB
   Load Address: 00200000
   Entry Point:  00e26be0
   Verifying Checksum ... OK
   Uncompressing Kernel Image
Warning: invalid device tree. Used linux default dtb
512 MiB
[    0.000000] Linux version 5.10.0.lsgd-ga7f3115b8c73 (loongson@loongson) (loongarch64-linux-gnu-gcc (LoongArch GNU toolchain rc1.3-1 (20240425)) 8.3.0, GNU ld (LoongArch GNU toolchain rc1.3-1 20240425) 2.31.1.20190122) #1 PREEMPT Mon Jun 17 17:33:02 CST 2024
[    0.000000] Primary instruction cache 32kB, 4-way, VIPT, linesize 64 bytes.
[    0.000000] Primary data cache 32kB, 4-way, VIPT, no aliases, linesize 64 bytes
[    0.000000] Unified victim cache 1024kB 16-way, linesize 64 bytes.
[    0.000000] Unified secondary cache 0kB direct mapped, linesize 1 bytes.
[    0.000000] 64-bit Loongson Processor probed (LA264 Core)
[    0.000000] CPU0 revision is: 0014a030 (Loongson-64bit)
[    0.000000] FPU0 revision is: 00000000
[    0.000000] cmdline:console=ttyS0,115200 root=/dev/mmcblk1p1 rw noinitrd init=/linuxrc rootfstype=ext4 rootwait mtdparts=spi0.0:924k(uboot),32k(uboot_env),4k(bdinfo),64k(dtb) fbcon=rotate:0 panel=default
[    0.000000] BPI1001 with boot flags 2.
[    0.000000] convert legacy mem map to new mem map.
[    0.000000] SMBIOS 3.0 present.
[    0.000000] DMI: Loongson LS2K300/LS2K300-MINI-DP, BIOS 2022.04-v2.1.0-00429-g33df0614 04/01/2022
[    0.000000] CpuClock = 0
[    0.000000] The BIOS Version: 2022.04-v2.1.0-00429-g33df0614
[    0.000000] Ext list mem info is ignored!
[    0.000000] Reserved memory: created CMA memory pool at 0x000000009c000000, size 32 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] earlycon: ns16550a0 at MMIO 0x0000000016100000 (options '115200n8')
[    0.000000] printk: bootconsole [ns16550a0] enabled
[    0.000000]  - disabling initrd
[    0.000000] start_pfn=0x80, end_pfn=0x28000, num_physpages:0x7b80
[    0.000000] Wasting 8192 bytes for tracking 128 unused pages
[    0.000000] software IO TLB: mapped [mem 0x00000000017bc000-0x00000000057bc000] (64MB)
[    0.000000] Zone ranges:
[    0.000000]   DMA32    [mem 0x0000000000200000-0x00000000ffffffff]
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000200000-0x000000000effffff]
[    0.000000]   node   0: [mem 0x0000000090000000-0x000000009fffffff]
[    0.000000] Zeroed struct page in unavailable ranges: 1152 pages
[    0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x000000009fffffff]
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 31492
[    0.000000] Kernel command line: earlycon console=ttyS0,115200 root=/dev/mmcblk1p1 rw noinitrd init=/linuxrc rootfstype=ext4 rootwait mtdparts=spi0.0:924k(uboot),32k(uboot_env),4k(bdinfo),64k(dtb) fbcon=rotate:0 panel=default fbcon=logo-pos:center fbcon=logo-count:1
[    0.000000] Dentry cache hash table entries: 65536 (order: 5, 524288 bytes, linear)
[    0.000000] Inode-cache hash table entries: 32768 (order: 4, 262144 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 351024K/505856K available (12493K kernel code, 4787K rwdata, 3716K rodata, 352K init, 865K bss, 122064K reserved, 32768K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies.
[    0.000000] NR_IRQS: 576, nr_irqs: 576, preallocated irqs: 16
[    0.000000] random: get_random_bytes called from start_kernel+0x35c/0x4f0 with crng_init=0
[    0.000000] Constant clock event device register
[    0.000000] clocksource: Constant: mask: 0xffffffffffffffff max_cycles: 0x3759f22983, max_idle_ns: 881590413697 ns
[    0.000006] sched_clock: 64 bits at 120MHz, resolution 8ns, wraps every 4398046511102ns
[    0.008084] Constant clock source device register
[    0.012988] Console: colour dummy device 80x25
[    0.017536] Calibrating delay loop (skipped), value calculated using timer frequency.. 240.00 BogoMIPS (lpj=120000)
[    0.028089] pid_max: default: 32768 minimum: 301
[    0.032842] LSM: Security Framework initializing
[    0.037533] Yama: becoming mindful.
[    0.041163] Mount-cache hash table entries: 2048 (order: 0, 16384 bytes, linear)
[    0.048660] Mountpoint-cache hash table entries: 2048 (order: 0, 16384 bytes, linear)
[    0.058393] Performance counters: loongarch/loongson64 PMU enabled, 4 64-bit counters available to each CPU.
[    0.068479] rcu: Hierarchical SRCU implementation.
[    0.073817] devtmpfs: initialized
[    0.081273] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[    0.091157] futex hash table entries: 256 (order: -2, 6144 bytes, linear)
[    0.098547] pinctrl core: initialized pinctrl subsystem
[    0.104863] NET: Registered protocol family 16
[    0.110263] audit: initializing netlink subsys (disabled)
[    0.116524] thermal_sys: Registered thermal governor 'step_wise'
[    0.117343] audit: type=2000 audit(0.027:1): state=initialized audit_enabled=0 res=1
[    0.152159] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.362536] random: fast init done
[    1.919668] gpio-lsirq 16104000.gpio: register irqnum=107, vhwirq-base=128, rirq-base=78
[    1.929065] loongson-lsia-dma 1612c000.iodma: DMA driver registered
[    1.935771] vgaarb: loaded
[    1.938836] SCSI subsystem initialized
[    1.943073] ls-spi 16010000.spi: controller is unqueued, this is deprecated
[    1.950736] usbcore: registered new interface driver usbfs
[    1.956336] usbcore: registered new interface driver hub
[    1.961764] usbcore: registered new device driver usb
[    1.967045] mc: Linux media interface: v0.10
[    1.971391] videodev: Linux video capture interface: v2.00
[    1.976994] pps_core: LinuxPPS API ver. 1 registered
[    1.982011] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.991258] PTP clock support registered
[    1.995510] Advanced Linux Sound Architecture Driver Initialized.
[    2.003160] clocksource: Switched to clocksource Constant
[    2.008976] VFS: Disk quotas dquot_6.6.0
[    2.012998] VFS: Dquot-cache hash table entries: 2048 (order 0, 16384 bytes)
[    2.020244] FS-Cache: Loaded
[    2.029377] NET: Registered protocol family 2
[    2.034552] tcp_listen_portaddr_hash hash table entries: 1024 (order: 0, 16384 bytes, linear)
[    2.043214] TCP established hash table entries: 4096 (order: 1, 32768 bytes, linear)
[    2.051065] TCP bind hash table entries: 4096 (order: 1, 32768 bytes, linear)
[    2.058318] TCP: Hash tables configured (established 4096 bind 4096)
[    2.064935] UDP hash table entries: 512 (order: 0, 16384 bytes, linear)
[    2.071665] UDP-Lite hash table entries: 512 (order: 0, 16384 bytes, linear)
[    2.078992] NET: Registered protocol family 1
[    2.083969] RPC: Registered named UNIX socket transport module.
[    2.089985] RPC: Registered udp transport module.
[    2.094740] RPC: Registered tcp transport module.
[    2.099507] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    2.108719] Initialise system trusted keyrings
[    2.113404] workingset: timestamp_bits=46 max_order=15 bucket_order=0
[    2.124896] zbud: loaded
[    2.129021] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    2.135881] NFS: Registering the id_resolver key type
[    2.141052] Key type id_resolver registered
[    2.145281] Key type id_legacy registered
[    2.149414] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    2.156191] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    2.163903] Key type asymmetric registered
[    2.168059] Asymmetric key parser 'x509' registered
[    2.173222] io scheduler mq-deadline registered
[    2.177817] io scheduler kyber registered
[    2.181981] io scheduler bfq registered
[    2.186448] pinctrl-single 16000490.pinmux: 128 pins, size 32
[    2.192716] ls-pwm 1611b000.pwm: pwm->clock_frequency=200000000
[    2.198977] ls-pwm 1611b010.pwm: pwm->clock_frequency=200000000
[    2.205233] ls-pwm 1611b020.pwm: pwm->clock_frequency=200000000
[    2.211433] ls-pwm 1611b030.pwm: pwm->clock_frequency=200000000
[    2.220458] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[    2.231014] printk: console [ttyS0] disabled
[    2.235453] 16100000.serial: ttyS0 at MMIO 0x16100000 (irq = 16, base_baud = 12500000) is a 16550A
[    2.244593] printk: console [ttyS0] enabled
[    2.253045] printk: bootconsole [ns16550a0] disabled
[    2.263715] 16100400.serial: ttyS1 at MMIO 0x16100400 (irq = 17, base_baud = 12500000) is a 16550A
[    2.273431] 16100800.serial: ttyS2 at MMIO 0x16100800 (irq = 18, base_baud = 12500000) is a 16550A
[    2.283094] 16100c00.serial: ttyS3 at MMIO 0x16100c00 (irq = 18, base_baud = 12500000) is a 16550A
[    2.292956] [drm] LSK0300 DC found
[    2.296641] lsdc 16090000.dc: [drm] Has OF graph support
[    2.313238] brd: module loaded
[    2.325862] loop: module loaded
[    2.330099] SPI-UID: 32:33:37:35:32:17:00:63:00:14:50:ff:ff:ff:ff:ff
[    2.336636] spi-nor spi0.0: gd25q80 (1024 Kbytes)
[    2.341398] 4 cmdlinepart partitions found on MTD device spi0.0
[    2.347347] Creating 4 MTD partitions on "spi0.0":
[    2.352167] 0x000000000000-0x0000000e7000 : "uboot"
[    2.361722] 0x0000000e7000-0x0000000ef000 : "uboot_env"
[    2.371670] 0x0000000ef000-0x0000000f0000 : "bdinfo"
[    2.380703] 0x0000000f0000-0x000000100000 : "dtb"
[    2.390970] libphy: Fixed MDIO Bus: probed
[    2.395587] CAN device driver interface
[    2.399628] lbx----->ctucan_platform_probe,76
[    2.404070] lscanfd 16110000.can: probe addr=ffffff8012d08000,irq=19 can_clk=200000000 ntxbufs=8 res->start=16110000
[    2.414732] lscanfd 16110000.can: lbx----device id :babe
[    2.420679] lbx----->ctucan_platform_probe,76
[    2.425116] lscanfd 16110400.can: probe addr=ffffff8012d10400,irq=20 can_clk=200000000 ntxbufs=8 res->start=16110400
[    2.435788] lscanfd 16110400.can: lbx----device id :babe
[    2.441649] lbx----->ctucan_platform_probe,76
[    2.446075] lscanfd 16110800.can: probe addr=ffffff8012d18800,irq=21 can_clk=200000000 ntxbufs=8 res->start=16110800
[    2.456754] lscanfd 16110800.can: lbx----device id :babe
[    2.462619] lbx----->ctucan_platform_probe,76
[    2.467046] lscanfd 16110c00.can: probe addr=ffffff8012d20c00,irq=22 can_clk=200000000 ntxbufs=8 res->start=16110c00
[    2.477712] lscanfd 16110c00.can: lbx----device id :babe
[    2.483883] stmmaceth 16020000.ethernet: IRQ eth_wake_irq not found
[    2.490243] stmmaceth 16020000.ethernet: IRQ eth_lpi not found
[    2.496233] stmmaceth 16020000.ethernet: Cannot get CSR clock
[    2.502017] stmmaceth 16020000.ethernet: PTP uses main clock
[    2.507709] stmmaceth 16020000.ethernet: no reset control found
[    2.513934] stmmaceth 16020000.ethernet: User ID: 0x11, Synopsys ID: 0x37
[    2.520774] stmmaceth 16020000.ethernet:     DWMAC1000
[    2.525679] stmmaceth 16020000.ethernet: DMA HW capability register supported
[    2.532847] stmmaceth 16020000.ethernet: RX Checksum Offload Engine supported
[    2.540015] stmmaceth 16020000.ethernet: COE Type 2
[    2.544916] stmmaceth 16020000.ethernet: TX Checksum insertion supported
[    2.551647] stmmaceth 16020000.ethernet: Wake-Up On Lan supported
[    2.557830] stmmaceth 16020000.ethernet: Enhanced/Alternate descriptors
[    2.564478] stmmaceth 16020000.ethernet: Enabled extended descriptors
[    2.570950] stmmaceth 16020000.ethernet: Ring mode enabled
[    2.576460] stmmaceth 16020000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    2.584160] stmmaceth 16020000.ethernet: device MAC address 0e:e8:b8:f7:e6:b0
[    2.591775] libphy: stmmac: probed
[    2.597341] PPP generic driver version 2.4.2
[    2.601869] PPP BSD Compression module registered
[    2.606625] PPP Deflate Compression module registered
[    2.611730] PPP MPPE Compression module registered
[    2.616562] NET: Registered protocol family 24
[    2.621382] dwc2 16040000.otg: supply vusb_d not found, using dummy regulator
[    2.628732] dwc2 16040000.otg: supply vusb_a not found, using dummy regulator
[    2.845178] dwc2 16040000.otg: dwc2_check_params: Invalid parameter lpm=1
[    2.852003] dwc2 16040000.otg: dwc2_check_params: Invalid parameter lpm_clock_gating=1
[    2.859957] dwc2 16040000.otg: dwc2_check_params: Invalid parameter besl=1
[    2.866863] dwc2 16040000.otg: dwc2_check_params: Invalid parameter hird_threshold_en=1
[    2.874906] dwc2 16040000.otg: dwc2_check_params: Invalid parameter g_rx_fifo_size=2048
[    2.882945] dwc2 16040000.otg: dwc2_check_params: Invalid parameter g_np_tx_fifo_size=1024
[    2.891248] dwc2 16040000.otg: dwc2_check_param_tx_fifo_sizes: Invalid parameter g_tx_fifo_size[1]=312
[    2.900596] dwc2 16040000.otg: dwc2_check_param_tx_fifo_sizes: Invalid parameter g_tx_fifo_size[2]=312
[    2.909963] dwc2 16040000.otg: EPs: 7, dedicated fifos, 3016 entries in SPRAM
[    2.917559] dwc2 16040000.otg: DWC OTG Controller
[    2.922309] dwc2 16040000.otg: new USB bus registered, assigned bus number 1
[    2.929418] dwc2 16040000.otg: irq 48, io mem 0x16040000
[    2.935412] hub 1-0:1.0: USB hub found
[    2.939216] hub 1-0:1.0: 1 port detected
[    2.944134] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.950701] ehci-pci: EHCI PCI platform driver
[    2.955233] ehci-platform: EHCI generic platform driver
[    2.960716] ehci-platform 16080000.ehci: EHCI Host Controller
[    2.966606] ehci-platform 16080000.ehci: new USB bus registered, assigned bus number 2
[    2.974767] ehci-platform 16080000.ehci: irq 46, io mem 0x16080000
[    2.987175] ehci-platform 16080000.ehci: USB 2.0 started, EHCI 1.00
[    2.993990] hub 2-0:1.0: USB hub found
[    2.997807] hub 2-0:1.0: 1 port detected
[    3.002132] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    3.008359] ohci-pci: OHCI PCI platform driver
[    3.012887] ohci-platform: OHCI generic platform driver
[    3.018339] ohci-platform 16088000.ohci: Generic Platform OHCI controller
[    3.025301] ohci-platform 16088000.ohci: new USB bus registered, assigned bus number 3
[    3.033363] ohci-platform 16088000.ohci: irq 47, io mem 0x16088000
[    3.095676] hub 3-0:1.0: USB hub found
[    3.099487] hub 3-0:1.0: 1 port detected
[    3.103884] usbcore: registered new interface driver cdc_acm
[    3.110107] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    3.118235] usbcore: registered new interface driver usb-storage
[    3.124396] usbcore: registered new interface driver option
[    3.130023] usbserial: USB Serial support registered for GSM modem (1-port)
[    3.137296] using random self ethernet address
[    3.141769] using random host ethernet address
[    3.146685] usb0: HOST MAC be:6a:0d:1a:1b:e5
[    3.151043] usb0: MAC 8a:95:d6:f3:dd:08
[    3.154930] using random self ethernet address
[    3.159397] using random host ethernet address
[    3.163921] g_ether gadget: Ethernet Gadget, version: Memorial Day 2008
[    3.170570] g_ether gadget: g_ether ready
[    3.174604] dwc2 16040000.otg: bound driver g_ether
[    3.179804] mousedev: PS/2 mouse device common for all mice
[    3.185741] <<-GTP-INFO->> GTP driver installing....
[    3.193199] rtc rtc0: invalid alarm value: 1919-05-23T05:61:26
[    3.199428] ls2x-rtc 16128000.rtc: registered as rtc0
[    3.204945] ls2x-rtc 16128000.rtc: setting system clock to 2022-05-01T00:02:07 UTC (1651363327)
[    3.214345] i2c /dev entries driver
[    3.219105] Goodix-TS 1-0014: supply AVDD28 not found, using dummy regulator
[    3.226347] Goodix-TS 1-0014: supply VDDIO not found, using dummy regulator
[    3.233542] Goodix-TS 1-0014: i2c test failed attempt 1: -5
[    3.260194] Goodix-TS 1-0014: i2c test failed attempt 2: -5
[    3.287162] Goodix-TS 1-0014: I2C communication failure: -5
[    3.292910] Goodix-TS: probe of 1-0014 failed with error -5
[    3.299865] usbcore: registered new interface driver uvcvideo
[    3.305707] USB Video Class driver (1.1.1)
[    3.309838] gspca_main: v2.14.0 registered
[    3.314021] usbcore: registered new interface driver ov519
[    3.319577] usbcore: registered new interface driver ov534
[    3.325124] usbcore: registered new interface driver ov534_9
[    3.330846] usbcore: registered new interface driver spca500
[    3.336579] usbcore: registered new interface driver spca501
[    3.342299] usbcore: registered new interface driver spca505
[    3.348017] usbcore: registered new interface driver spca506
[    3.353737] usbcore: registered new interface driver spca508
[    3.359458] usbcore: registered new interface driver spca561
[    3.365184] usbcore: registered new interface driver spca1528
[    3.371007] usbcore: registered new interface driver gspca_zc3xx
[    3.377075] usbcore: registered new interface driver usbtv
[    3.382585] Driver for 1-wire Dallas network protocol.
[    3.389171] ls2k_sdio 16140000.sdio: Use exclusive dma engine.
[    3.625374] ls2k_sdio 16148000.sdio: Use exclusive dma engine.
[    3.638281] ls2k_sdio 16148000.sdio: Got CD GPIO
[    4.070884] hid: raw HID events driver (C) Jiri Kosina
[    4.080330] usbcore: registered new interface driver usbhid
[    4.089153] usbhid: USB HID core driver
[    4.102192] ls2k300_adc 1611c000.adc: ADC Device registered successfully
[    4.117709] xt_time: kernel timezone is -0000
[    4.157692] ipt_CLUSTERIP: ClusterIP Version 0.8 loaded successfully
[    4.164246] Initializing XFRM netlink socket
[    4.175684] NET: Registered protocol family 10
[    4.192820] Segment Routing with IPv6
[    5.346169] mmc1: new SDHC card at address 0001
[    5.359416] mmcblk1: mmc1:0001 SD 7.23 GiB
[    5.378848] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    5.390912] NET: Registered protocol family 17
[    5.400282] NET: Registered protocol family 15
[    5.410900]  mmcblk1: p1
[    5.415323] can: controller area network core
[    5.423291] NET: Registered protocol family 29
[    5.432159] can: raw protocol
[    5.435144] can: broadcast manager protocol
[    5.446159] can: netlink gateway - max_hops=1
[    5.455332] 8021q: 802.1Q VLAN Support v1.8
[    5.468273] NET: Registered protocol family 21
[    5.476184] Key type dns_resolver registered
[    5.484611] registered taskstats version 1
[    5.492162] Loading compiled-in X.509 certificates
[    5.502941] zswap: loaded using pool zstd/zbud
[    5.545358] ls-spi 16018000.spi: controller is unqueued, this is deprecated
[    5.552761] mmc0: new high speed MMC card at address 0001
[    5.558830] ls-spi-io 1610c000.spi: controller is unqueued, this is deprecated
[    5.566699] mmcblk0: mmc0:0001 08A391 7.28 GiB
[    5.571462] mmcblk0boot0: mmc0:0001 08A391 partition 1 4.00 MiB
[    5.578132] [drm] LSK0300 DC found
[    5.581858] lsdc 16090000.dc: [drm] Has OF graph support
[    5.587481] mmcblk0boot1: mmc0:0001 08A391 partition 2 4.00 MiB
[    5.593482] lsdc 16090000.dc: [drm] output-0 is a DPI panel
[    5.599157] lsdc 16090000.dc: [drm] bridge-0 attached to encoder-0
[    5.605367] lsdc 16090000.dc: [drm] number of outputs: 1
[    5.610757] lsdc 16090000.dc: [drm] display pipe 0 initialized
[    5.619287] [drm] Initialized lsdc 1.0.0 20200701 for 16090000.dc on minor 0
[    5.637558] Console: switching to colour frame buffer device 100x30
[    5.646046] lsdc 16090000.dc: [drm] fb0: lsdcdrmfb frame buffer device
[    5.755179] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    5.915451] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    5.922170] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    5.930865] ALSA device list:
[    5.933866]   No soundcards found.
[    5.937308] cfg80211: failed to load regulatory.db
[    5.965266] EXT4-fs (mmcblk1p1): mounted filesystem with ordered data mode. Opts: (null)
[    5.973458] ext4 filesystem being mounted at /root supports timestamps until 2038 (0x7fffffff)
[    5.982203] VFS: Mounted root (ext4 filesystem) on device 179:1.
[    6.005320] devtmpfs: mounted
[    6.009080] Freeing unused kernel memory: 352K
[    6.013560] This architecture does not have kernel memory protection.
[    6.020052] Run /linuxrc as init process
 __
\ \ \        ___     ___     ___   [    6.353085] [pid=80][Init][INFO][init_adapter.c:91]ExecuteRcs, child process id 80.
[    6.559984] random: crng init done
   __     ____    ___     ___
 \ \ \  __  / __ \  / __ \ /  _  \  / _  \  / ,__\  / __ \ /  _  \
  \ \ \L\ \/\ \L\ \/\ \L\ \/\ \/\ \/\ \L\ \/\__, `\/\ \L\ \/\ \/\ \
   \ \____/\ \____/\ \____/\ \_\ \_\ \____ \/\____/\ \____/\ \_\ \_\
    \/___/  \/___/  \/___/  \/_/\/_/\/___L\ \/___/  \/___/  \/_/\/_/
                                      /\____/
                                      \_/__/
[RCS]: /etc/init.d/S00devs
mknod: /dev/console: File exists
mknod: /dev/ttyS0: File exists
mknod: /dev/null: File exists
[RCS]: /etc/init.d/S01mdev
[RCS]: /etc/init.d/S02_check_boot
[    6.978897] do_page_fault(): sending SIGSEGV to update_system for invalid read access from 0000000000000000
[    6.988729] era = 0000007ff1cfc92c in libc-2.28.so[7ff1c70000+17c000]
[    6.995221] ra  = 000000012000558c in update_system[120000000+c000]
Signal 11
[RCS]: /etc/init.d/S03resizerootfs
Rootfs Resizing...
Partition resizing...
analy_part_type
read_disk_size
analy_swap_size
analy_part_info
parted_root_part
resize2fs 1.44.5 (15-Dec-2018)
Filesystem at /d[    7.838901] EXT4-fs (mmcblk1p1): resizing filesystem from 523264 to 7576576 blocks
ev/mmcblk1p1 is mounted on /; on-line resizing required
old_desc_blocks = 4, new_desc_blocks = 58
[   18.947867] EXT4-fs (mmcblk1p1): resized to 1572865 blocks
[   29.968643] EXT4-fs (mmcblk1p1): resized to 2621441 blocks
[   40.465487] EXT4-fs (mmcblk1p1): resized to 3407873 blocks
[   50.693298] EXT4-fs (mmcblk1p1): resized to 4325377 blocks
[   61.214793] EXT4-fs (mmcblk1p1): resized to 5242881 blocks
[   71.873248] EXT4-fs (mmcblk1p1): resized to 6160385 blocks
[   83.119135] EXT4-fs (mmcblk1p1): resized to 6815745 blocks
[   91.530043] EXT4-fs (mmcblk1p1): resized filesystem to 7576576
The filesystem on /dev/mmcblk1p1 is now 7576576 (1k) blocks long.
fdisk_other_part
mkfs_other_part
gen_fstab
data_partition_init
[RCS]: /etc/init.d/S30dbus
Starting system message bus: done
[RCS]: /etc/init.d/S50sshd
ssh-keygen: generating new host keys: RSA DSA ECDSA ED25519
Starting sshd: OK
[RCS]: /etc/init.d/S70vsftpd
Starting vsftpd: OK
[RCS]: /etc/init.d/S80network
[  104.866273] stmmaceth 16020000.ethernet eth0: PHY [stmmac-0:00] driver [YT8531 Gigabit Ethernet] (irq=POLL)
[  104.886770] stmmaceth 16020000.ethernet eth0: No Safety Features support found
[  104.894039] stmmaceth 16020000.ethernet eth0: IEEE 1588-2008 Advanced Timestamp supported
[  104.902481] stmmaceth 16020000.ethernet eth0: registered PTP clock
[  104.908981] stmmaceth 16020000.ethernet eth0: configuring for phy/rgmii link mode
[RCS]: /etc/init.d/S82ohos
ohos_service_start
chmod: /dev/hilog: No such file or directory
[  104.971741] [pid=1][Init][INFO][init_group_manager.c:201]boot start device.boot.group
[  104.971815] [pid=1][PARAM][INFO][param_service.c:393]InitParamService pipe: /dev/unix/socket/paramservice.
[  104.980054] [pid=1][PARAM][INFO][param_base.c:204]Max selinux label 1 1
[  104.990197] [pid=1][PARAM][INFO][param_server.c:422]Load default parameters from /system/etc/param/ohos_const.
[  105.002343] [pid=1][PARAM][INFO][param_server.c:422]Load default parameters from /vendor/etc/param.
[  105.016495] [pid=1][PARAM][INFO][param_server.c:422]Load default parameters from /system/etc/param.
[  105.027063] [pid=1][PARAM][ERROR][param_server.c:393]Failed to set param 'const.build.characteristics' error:107
[  105.036234] [pid=1][PARAM][ERROR][param_server.c:393]Failed to set param 'const.product.model' error:107
[  105.046623] [pid=1][PARAM][ERROR][param_server.c:393]Failed to set param 'const.product.name' error:107
hilog fd failed No such file or directory
# [  105.056352] [pid=1][PARAM][ERROR][param_server.c:393]Failed to set param 'const.software.model' error:107
[  106.007906] do_page_fault(): sending SIGSEGV to devattest_servi for invalid read access from 0000000000000000
[  106.027798] era = 0000007ff12ae630 in libsamgr.so[7ff12a4000+10000]
[  106.034122] ra  = 0000007ff12ae630 in libsamgr.so[7ff12a4000+10000]
[  106.157016] do_page_fault(): sending SIGSEGV to wms_server for invalid write access to 0000007ff3074000
[  106.174975] era = 0000007ff3496534 in libdisplay_layer.so[7ff3494000+4000]
[  106.190534] ra  = 0000007ff3496500 in libdisplay_layer.so[7ff3494000+4000]
Error: init_mtd_info_open_fd: /dev/mtd2 open failed! (13) 12 12
[  106.707103] do_page_fault(): sending SIGSEGV to bundle_daemon for invalid read access from 0000000000000000
[  106.716944] era = 0000007ff11d2630 in libsamgr.so[7ff11c8000+10000]
[  106.723281] ra  = 0000007ff11d2630 in libsamgr.so[7ff11c8000+10000]
[  106.917631] do_page_fault(): sending SIGSEGV to huks_server for invalid read access from 0000000000000000
[  106.927573] era = 0000007ff15d6630 in libsamgr.so[7ff15cc000+10000]
[  106.933899] ra  = 0000007ff15d6630 in libsamgr.so[7ff15cc000+10000]
[  107.047847] do_page_fault(): sending SIGSEGV to huks_server for invalid read access from 0000000000000000
[  107.059274] era = 0000007ff26be630 in libsamgr.so[7ff26b4000+10000]
[  107.065598] ra  = 0000007ff26be630 in libsamgr.so[7ff26b4000+10000]
Error: init_mtd_info_open_fd: /dev/mtd2 open fai[  107.200643] do_page_fault(): sending SIGSEGV to huks_server for invalid read access from 0000000000000000
[  107.210635] era = 0000007ff3312630 in libsamgr.so[7ff3308000+10000]
[  107.218432] ra  = 0000007ff3312630 in libsamgr.so[7ff3308000+10000]
Error: init_mtd_info_open_fd: /d[  107.295392] do_page_fault(): sending SIGSEGV to huks_server for invalid read access from 0000000000000000
ev/mtd2 open fai[  107.306358] era = 0000007ff3bde630 in libsamgr.so[7ff3bd4000+10000]
[  107.313798] ra  = 0000007ff3bde630 in libsamgr.so[7ff3bd4000+10000]
[  107.328276] do_page_fault(): sending SIGSEGV to foundation for invalid read access from 0000000000000000
[  107.337831] era = 0000007fefc4e630 in libsamgr.so[7fefc44000+10000]
[  107.344157] ra  = 0000007fefc4e630 in libsamgr.so[7fefc44000+10000]
[  108.112501] mmc1: card 0001 removed
回帖(2)
jf_38522704
2024-8-7 19:31:34
建议先更新u-boot
1 举报
gjianw217
2024-8-27 14:38:02
升级u-boot,重新设置环境变量,问题仍存在
