FPGA|CPLD|ASICwilliam hill官网
薄迪
12年用户 1313经验值
擅长:583626
FPGA 1602动态显示办法
我只会FPGA做静态显示,但是不知道该怎样动态显示。求解决
是不是在模块内设置一个变量啊,然后那个变量怎么变化,然后1602上面也变化。“电压值 = **.**”
已退回100积分
回帖(6)
馨雨
2013-12-28 12:29:40
{:6:}
h1654155733.5974
2013-12-28 16:10:06
电子科大的妹子还是哥哥啊??
薄迪
2013-12-29 15:21:14
引用: weihuahua123 发表于 2013-12-28 16:10
电子科大的妹子还是哥哥啊??
额....哥.......
格古落
2015-7-25 17:49:41
Verilog 代码
下面代码功能主要是完成一个0-99s的计数器,动态刷新。主要是在LCD1602上动态显示:“Cnt:00”。
module lcd1602_driver(input clk,      //50M
                     input rst_n,
                     output lcd_p,    //Backlight Source +
                     output lcd_n,    //Backlight Source -
                     output reg lcd_rs,    //0:write order; 1:write data
                     output lcd_rw,        //0:write data;  1:read data
                     output reg lcd_en,    //negedge
                     output reg [7:0] lcd_data);
//--------------------lcd1602 order----------------------------
parameter    Mode_Set    =  8'h31,
             Cursor_Set  =  8'h0c,
             Address_Set =  8'h06,
             Clear_Set   =  8'h01;
/****************************LCD1602 Display Data****************************/
wire [7:0] data0,data1; //counter data
wire [7:0] addr;   //write address
//---------------------------------1s counter-----------------------------------
reg [31:0] cnt1;
reg [7:0] data_r0,data_r1;
always@(posedge clk or negedge rst_n)
begin
    if(!rst_n)
        begin
            cnt1 <= 1'b0;
            data_r0 <= 1'b0;
            data_r1 <= 1'b0;
        end
    else if(cnt1==32'd50000000)
        begin
            if(data_r0==8'd9)
                begin
                    data_r0 <= 1'b0;
                    if(data_r1==8'd9)
                        data_r1 <= 1'b0;
                    else
                        data_r1 <= data_r1 + 1'b1;
                end
            else
                data_r0 <= data_r0 + 1'b1;
            cnt1 <= 1'b0;
        end
    else
        cnt1 <= cnt1 + 1'b1;
end
assign data0 = 8'h30 + data_r0 ;
assign data1 = 8'h30 + data_r1 ;
//-------------------address------------------
assign addr = 8'h80;
/****************************LCD1602 Driver****************************/
//-----------------------lcd1602 clk_en---------------------
reg [31:0] cnt;
reg lcd_clk_en;
always @(posedge clk or negedge rst_n)
begin
    if(!rst_n)
        begin
            cnt <= 1'b0;
            lcd_clk_en <= 1'b0;
        end
    else if(cnt == 32'h24999)   //500us
        begin
            lcd_clk_en <= 1'b1;
            cnt <= 1'b0;
        end
    else
        begin
            cnt <= cnt + 1'b1;
            lcd_clk_en <= 1'b0;
        end
end
//-----------------------lcd1602 display state-------------------------------------------
reg [4:0] state;
begin
    if(!rst_n)
        begin
            state <= 1'b0;
            lcd_rs <= 1'b0;
            lcd_en <= 1'b0;
            lcd_data <= 1'b0;
        end
    else if(lcd_clk_en)
        begin
            case(state)
                //-------------------init_state---------------------
                5'd0: begin
                        lcd_rs <= 1'b0;
                        lcd_en <= 1'b1;
                        lcd_data <= Mode_Set;
                        state <= state + 1'd1;
                        end
                5'd1: begin
                        lcd_en <= 1'b0;
                        end
                5'd2: begin
                        lcd_rs <= 1'b0;
                        lcd_en <= 1'b1;
                        lcd_data <= Cursor_Set;
                        end
                5'd3: begin
                        lcd_en <= 1'b0;
                        end
                5'd4: begin
                        lcd_rs <= 1'b0;
                        lcd_en <= 1'b1;
                        lcd_data <= Address_Set;
                        end
                5'd5: begin
                        lcd_en <= 1'b0;
                        end
                5'd6: begin
                        lcd_rs <= 1'b0;
                        lcd_en <= 1'b1;
                        lcd_data <= Clear_Set;
                        end
                5'd7: begin
                        lcd_en <= 1'b0;
                        end
                //--------------------work state--------------------
                5'd8: begin
                        lcd_rs <= 1'b0;
                        lcd_en <= 1'b1;
                        lcd_data <= addr;   //write addr
                        end
                5'd9: begin
                        lcd_en <= 1'b0;
                        end
                5'd10: begin
                        lcd_rs <= 1'b1;
                        lcd_en <= 1'b1;
                        lcd_data <= "C";   //write data
                         end
                5'd11: begin
                        lcd_en <= 1'b0;
                        end
                5'd12: begin
                        lcd_rs <= 1'b1;
                        lcd_en <= 1'b1;
                        lcd_data <= "n";   //write data
                         end
                5'd13: begin
                        lcd_en <= 1'b0;
                        end
                5'd14: begin
                        lcd_rs <= 1'b1;
                        lcd_en <= 1'b1;
                        lcd_data <= "t";   //write data
                         end
                5'd15: begin
                        lcd_en <= 1'b0;
                        end
                5'd16: begin
                        lcd_rs <= 1'b1;
                        lcd_en <= 1'b1;
                        lcd_data <= ":";   //write data
                         end
                5'd17: begin
                        lcd_en <= 1'b0;
                        end
                5'd18: begin
                        lcd_rs <= 1'b1;
                        lcd_en <= 1'b1;
                        lcd_data <= data1;   //write data: tens digit
                         end
                5'd19: begin
                        lcd_en <= 1'b0;
                         end
                5'd20: begin
                        lcd_rs <= 1'b1;
                        lcd_en <= 1'b1;
                        lcd_data <= data0;   //write data: single digit
                        end
                5'd21: begin
                        lcd_en <= 1'b0;
                        state <= 5'd8;
                       end
                default: state <= 5'bxxxxx;
            endcase
        end
end
assign lcd_rw = 1'b0;   //only write
//------------------backlight driver----------------
assign lcd_n = 1'b0;
assign lcd_p = 1'b1;
endmodule
楼主可以看看这篇帖子:http://blog.chinaaet.com/detail/35557
lv0817
2015-8-12 19:46:23
先来认真学习一下。。。。。
matipo26
2015-8-31 12:16:49
应该注意两个方面就好了,一个是要显示的数据或者字符,另一个是刷新频率吧,希望可以对你有帮助
