物联网技术
陈兵
11年用户 82经验值
擅长:95724
[资料]
Android Socket通信 客户端
package com.michael.chatclient;
import java.io.DataInputStream;
import java.io.DataOutputStream;
import java.io.IOException;
import java.net.Socket;
import java.sql.Date;
import java.text.SimpleDateFormat;
import android.os.Bundle;
import android.os.Handler;
import android.os.Message;
import android.app.Activity;
import android.view.Menu;
import android.view.View;
import android.widget.Button;
import android.widget.EditText;
import android.widget.Toast;
public class MainActivity extends Activity implements Runnable{
        private EditText usernameEdit;
        private EditText ipEdit;
        private EditText historyEdit;
        private EditText messageEdit;
        private Button loginButton;
        private Button sendButton;
        private Button leaveButton;
    private String username,ip,chat_txt,chat_in;
    public static final int PORT = 8888;
    Socket socket;
    Thread thread;
    DataInputStream in;
    DataOutputStream out;
    boolean flag = false;
        @Override
        protected void onCreate(Bundle savedInstanceState) {
                super.onCreate(savedInstanceState);
                setContentView(R.layout.activity_main);
                usernameEdit = (EditText) findViewById(R.id.username1);
                ipEdit = (EditText) findViewById(R.id.ip);
                historyEdit = (EditText) findViewById(R.id.history);
                messageEdit = (EditText) findViewById(R.id.message);
                loginButton = (Button) findViewById(R.id.LoginButton);
                leaveButton = (Button) findViewById(R.id.LeaveButton);
                sendButton = (Button) findViewById(R.id.SendButton);
                //绑定监听器
                loginButton.setOnClickListener(listener);
                leaveButton.setOnClickListener(listener);
                sendButton.setOnClickListener(listener);
        View.OnClickListener listener = new View.OnClickListener(){
                @Override
                public void onClick(View arg0) {
                        // TODO Auto-generated method stub
                        switch (arg0.getId()){     //进入聊天室按钮的处理
                        case R.id.LoginButton:
                                if(flag == true){
                                        Toast.makeText(MainActivity.this,""
                                                        + "已经登陆过了!",Toast.LENGTH_SHORT).show();
                                        return;
                    username = usernameEdit.getText().toString();
                    ip = ipEdit.getText().toString();
                    if(username != "" && username != null
                                    && username != "用户名输入" && ip != null){
                            try{
                                    socket = new Socket(ip,PORT);
                                    in = new DataInputStream(socket.getInputStream());
                                    out = new DataOutputStream(socket.getOutputStream());
                                    Date now = new Date(System.currentTimeMillis());
                                    SimpleDateFormat format = new SimpleDateFormat
                                                    ("hh:mm:ss");
                                    String nowStr = format.format(now);
                                    out.writeUTF("$$" + username + " " + nowStr
                                                    + "上线了!");
                            }catch(IOException e1){
                                    System.out.println("can't connect");
                            thread = new Thread(MainActivity.this);
                            thread.start();
                            flag = true;
                    break;
                        case R.id.SendButton:
                                if(flag == false){
                                                        + "没有登录,请登录",Toast.LENGTH_SHORT).show();
                                        return;
                                chat_txt = messageEdit.getText().toString();
                                if(chat_txt != null){
                                                    ("hh:mm:ss");
                                    try{ out.writeUTF("^_^" + username + " " + nowStr +
                                                     "说/n" + chat_txt);}
                                    catch(IOException e2){}
                                else
                                        try{ out.writeUTF("请说话");}
                                        catch(IOException e3){}
                                break;
                        case R.id.LeaveButton:
                                if(flag == true){
                                        if(flag != false){
        + "没有登录,请登录!",Toast.LENGTH_SHORT).show();
                                                return;
                                        try{
                                                out.writeUTF("==" + username + "下线了!");
                                                out.close();
                                                in.close();
                                                socket.close();
                                        }catch(IOException e4){}
                                flag = false;
                                                + "已退出!",Toast.LENGTH_SHORT).show();
                                break;
        @Override
        public boolean onCreateOptionsMenu(Menu menu) {
                // Inflate the menu; this adds items to the action bar if it is present.
                getMenuInflater().inflate(R.menu.main, menu);
                return true;
        @Override
        public void run() {
                while(true){
                        try{
                                chat_in = in.readUTF();
                                chat_in = chat_in + "/n";
                                mHandler.sendMessage(mHandler.obtainMessage());
                        }catch(IOException e){}
        Handler mHandler = new Handler(){
                public void handleMessage(Message msg){
                        historyEdit.append(chat_in);
                        super.handleMessage(msg);
