//SMC1602A(16*2)模拟口线接线方式
//连接线图:
// |LCM-----51 | LCM-----51 | LCM------51 |
// |DB0-----P0.0 | DB4-----P0.4 | RW-------P1.1 |
// |DB1-----P0.1 | DB5-----P0.5 | RS-------P1.0 |
// |DB2-----P0.2 | DB6-----P0.6 | E--------P1.2 |
// |DB3-----P0.3 | DB7-----P0.7 | VLCD接1K电阻到GND|
//接线:模块TRIG接 P2.6 ECH0 接P2.7
//本程序源码只供学习参考,不得应用于商业用途,如有需要请联系作者。
//[注:AT89x51使用12M或11.0592M晶振,实测使用11.0592M]
#include
//器件配置文件
#include
#define RX P2_7
#define TX P2_6
#define LCM_RW P1_1 //定义LCD引脚
#define LCM_RS P1_0
#define LCM_E P1_2
#define LCM_Data P3
#define Key_Data P2_0 //定义Keyboard引脚
#define Key_CLK P3_2
#define Busy 0x80 //用于检测LCM状态字中的Busy标识
void LCMInit(void);
void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData);
void DisplayListChar(unsigned char X, unsigned char Y, unsigned char code *DData);
void Delay5Ms(void);
void Delay400Ms(void);
void Decode(unsigned char ScanCode);
void WriteDataLCM(unsigned char WDLCM);
void WriteCommandLCM(unsigned char WCLCM,BuysC);
unsigned char ReadDataLCM(void);
unsigned char ReadStatusLCM(void);
unsigned char code mcustudio[] ={"12:12:12 50'C"};
unsigned char code email[] = {"SET T:50 E:045 "};
unsigned char code Cls[] = {"NOW T:19'9 E:011"};
unsigned char code ASCII[15] = {'0','1','2','3','4','5','6','7','8','9','.','-','M'};
static unsigned char DisNum = 0; //显示用指针
unsigned int time=0;
unsigned long S=0;
bit flag =0;
unsigned char di***uff[4] ={ 0,0,0,0,};
//写数据
ReadStatusLCM(); //检测忙
LCM_Data = WDLCM;
LCM_RS = 1;
LCM_RW = 0;
LCM_E = 0; //若晶振速度太高可以在这后加小的延时
LCM_E = 0; //延时
LCM_E = 1;
//写指令
void WriteCommandLCM(unsigned char WCLCM,BuysC) //BuysC为0时忽略忙检测
if (BuysC) ReadStatusLCM(); //根据需要检测忙
LCM_Data = WCLCM;
LCM_RS = 0;
LCM_RW = 0;
LCM_E = 0;
LCM_E = 0;
LCM_E = 1;
//读数据
LCM_RS = 1;
LCM_RW = 1;
LCM_E = 0;
LCM_E = 0;
LCM_E = 1;
return(LCM_Data);
//读状态
LCM_Data = 0xFF;
LCM_RS = 0;
LCM_RW = 1;
LCM_E = 0;
LCM_E = 0;
LCM_E = 1;
while (LCM_Data & Busy); //检测忙信号
return(LCM_Data);
void LCMInit(void) //LCM初始化
LCM_Data = 0;
WriteCommandLCM(0x38,0); //三次显示模式设置,不检测忙信号
Delay5Ms();
Delay5Ms();
Delay5Ms();
WriteCommandLCM(0x38,1); //显示模式设置,开始要求每次检测忙信号
WriteCommandLCM(0x08,1); //关闭显示
WriteCommandLCM(0x01,1); //显示清屏
WriteCommandLCM(0x06,1); // 显示光标移动设置
WriteCommandLCM(0x0F,1); // 显示开及光标设置
//按指定位置显示一个字符
Y &= 0x1;
X &= 0xF; //限制X不能大于15,Y不能大于1
if (Y) X |= 0x40; //当要显示第二行时地址码+0x40;
X |= 0x80; //算出指令码
WriteCommandLCM(X, 1); //发命令字
WriteDataLCM(DData); //发数据
//按指定位置显示一串字符
unsigned char ListLength;
ListLength = 0;
Y &= 0x1;
while (DData[ListLength]>0x19) //若到达字串尾则退出
if (X <= 0xF) //X坐标应小于0xF
DisplayOneChar(X, Y, DData[ListLength]); //显示单个字符
ListLength++;
X++;
//5ms延时
void Delay5Ms(void)
unsigned int TempCyc = 5552;
while(TempCyc--);
//400ms延时
unsigned char TempCycA = 5;
unsigned int TempCycB;
while(TempCycA--)
TempCycB=7269;
while(TempCycB--);
void Conut(void)
time=TH0*256+TL0;
TH0=0;
TL0=0;
S=(time*1.7)/100; //算出来是CM
if((S>=700)||flag==1) //超出测量范围显示“-”
flag=0;
DisplayOneChar(0, 1, ASCII[11]);
DisplayOneChar(1, 1, ASCII[10]); //显示点
DisplayOneChar(2, 1, ASCII[11]);
DisplayOneChar(3, 1, ASCII[11]);
DisplayOneChar(4, 1, ASCII[12]); //显示M
else
di***uff[0]=S%1000/100;
di***uff[1]=S%1000%100/10;
di***uff[2]=S%1000%10 %10;
DisplayOneChar(0, 1, ASCII[di***uff[0]]);
DisplayOneChar(2, 1, ASCII[di***uff[1]]);
DisplayOneChar(3, 1, ASCII[di***uff[2]]);
void zd0() interrupt 1 //T0中断用来计数器溢出,超过测距范围
flag=1; //中断溢出标志
void StartModule() //启动模块
TX=1; //启动一次模块
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
TX=0;
void delayms(unsigned int ms)
unsigned char i=100,j;
for(;ms;ms--)
while(--i)
j=10;
while(--j);
void main(void)
unsigned char TempCyc;
Delay400Ms(); //启动等待,等LCM讲入工作状态
LCMInit(); //LCM初始化
Delay5Ms(); //延时片刻(可不要)
DisplayListChar(0, 0, mcustudio);
DisplayListChar(0, 1, email);
ReadDataLCM();//测试用句无意义
for (TempCyc=0; TempCyc<10; TempCyc++)
Delay400Ms(); //延时
DisplayListChar(0, 1, Cls);
while(1)
TMOD=0x01; //设T0为方式1,GATE=1;
TH0=0;
TL0=0;
ET0=1; //允许T0中断
EA=1; //开启总中断
while(1)
StartModule();
// DisplayOneChar(0, 1, ASCII[0]);
while(!RX); //当RX为零时等待
TR0=1; //开启计数
while(RX); //当RX为1计数并等待
TR0=0; //关闭计数
Conut(); //计算
delayms(80); //80MS
//连接线图:
#include
//器件配置文件
#include
#define RX P2_7
#define TX P2_6
#define LCM_RS P1_0
#define LCM_E P1_2
#define LCM_Data P3
void LCMInit(void);
unsigned long S=0;
bit flag =0;
//写数据
LCM_Data = WDLCM;
LCM_RS = 1;
LCM_RW = 0;
LCM_E = 0; //延时
LCM_E = 1;
//写指令
LCM_Data = WCLCM;
LCM_RS = 0;
LCM_RW = 0;
LCM_E = 0;
LCM_E = 0;
LCM_E = 1;
//读数据
LCM_RS = 1;
LCM_RW = 1;
LCM_E = 0;
LCM_E = 0;
LCM_E = 1;
return(LCM_Data);
//读状态
LCM_Data = 0xFF;
LCM_RS = 0;
LCM_RW = 1;
LCM_E = 0;
LCM_E = 0;
LCM_E = 1;
return(LCM_Data);
LCM_Data = 0;
Delay5Ms();
Delay5Ms();
Delay5Ms();
//按指定位置显示一个字符
Y &= 0x1;
X |= 0x80; //算出指令码
//按指定位置显示一串字符
ListLength = 0;
Y &= 0x1;
ListLength++;
X++;
//5ms延时
void Delay5Ms(void)
while(TempCyc--);
//400ms延时
while(TempCycA--)
TempCycB=7269;
while(TempCycB--);
void Conut(void)
time=TH0*256+TL0;
TH0=0;
TL0=0;
flag=0;
else
flag=1; //中断溢出标志
TX=1; //启动一次模块
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
TX=0;
for(;ms;ms--)
while(--i)
j=10;
while(--j);
void main(void)
LCMInit(); //LCM初始化
Delay400Ms(); //延时
while(1)
TH0=0;
TL0=0;
ET0=1; //允许T0中断
EA=1; //开启总中断
while(1)
StartModule();
TR0=1; //开启计数
TR0=0; //关闭计数
Conut(); //计算
delayms(80); //80MS
