package com.example.drawabletest;
import android.app.Ac
tivity;
import android.graphics.Bitmap;
import android.graphics.BitmapFactory;
import android.graphics.drawable.BitmapDrawable;
import android.graphics.drawable.Drawable;
import android.graphics.drawable.TransitionDrawable;
import android.os.Bundle;
import android.os.Handler;
import android.os.Message;
import android.widget.ImageView;
public class MainActivity extends Activity {
private int change=0;
private int[] ids = new int[] { R.drawable.image1, R.drawable.image2, R.drawable.image3,
R.drawable.image4, R.drawable.image5 };
private Drawable[] drawables;
private ImageView imageView;
@Override
public void onCreate(Bundle savedInstanceState) {
super.onCreate(savedInstanceState);
setContentView(R.layout.activity_main);
imageView = (ImageView) findViewById(R.id.imgView);
/*获得合适的drawable资源*/
BitmapFactory.Options opts = new BitmapFactory.Options();
opts.inJustDecodeBounds = true;
BitmapFactory.decodeResource(getResources(), R.drawable.image1, opts);
opts.inSampleSize = computeSampleSize(opts, -1, 500 * 500);
opts.inJustDecodeBounds = false;
drawables=new Drawable[ids.length];
try {
for (int i = 0; i < ids.length; i++) {// for循环,加载5个drawable资源
Bitmap bmp = BitmapFactory.decodeResource(getResources(), ids
, opts);
drawables = new BitmapDrawable(bmp);
} catch (Exception e) {
e.printStackTrace();
//开启线程,改变transition
new Thread(new MyRunnable()).start();
//处理transition的改变
private Handler handler=new Handler(new Handler.Callback() {
public boolean handleMessage(Message msg) {
int duration=msg.arg1;
TransitionDrawable transitionDrawable=null;
transitionDrawable= new TransitionDrawable(new Drawable[] {
drawables[change%ids.length],//实现从0 1 2 3 4 5 0 1 2.。。这样的不停转变
drawables[(change+1)%ids.length] });
change++;
imageView.setImageDrawable(transitionDrawable);
transitionDrawable.startTransition(duration);
return false;
//线程,去发送消息,让transition一直改变
private class MyRunnable implements Runnable{
public void run() {
while (true) {
int duration=3000;//改变的间隔
Message message=handler.obtainMessage();
message.arg1=duration;
handler.sendMessage(message);
try {
Thread.sleep(duration);
} catch (InterruptedException e) {
//计算合适的图片大小
public static int computeSampleSize(BitmapFactory.Options options, int minSideLength,
int maxNumOfPixels) {
int initialSize = computeInitialSampleSize(options, minSideLength, maxNumOfPixels);
int roundedSize;
if (initialSize <= 8) {
roundedSize = 1;
while (roundedSize < initialSize) {
roundedSize <<= 1;
} else {
roundedSize = (initialSize + 7) / 8 * 8;
return roundedSize;
//计算合适的图片大小
private static int computeInitialSampleSize(BitmapFactory.Options options, int minSideLength,
double w = options.outWidth;
double h = options.outHeight;
int lowerBound = (maxNumOfPixels == -1) ? 1 : (int) Math.ceil(Math.sqrt(w * h
/ maxNumOfPixels));
int upperBound = (minSideLength == -1) ? 128 : (int) Math.min(
Math.floor(w / minSideLength), Math.floor(h / minSideLength));
if (upperBound < lowerBound) {
// return the larger one when there is no overlapping zone.
return lowerBound;
if ((maxNumOfPixels == -1) && (minSideLength == -1)) {
return 1;
} else if (minSideLength == -1) {
return lowerBound;
} else {
return upperBound;
