乐美客SBC专区
李方
10年用户 127经验值
擅长:嵌入式技术 连接器 EDA/IC设计 处理器/DSP 接口/总线/驱动 控制/MCU
[香蕉派江湖]
在BananaPi上启动最小ubuntu系统
转自lemaker
1. 下载image文件
u-boot, script.bin, kernel: http://pan.baidu.com/s/1i3sorhr
ubuntu: http://pan.baidu.com/s/1c0paF88
2. 烧写u-boot
$ sudo dd if=/dev/zero of=/dev/sdb bs=1M count=1
$ sudo dd if=u-boot-sunxi-with-spl.bin of=/dev/sdb bs=1024 seek=8
3. SD 卡分区
蓝色的部分直接回车,红色部分为输入。
--->8---
$ sudo fdisk /dev/sdb
Device contains neither a valid DOS partition table, nor Sun, SGI or OSF disklabel
Building a new DOS disklabel with disk identifier 0x67abb3e5.
Changes will remain in memory only, until you decide to write them.
After that, of course, the previous content won't be recoverable.
Warning: invalid flag 0x0000 of partition table 4 will be corrected by w(rite)
Command (m for help): n
Partition type:
   p   primary (0 primary, 0 extended, 4 free)
   e   extended
Select (default p):
Using default response p
Partition number (1-4, default 1):
Using default value 1
First sector (2048-1990655, default 2048):
Using default value 2048
Last sector, +sectors or +size{K,M,G} (2048-1990655, default 1990655): +20M
Partition type:
   p   primary (1 primary, 0 extended, 3 free)
   e   extended
Select (default p):
Partition number (1-4, default 2):
First sector (43008-1990655, default 43008):
Using default value 43008
Last sector, +sectors or +size{K,M,G} (43008-1990655, default 1906595):
Using default value 1990655
Command (m for help): w
The partition table has been altered!
Calling ioctl() to re-read partition table.
Syncing disks.
---8<---
分区创建好了,下面进行格式化。
$ sudo mkfs.vfat /dev/sdb1
$ sudo mkfs.ext2 /dev/sdb2
4. 复制script.bin和uImage文件
$ sudo mount /dev/sdb1 /mnt
$ sudo cp script.bin /mnt
$ sudo cp uImage /mnt/
$ sudo umount /mnt
5. 解压ubuntu文件系统
$ sudo mount /dev/sdb2 /mnt
$ sudo tar -xvf ubuntu-13.04.tgz -C /mnt (or sudo tar -jxvf ubuntu-14.04.bz2 -C /mnt)
$ sudo umount /mnt
6. 将SD卡插入BananaPi上面,上电,等待着ubuntu启动起来,然后,就可以随心所欲啦。
7. 是不是不知道用户名和密码呢?猜一猜?是BananaPi呢?还是bananapi呢?
用户名:bananapi
密码:bananapi
回帖(5)
周城东
2014-9-4 01:01:56
很强大{:12:}
JiangMichael
2016-1-25 17:23:55
请问楼主第7个密码是怎么来的?
Daemon1
2016-5-21 17:13:48
您好!版主;我点了您给的百度网盘资料链接,但已经过期了,给以给我发一下吗;很急,非常感谢:aarogus@outlook.com
lee_st
2017-5-14 07:59:48
好像很腻害的样子啊
