百度网盘:http://pan.baidu.com/s/1mgwYgze
DS-5 v5.15.1 重要说明:(2)该版本安装正版许可证(包括试用许可证)后可以使用全部功能。
(4)该版本是从ARM官方网站下载而来,为方便国内用户提供的下载地址,为并非DS-5破解版。
(5)2013年6月20日起,新申请的试用版许可证不能在 DS-5 以前的版本中使用,即 DS-5 v5.14 及以前的版本都不能使用2013年6月20日以后申请的许可证,需下载 DS-5 v5.15.1 及以上版本方可使用。
(7)该下载地址的 DS-5 版本适合安装在 Linux 64 位系统上。
DS-5 v5.15.1 版本更新摘要(build5150018 2013年6月20日)
ARM 编译器- updated to ARM Compiler 5.03u2 for latest improvements and bug fixes
ARM Streamline 性能分析器- Capture & Analysis Options dialog adds a Keep option to limit the amount of data to process from a capture session
- per-cpu disclosure added to the real-time live display
- CPU Wait charts are now user configurable
- Log view allows filtering on When and Duration
- performance of .apc file generation is improved
- redesigned interface for displaying warnings
DS-5- separate installers are provided for 32-bit and 64-bit Windows
DS-5 调试器- processor support extended to include Cortex-A12
- watchpoints are now supported when connected to CADI simulation models
- added OS awareness for FreeRTOS™ on Cortex-M family devices
- added OS awareness for Micrium® μCOS-III® on Cortex-M family devices
- breakpoint and memory commands now set an internal $ variable with the breakpoint or memory region number so that these can be used in subsequent scripting commands
- new command newvar allows creation of new variables in DS scripts
- new address space AXI: provides direct memory access via a CoreSight™ Debug Access Port
- cdbimporter now supports Embedded Trace FIFO (ETF) and Embedded Trace Router (ETR) devices
- device support extended to include: Avnet ZedBoard, Freescale i.MX6 Dual, Mindspeed T2200 / T3300, pandaboard.org OMAP 5432, Renesas RZ/A1H R7S721001, ST-Ericsson U8540, TI OMAP 543X and TI TMDX570LS04HDK / TMDX570LS12HDK / TMDX570LS31HDK / TMDXRM42HDK / TMDXRM46HDK / TMDXRM48HDK
DSTREAM/RVI- new 4.12.0 version of firmware included
- support added for > 32-bit addresses on AXI-AP
- drive strengths of the JTAG/SWD signals on the DSTREAM probe are reduced to prevent signal reflection issues with certain targets
- improved support for large multi-core systems containing Cortex devices
Eclipse IDE- removed a limitation on linker command line lengths when building projects on Windows host platforms
- License Manager dialog provides a diagnostics tab to help resolve licensing errors
- improved visibility of product update notifications
Examples- new projects Freescale-Vybrid-VF6xx-A5_RAM and Freescale-VF6xx-M4_RAM in Bare-metal_boards_examples.zip demonstrate basic bare-metal applications running on Freescale Vybrid VF6xx devices
- ports of RTX for Renesas RZ/A1 device and GENMAI board are included in CMSIS_RTOS_RTX.zip
GCC 工具链:- updated to Linaro GCC Toolchain 2013.03 for Linux applications and Linux kernel
Simulation Models- pre-supplied Real-Time Simulation Models (RTSM) are rebranded to Fixed Virtual Platforms (FVP)
以下功能已经过时,在将来的版本中会删除:
