STM32/STM8技术william hill官网
deeplink
9年用户 20经验值
擅长:嵌入式技术 接口/总线/驱动 控制/MCU
关于timer16路pwm输出极性的问题
在做bldc驱动上希望用p+nmos也就是comos模式驱动,可以利用同步整流减少续流损耗,但在实现的过程中对于mos管和STM32对于pwm波形极性的设置不甚明白,希望高手指点一二,不胜感激。
6路pwm输出设置:
/* Channel 1, 2,3 and 4 Configuration in PWM mode */
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
  TIM_OCInitStructure.TIM_Pulse = ps;
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
  TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High;
  TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Reset;
  TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCNIdleState_Set;
  TIM_OC1Init(TIM1, &TIM_OCInitStructure);
  /* Automatic Output enable, Break, dead time and lock configuration*/
  TIM_BDTRInitStructure.TIM_OSSRState = TIM_OSSRState_Enable;
  TIM_BDTRInitStructure.TIM_OSSIState = TIM_OSSIState_Enable;
  TIM_BDTRInitStructure.TIM_LOCKLevel = TIM_LOCKLevel_OFF;
  TIM_BDTRInitStructure.TIM_DeadTime = 1;
  TIM_BDTRInitStructure.TIM_Break = TIM_Break_Enable;
  TIM_BDTRInitStructure.TIM_BreakPolarity = TIM_BreakPolarity_Low;
  TIM_BDTRInitStructure.TIM_AutomaticOutput = TIM_AutomaticOutput_Enable;
  TIM_BDTRConfig(TIM1, &TIM_BDTRInitStructure);
6步换相操作:
if (step == 1)
   /* Next step: Step 2 Configuration ---------------------------- */
   /*  Channel1 configuration */
   // TIM_SelectOCxM(TIM1, TIM_Channel_1, TIM_OCMode_PWM1);
   TIM_CCxCmd(TIM1, TIM_Channel_1, TIM_CCx_Enable);
#if 0
   TIM_CCxNCmd(TIM1, TIM_Channel_1, TIM_CCxN_Disable);
   /**OC1N=CC1NP,CC1NP=0下桥臂关*/
   TIM_OC1NPolarityConfig(TIM1, TIM_OCNPolarity_High);
#endif
   /*  Channel2 configuration */
   // TIM_SelectOCxM(TIM1, TIM_Channel_2, TIM_OCMode_PWM1 );
   TIM_CCxCmd(TIM1, TIM_Channel_2, TIM_CCx_Disable);
   TIM_CCxNCmd(TIM1, TIM_Channel_2, TIM_CCxN_Disable);
   /*OC2N=CC2NP,CC2NP=1下桥臂开*/
   TIM_OC2NPolarityConfig(TIM1, TIM_OCNPolarity_Low);
   /*  Channel3 configuration */
   TIM_CCxCmd(TIM1, TIM_Channel_3, TIM_CCx_Disable);
   TIM_CCxNCmd(TIM1, TIM_Channel_3, TIM_CCxN_Disable);
   /*OC3N=CC3NP,CC3NP=0下桥臂关*/
   TIM_OC3NPolarityConfig(TIM1, TIM_OCNPolarity_High);
   step++;
  else if (step == 2)
   /* Next step: Step 3 Configuration ---------------------------- */
   TIM_CCxCmd(TIM1, TIM_Channel_1, TIM_CCx_Disable);
#if 0
#endif
   //  TIM_SelectOCxM(TIM1, TIM_Channel_2, TIM_OCMode_PWM1);
#if 0
#endif
   //   TIM_SelectOCxM(TIM1, TIM_Channel_3, TIM_OCMode_PWM1);
   TIM_CCxCmd(TIM1, TIM_Channel_3, TIM_CCx_Enable);
#if 0
#endif
   step++;
  else if (step == 3)
   /* Next step: Step 4 Configuration ---------------------------- */
   /*OC1N=CC1NP,CC1NP=1下桥臂开*/
   TIM_OC1NPolarityConfig(TIM1, TIM_OCNPolarity_Low);
   /*OC2N=CC2NP,CC2NP=0下桥臂关*/
   TIM_OC2NPolarityConfig(TIM1, TIM_OCNPolarity_High);
#if 0
#endif
   step++;
  else if (step == 4)
   /* Next step: Step 5 Configuration ---------------------------- */
   /*下桥臂常开*/
   TIM_CCxCmd(TIM1, TIM_Channel_2, TIM_CCx_Enable);
#if 0
#endif
#if 0
#endif
   step++;
  else if (step == 5)
   /* Next step: Step 6 Configuration ---------------------------- */
#if 0
   /*OC2N=CC2NP,CC2NP=0下桥臂常关*/
#endif
   /*OC3N=CC3NP,CC3NP=1下桥臂开*/
   TIM_OC3NPolarityConfig(TIM1, TIM_OCNPolarity_Low);
   step++;
  else
   /* Next step: Step 1 Configuration ---------------------------- */
#if 0
#endif
#if 0
#endif
   step = 1;
请问其中:
1.同步整流是怎么实现的?
2.  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
这四句分别实现什么功能?
3.TIM_OC1NPolarityConfig(TIM1, TIM_OCNPolarity_High);
该句是为了设置pwm互补通道的输出极性,这里面的high和low分别代表什么意思?是输出1和0的意思吗,还是输出1导通和0导通?
4.对于pmos管和nmos管导通原理自然不一样,是相反的,在程序里怎么体现呢?打比方来讲对于3通道:
若上桥为pmos,下桥为nmos,上述2句是不是导通其中的一桥,而另一桥关断?那哪个导通哪个关断呢?关于这个极性的设置好头大啊,望大神不吝详细指点一二!
