下面这个函数是arduino中测量引脚高地平或者低电平维持时间的函数,楼主可以参照一下,只要测得引脚输入的高电平或者低电平维持时间,其倒数就是频率了。
unsigned long pulseIn(uint8_t pin, uint8_t state, unsigned long timeout)
// cache the port and bit of the pin in order to speed up the
// pulse width measuring loop and achieve finer resolution. calling
// digitalRead() instead yields much coarser resolution.
uint8_t bit = digitalPinToBitMask(pin);
uint8_t port = digitalPinToPort(pin);
uint8_t stateMask = (state ? bit : 0);
unsigned long width = 0; // keep initialization out of time critical area
// convert the timeout from microseconds to a number of times through
// the initial loop; it takes 16 clock cycles per iteration.
unsigned long numloops = 0;
unsigned long maxloops = microsecondsToClockCycles(timeout) / 16;
// wait for any previous pulse to end
while ((*portInputRegister(port) & bit) == stateMask)
if (numloops++ == maxloops)
return 0;
// wait for the pulse to start
while ((*portInputRegister(port) & bit) != stateMask)
return 0;
// wait for the pulse to stop
while ((*portInputRegister(port) & bit) == stateMask) {
return 0;
width++;
// convert the reading to microseconds. There will be some error introduced by
// the interrupt handlers.
// Conversion constants are compiler-dependent, different compiler versions
// have different levels of optimization.
#if __GNUC__==4 && __GNUC_MINOR__==3 && __GNUC_PATCHLEVEL__==2
// avr-gcc 4.3.2
return clockCyclesToMicroseconds(width * 21 + 16);
#elif __GNUC__==4 && __GNUC_MINOR__==8 && __GNUC_PATCHLEVEL__==1
// avr-gcc 4.8.1
return clockCyclesToMicroseconds(width * 24 + 16);
#elif __GNUC__<=4 && __GNUC_MINOR__<=3
// avr-gcc <=4.3.x
#warning "pulseIn() results may not be accurate"
#else
// avr-gcc >4.3.x
#endif
return 0;
return 0;
return 0;
width++;
// avr-gcc 4.3.2
// avr-gcc 4.8.1
// avr-gcc <=4.3.x
#else
// avr-gcc >4.3.x
#endif
