`Linear公司的LTC4120是无线电源接收器和 400mA 降压型电池充电器,具有动态协调控制可优化宽耦合范围内的无线充电,宽输入电压从4.3V 至 40V,可调电池浮动电压从3.5V 至 11V,采用单个电阻器设置的 50mA 至 400mA 充电电流, ±1%反馈电压准确度, 准确度为 5% 的可编程充电电流,以及无需微处理器和无变压器磁芯等特性,主要用在手持仪表,工业/军用传感器,手持医疗设备以及电隔离设备.本文介绍了LTC4120主要特性,框图,典型应用威廉希尔官方网站
以及演示板DC1969A主要特性,威廉希尔官方网站
图和材料清单. The LTC.4120 is a constant-current/constant-voltage wireless receiver and battery charger. An external programming resistor sets the charge current up to 400mA. The programmable float voltage of the LTC4120 accommodates several battery chemistries. The LTC4120 uses a Dynamic HARMonization Control (DHC) technique that allows high efficiency contactless charging across an air gap. The LTC4120 regulates its input voltage via the DHC pin. This technique modulates the resonant frequency of a receiver tank to automatically adjust the power received as well as the power transmitted to provide an efficient solution for wirelessly charging battery-powered devices. Wireless charging with the LTC4120 provides a method to power devices in harsh environments without requiring expensive failure-prone connectors. This allows products to be charged while locked within sealed enclosures, or in moving or rotating equipment, or where cleanliness or sanitation is critical. This full featured battery charger includes accurate RUN pin threshold, low voltage battery preconditioning and bad battery fault detection, timer termination, auto-recharge, and NTC temperature qualified charging. The FAULT pin provides an indication of bad battery or temperature faults. Once charging is terminated, the LTC4120 signals end-ofcharge via the CHRG pin, and enters a low current sleep mode. An auto-restart feature starts a new charging cycle if the battery voltage drops by 2.5%. LTC4120主要特性: Dynamic Harmonization Control Optimizes Wireless Charging Over a Wide Coupling Range Wide Input Voltage Range: 4.3V to 40V Adjustable Battery Float Voltage: 3.5V to 11V 50mA to 400mA Charge Current Programmed with a Single Resistor ±1% Feedback Voltage Accuracy Programmable 5% Accurate Charge Current No Microprocessor Required No Transformer Core Thermally Enhanced, Low Profile 16-Lead (3mm × 3mm × 0.75mm) QFN Package LTC4120应用: Handheld Instruments Industrial/Military Sensors and Devices Harsh Environments Portable Medical Devices Physically Small Devices Electrically Isolated Devices 图1.LTC 4120框图 图2.LTC 4120典型应用威廉希尔官方网站 演示板DC1969A Demonstration circuit DC1969A is a kit of: the DC1967A-X LTC®4120EUD demonstration board, the DC1968A basic wireless transmitter, a 35mm receiver ferrite disk, and an assortment of different length standoffs. The basic transmitter can deliver 2W to the receive board with up to 10mm spacing between the transmit and the receive coils. The basic transmitter does not support foreign object detection, i.e. coins or other metallic objects. 演示板DC1969A套件包括: 1X DC1967A-X* (LTC4120EUD) Demo Board 1X DC1968A (Wireless Basic Transmitter) Demo Board 1X 35mm Ferrite Bead 4X 6.25mm (0.25") Nylon Standoffs 4X 12.5mm (0.50") Nylon Standoffs 4X 15.875mm (0.625") Nylon Standoffs 图3.DC1967A-B LTC4120接收板外形图 图4.DC1968A Basic发送板外形图 图5.无线充电系统功能框图 图6.LTC4120发送器威廉希尔官方网站 图 图7.DC1967A威廉希尔官方网站 图(1) 图8.DC1967A威廉希尔官方网站 图(2) 图9.DC1968A威廉希尔官方网站 图 演示板DC1969A材料清单: |
5 个讨论
7475 浏览 0 评论
自己设计的Arduino UNO R3主控板原理图+PCB源文件(可直接打样)
7448 浏览 0 评论
65738 浏览 1 评论
2937 浏览 2 评论
7224 浏览 0 评论
基于峰岹的FU6813L波轮洗衣机控制方案(原理图+PCB+源程序
95281浏览 4评论
2940浏览 2评论
65803浏览 1评论
7227浏览 0评论
7540浏览 0评论
GMT+8, 2025-1-14 11:10 , Processed in 1.092281 second(s), Total 51, Slave 41 queries .
