可以试试这个,IIC 的时序要正确 我不知道你是否按照时序图写了
#define I2C_DELAY; _nop_();_nop_();_nop_();_nop_();_nop_(); // >=4.7uS
// delay 100us
void mDelay(INT8U k)
INT16U i ;
for(; k>0; k--)
for(i=0; i<93; i++)
//OK
void I2C_Start(void)
SDA = 1;
I2C_DELAY;
SCL = 1;
I2C_DELAY;
SDA = 0;
I2C_DELAY;
I2C_DELAY;
//OK
void I2C_Stop(void)
SDA = 0 ;
I2C_DELAY;
SCL = 1 ;
I2C_DELAY;
SDA = 1 ;
I2C_DELAY;
I2C_DELAY;
void sendAck(void)
SCL = 0;
I2C_DELAY;
SDA = 0;
I2C_DELAY;
SCL = 1;
I2C_DELAY;
void sendNoAck(void)
SCL = 0;
I2C_DELAY;
SDA = 1;
I2C_DELAY;
SCL = 1;
I2C_DELAY;
// 0 = noACK; 1 = ACK ;
bit checkAck()
bit tempbit;
/*发送完一个字节后检验设备的应答信号*/
SDA = 1;
I2C_DELAY;
SCL = 0;
I2C_DELAY;
tempbit = SDA;
SCL = 1;
I2C_DELAY;
if(tempbit==1)
return 0; //noACK
else
return 1; //ACK
//OK
// a positive clock edge clock a bit into the ROM
void writeByte(INT8U datum)
INT8U bitCnt = 0 ;
for(bitCnt=0; bitCnt<8; bitCnt++)
SCL = 0 ;
I2C_DELAY;
if ((datum&0x80) == 0x80) //if the MSb is 1
SDA = 1 ;
else
SDA = 0 ;
I2C_DELAY;
SCL = 1 ;
I2C_DELAY;
datum<<=1 ;
//OK
INT8U readByte(void)
bit tempbit = 1 ;
INT8U temp = 0 ;
INT8U bitCnt ;
SDA = 1 ; // release the bus,ready to receive byte??????????????
I2C_DELAY;
SCL = 0; //?????????????????????????huan???????????????
I2C_DELAY;
tempbit = SDA ;
if (tempbit)
temp |= 0x01 ;
else
temp &= 0xfe ;
SCL = 1 ;
I2C_DELAY;
if(bitCnt<7)
temp <<= 1 ;
return(temp) ;
/*~~~~~~~~~~~~~~~~~~~~~~~ API ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~*/
write some bytes to sequential address
void writeToROM(INT8U datum[], INT8U address, INT8U num)
bit tempbit ;
INT8U i ;
INT8U *datum_P ;
datum_P = datum ;
I2C_Start() ;
writeByte(0xa0) ;
tempbit = checkAck();
writeByte(address) ;
for(i=0; i
writeByte(*(datum_P+i)) ;
if(!checkAck())
I2C_Stop() ;
mDelay(100) ;
I2C_Stop() ;
read some bytes from ROM`s sequential address
void readFromROM(INT8U datum[], INT8U address, INT8U num)
bit tempbit ;
INT8U i ;
INT8U *datum_P ;
datum_P = datum;
I2C_Start() ;
writeByte(0xa0) ;
I2C_Start() ;
writeByte(0xa1) ;
for(i=0; i
*(datum_P+i) = readByte() ;
if(i!=num-1)
sendAck() ;
else
sendNoAck() ;
I2C_Stop() ;
wirte one byte to ROM --random write
void writeOneByte(INT8U addr, INT8U datum)
bit tempbit ;
/*write a byte to mem*/
I2C_Start();
writeByte(0xa0);
writeByte(addr); /*address*/
writeByte(datum); /*the data*/
I2C_Stop();
mDelay(100) ;
read one byte from rom --random read
INT8U readOneByte(INT8U addr)
bit tempbit = 1;
INT8U mydata;
/*read a byte from mem*/
I2C_Start();
writeByte(0xa0);
I2C_Start();
writeByte(0xa1);
mydata = readByte();
return (mydata) ;
I2C_Stop();
// delay 100us
INT16U i ;
for(; k>0; k--)
for(i=0; i<93; i++)
//OK
SDA = 1;
I2C_DELAY;
SCL = 1;
I2C_DELAY;
SDA = 0;
I2C_DELAY;
I2C_DELAY;
//OK
void I2C_Stop(void)
SDA = 0 ;
I2C_DELAY;
SCL = 1 ;
I2C_DELAY;
SDA = 1 ;
I2C_DELAY;
I2C_DELAY;
void sendAck(void)
SCL = 0;
I2C_DELAY;
SDA = 0;
I2C_DELAY;
SCL = 1;
I2C_DELAY;
SCL = 0;
I2C_DELAY;
SDA = 1;
I2C_DELAY;
SCL = 1;
I2C_DELAY;
bit checkAck()
bit tempbit;
SDA = 1;
I2C_DELAY;
SCL = 0;
I2C_DELAY;
tempbit = SDA;
SCL = 1;
I2C_DELAY;
if(tempbit==1)
return 0; //noACK
else
return 1; //ACK
//OK
INT8U bitCnt = 0 ;
SCL = 0 ;
I2C_DELAY;
SDA = 1 ;
else
SDA = 0 ;
I2C_DELAY;
SCL = 1 ;
I2C_DELAY;
datum<<=1 ;
//OK
bit tempbit = 1 ;
INT8U temp = 0 ;
INT8U bitCnt ;
I2C_DELAY;
I2C_DELAY;
tempbit = SDA ;
if (tempbit)
temp |= 0x01 ;
else
temp &= 0xfe ;
SCL = 1 ;
I2C_DELAY;
if(bitCnt<7)
temp <<= 1 ;
return(temp) ;
bit tempbit ;
INT8U i ;
INT8U *datum_P ;
datum_P = datum ;
I2C_Start() ;
writeByte(0xa0) ;
for(i=0; i
if(!checkAck())
I2C_Stop() ;
mDelay(100) ;
I2C_Stop() ;
bit tempbit ;
INT8U i ;
INT8U *datum_P ;
datum_P = datum;
I2C_Start() ;
writeByte(0xa0) ;
I2C_Start() ;
writeByte(0xa1) ;
for(i=0; i
if(i!=num-1)
sendAck() ;
else
sendNoAck() ;
I2C_Stop() ;
bit tempbit ;
I2C_Start();
writeByte(0xa0);
I2C_Stop();
mDelay(100) ;
bit tempbit = 1;
INT8U mydata;
I2C_Start();
writeByte(0xa0);
I2C_Start();
writeByte(0xa1);
return (mydata) ;
I2C_Stop();
