这俩天,趁着闲出来的时间做了eeprom的实验,自己写了eeprom的驱动,在这里与大家分享。
版本说明:
平台:OK210;
os :Linux2.6.35.7
驱动类型:eeprom
驱动程序如下:
- #include
- #include
- #include
- #include
- #include
- #include
- #include
- #include
- #include
- #include
- #include
- #define CHARDEVICEDRIVER_MAJOR 0
- #define CHARDEVICEDRIVER_MINOR 0
- struct at24cxx_dev
- struct device *dev_device;
- struct i2c_client *client;
- struct cdev cdev;
- struct at24cxx_dev *at24cxx_devp = NULL;
- static struct class *dev_class = NULL;
- static u32 chardevicedriver_major = CHARDEVICEDRIVER_MAJOR;
- static u32 chardevicedriver_minor = CHARDEVICEDRIVER_MINOR;
- static const struct i2c_device_id at24cxx_id[] = {
- {"at24cxx", 0 }, //该i2c_driver所支持的i2c_client
- MODULE_DEVICE_TABLE(i2c,at24cxx_id);
- static ssize_t at24cxx_read(struct file *file, char __user *buf, size_t size, loff_t * offset)
- unsigned char address;
- unsigned char data;
- struct i2c_msg msg[2];
- int ret;
- /* address = buf[0]
- * data = buf[1]
- if (size != 1)
- return -EINVAL;
- copy_from_user(&address, buf, 1);
- /* 数据传输三要素: 源,目的,长度 */
- /* 读AT24CXX时,要先把要读的存储空间的地址发给它 */
- msg[0].addr = at24cxx_devp->client->addr; /* 目的 */
- msg[0].buf = &address; /* 源 */
- msg[0].len = 1; /* 地址=1 byte */
- msg[0].flags = 0; /* 表示写 */
- /* 然后启动读操作 */
- msg[1].addr = at24cxx_devp->client->addr; /* 源 */
- msg[1].buf = &data; /* 目的 */
- msg[1].len = 1; /* 数据=1 byte */
- msg[1].flags = I2C_M_RD; /* 表示读 */
- ret = i2c_transfer(at24cxx_devp->client->adapter, msg, 2);
- if (ret == 2)
- copy_to_user(buf, &data, 1);
- return 1;
- else
- return -EIO;
- static ssize_t at24cxx_write(struct file *file, const char __user *buf, size_t size, loff_t *offset)
- unsigned char val[2];
- struct i2c_msg msg[1];
- int ret;
- * data = buf[1]
- if (size != 2)
- return -EINVAL;
- copy_from_user(val, buf, 2);
- msg[0].buf = val; /* 源 */
- msg[0].len = 2; /* 地址+数据=2 byte */
- ret = i2c_transfer(at24cxx_devp->client->adapter, msg, 1);
- if (ret == 1)
- return 2;
- else
- return -EIO;
- static struct file_operations at24cxx_fops = {
- .owner = THIS_MODULE,
- //.open = chardevicedriver_open,
- .read = at24cxx_read,
- .write = at24cxx_write,
- //.ioctl = chardevicedriver_ioctl,
- //.release= chardevicedriver_release,
- // add one cdev and create one device file
- static int chardevicedriver_cdev_add(struct at24cxx_dev *pcdevp, int index)
- int ret = -EFAULT;
- dev_t dev = 0;
- // add cdev object
- dev = MKDEV( chardevicedriver_major, chardevicedriver_minor + index );
- cdev_init( &(pcdevp->cdev), &at24cxx_fops);
- ret = cdev_add( &(pcdevp->cdev), dev, 1 );
- // create device
- pcdevp->dev_device = device_create( dev_class, NULL, dev, NULL, "at24cxx%d", MINOR( dev ) );
- return 0;
- static int at24cxx_probe(struct i2c_client *client, const struct i2c_device_id *id)
- int ret;
- dev_t dev = 0;
- // register device number
- if( chardevicedriver_major ) { // static device number
- dev = MKDEV( chardevicedriver_major, chardevicedriver_minor );
- ret = register_chrdev_region( dev, 1, "at24cxx" );
- else { // dynamic device number
- ret = alloc_chrdev_region( &dev, chardevicedriver_minor, 1, "at24cxx" );
- chardevicedriver_major = MAJOR( dev );
- at24cxx_devp = kmalloc( sizeof( struct at24cxx_dev ), GFP_KERNEL );
- memset(at24cxx_devp, 0, sizeof(struct at24cxx_dev));
- at24cxx_devp->client = client;
- dev_class = class_create( THIS_MODULE, "at24cxx" );
- chardevicedriver_cdev_add(at24cxx_devp,0);
- return 0;
- static int __devexit at24cxx_remove(struct i2c_client *client)
- device_destroy( dev_class, MKDEV( chardevicedriver_major, 0 ) );
- cdev_del( &( at24cxx_devp->cdev ) );
- // destroy device class
- class_destroy( dev_class );
- // free memory for private struct
- kfree( at24cxx_devp );
- at24cxx_devp = NULL;
- // unregister device number
- unregister_chrdev_region( MKDEV( chardevicedriver_major, chardevicedriver_minor ), 1 );
- return 0;
- /* 1. 分配一个i2c_driver结构体 */
- /* 2. 设置i2c_driver结构体 */
- static struct i2c_driver at24cxx_driver = {
- .driver = {
- .name = "at24cxx",
- .probe=at24cxx_probe,
- .remove=__devexit_p(at24cxx_remove),
- .id_table=at24cxx_id,
- static int __init at24cxx_init(void)
- i2c_add_driver(&at24cxx_driver);
- return 0;
- static void __exit at24cxx_exit(void)
- i2c_del_driver(&at24cxx_driver);
- module_init(at24cxx_init);
- module_exit(at24cxx_exit);
- MODULE_LICENSE("GPL");
makefile文件如下
- all:
- make -C $(SRC_PATH)/kernel M=`pwd` modules
- cp at24cxx.ko $(SRC_PATH)/system/modules/ -av
- clean:
- make -C $(SRC_PATH)/kernel M=`pwd` modules clean
- rm -rf modules.order *.o *.ko *.mod.* Module.*
- obj-m += at24cxx.o
测试程序如下
- #include
- #include
- #include
- #include
- #include
- #include
- /* i2c_test r addr
- * i2c_test w addr val
- void print_usage(char *file)
- printf("%s r addrn", file);
- printf("%s w addr valn", file);
- int main(int argc, char **argv)
- int fd;
- unsigned char buf[2];
- if ((argc != 3) && (argc != 4))
- print_usage(argv[0]);
- return -1;
- fd = open("/dev/at24cxx0", O_RDWR);
- if (fd < 0)
- printf("can't open /dev/at24cxxn");
- return -1;
- if (strcmp(argv[1], "r") == 0)
- buf[0] = strtoul(argv[2], NULL, 0);
- read(fd, buf, 1);
- printf("data: %c, %d, 0x%2xn", buf[0], buf[0], buf[0]);
- else if (strcmp(argv[1], "w") == 0)
- buf[1] = strtoul(argv[3], NULL, 0);
- write(fd, buf, 2);
- else
- return -1;
- return 0;
连续发了好几篇驱动程序,还有大概俩个实验,就准备发项目的了,由于我也是初学者,程序中难免有错误和bug,还请各位i大神多多包涵。
