Linuxwilliam hill官网
ty_shi
12年用户 50经验值
擅长:控制/MCU
[资料]
ubuntu下使用motion视频传输
Motion是一个开源的移动图像监控的程序
下载地址:
root@ubuntu:~# apt-get install motion
输出如下
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following extra packages will beinstalled:
libjpeg62 libpq5
Suggested packages:
mysql-client postgresql-client
Recommended packages:
ffmpeg
The following NEW packages will beinstalled:
libjpeg62 libpq5 motion
0 upgraded, 3 newly installed, 0 to removeand 26 not upgraded.
Need to get 360 kB of archives.
After this operation, 1067 kB of additionaldisk space will be used.
Do you want to continue [Y/n]? y
Get:1 http://ports.ubuntu.com/ubuntu-ports/precise-security/main libjpeg62 ARMh        f 6b1-2ubuntu1.1 [72.6 kB]
Get:2 http://ports.ubuntu.com/ubuntu-ports/precise-updates/main libpq5 armhf 9.        1.18-0ubuntu0.12.04 [73.3 kB]
Get:3 http://ports.ubuntu.com/ubuntu-ports/precise/universe motion armhf 3.2.12        -3.1 [214 kB]
Fetched 360 kB in 3s (106 kB/s)
Preconfiguring packages ...
Selecting previously unselected packagelibjpeg62.
(Reading database ... 68981 files anddirectories currently installed.)
Unpacking libjpeg62 (from.../libjpeg62_6b1-2ubuntu1.1_armhf.deb) ...
Selecting previously unselected packagelibpq5.
Unpacking libpq5 (from .../libpq5_9.1.18-0ubuntu0.12.04_armhf.deb)...
Selecting previously unselected packagemotion.
Unpacking motion (from.../motion_3.2.12-3.1_armhf.deb) ...
Processing triggers for ureadahead ...
Setting up libjpeg62 (6b1-2ubuntu1.1) ...
Setting up libpq5 (9.1.18-0ubuntu0.12.04)...
Setting up motion (3.2.12-3.1) ...
Adding group `motion' (GID 115) ...
Done.
Adding system user `motion' (UID 109) ...
Adding new user `motion' (UID 109) withgroup `motion' ...
Not creating home directory `/home/motion'.
Adding user `motion' to group `video' ...
Adding user motion to group video
Done.
*Not starting motion daemon, disabled via /etc/default/motion
Processing triggers for libc-bin ...
ldconfig deferred processing now takingplace
完成后开启
root@ubuntu:~# motion -c motion-dist.conf
输出信息如下
[0] Configfile motion-dist.conf not found -trying defaults.: No such file or directory
[0] Processing thread 0 - config file/etc/motion/motion.conf
[0] Motion 3.2.12 Started
[0] ffmpeg LIBAVCODEC_BUILD 3482112LIBAVFORMAT_BUILD 3478528
[0] Thread 1 is from/etc/motion/motion.conf
[1] Thread 1 started
[1] cap.driver: "uvcvideo"
[1] cap.card: "PC Camera"
[1] cap.bus_info: "u***-sw-ehci-1"
[1] cap.capabilities=0x04000001
[1] - VIDEO_CAPTURE
[1] - STREAMING
[1] Config palette index 8 (YU12) doesn'twork.
[1] Supported palettes:
[1] 0: MJPG (MJPEG)
[1] 1: YUYV (YUV 4:2:2 (YUYV))
[1] Selected palette YUYV
[0] motion-httpd/3.2.12 running, acceptingconnections
[0] motion-httpd: waiting for data on portTCP 8080
[1] Test palette YUYV (320x240)
[1] Using palette YUYV (320x240)bytesperlines 640 sizeimage 153600 colorspace 00000008
[1] found control 0x00980900,"Brightness", range -255,255
[1]    "Brightness", default 0, current 0
[1] found control 0x00980901,"Contrast", range 0,30
[1]    "Contrast", default 15, current 15
[1] found control 0x00980902,"Saturation", range 0,127
[1]    "Saturation", default 32, current 32
[1] found control 0x00980903,"Hue", range -16000,16000
[1]    "Hue", default 0, current 0
[1] found control 0x00980910,"Gamma", range 20,250
[1]    "Gamma", default 100, current 100
[1] mmap information:
[1] frames=4
[1] 0 length=153600
[1] 1 length=153600
[1] 2 length=153600
[1] 3 length=153600
[1] Using V4L2
[1] Resizing pre_capture buffer to 1 items
[1] Started stream webcam server in port8081
在浏览器中输入192.168.1.122:8081
没有看到视频信息
手动安装ffmpeg
sudo apt-get install ffmpeg
再次运行还是不行
需要修改motion.conf文件
该文件在/etc/motion/motion.conf
vim /etc/motion/motion.conf
修改# Restrict webcam connections to localhost only (default: on)
webcam_localhost off
限制仅本地通过网页访问视频
再次运行:
root@ubuntu:/etc/motion# motion -cmotion.conf
在浏览器中输入192.168.1.1228081
成功看到视频
已退回1积分
