在文档里面,写着这样的一段
The I2C bus uses two wires to transfer informa
tion between devices connected
to the bus: “SCL” (serial clock line) and “SDA” (serial data line). The I2C
component requires the use of external open-drain buffers since it has only
unidirectional ports. The “SDA” and “SCL” lines referred further are the actual
I2C bus signals, while the I2C component is connected to them with the use of
open-drains (“SDAO” as output and “SDAI” as input, “SCLO” as output and
“SCLI” as input). Each device connected to the bus is software addressable by a
unique address. The I2C is a true multi-master bus including collision detection
and arbitration to prevent data corruption if two or more masters simultaneously
initiate data transfer. The filtering logic rejects spikes on the bus data line to
preserve data integrity.
请问各位,这两个IO是不是还要接什么东西么?我现在直接使用芯片的IO,操作没有I2C的信号出来。
