EasyEDA-中国人自已的EDA工具
GerryChen
8年用户 188经验值
擅长:电源/新能源 MEMS/传感技术 处理器/DSP
EasyEDA硬件开源项目——LilyPad开发板
Description: The ProtoSnap series is a new way to prototype your project without a breadboard. Everything is wired together on a single board, which makes it easy to explore the possibilities of the components before snapping them apart and building them into your project.
The ProtoSnap LilyPad Simple Development board is a great way to get started in programmable e-textiles. By combining a LilyPad Simple board with 4 LED boards and a buzzer, the ProtoSnap LilyPad Simple Development board gives you everything you need to learn the basics. The kit also includes our LilyPad FTDI basic for programming the Simple board, conductive thread and needles and a Li-Po battery pack to power everything. The LiPo battery is rechargeable through the board; no more special external LiPo chargers required! The board also includes two pads to connect sensors using alligator clips (or use as a nifty touch-sensor).
LilyPad-Dev-Simple-v12 SCH
LilyPad-Dev-Simple-v12 PCB
EasyEDA项目链接 :https://easyeda.com/oshw/LilyPad_Development_Simple_Open_hardware-1hiki2Mwq
EasyEDA链接           https://easyeda.com
