EasyEDA-中国人自已的EDA工具
GerryChen
8年用户 188经验值
擅长:电源/新能源 MEMS/传感技术 处理器/DSP
EasyEDA开源硬件——英特尔®爱迪生模块9轴自由度
Description: The Intel® Edison is an ultra small computing platform that will change the way you look at embedded electronics. Each Edison is packed with a huge amount of tech goodies into a tiny package while still providing the same robust strength of your go-to single board computer. Powered by the Intel® Atom™ SoC dual-core CPU and including an integrated WiFi, Bluetooth LE, and a 70-pin connector to attach a veritable slew of shield-like “Blocks” which can be stacked on top of each other. It’s no wonder how this little guy is lowering the barrier of entry on the world of electronics!
The 9 Degrees of Freedom Block for the Intel® Edison uses the LSM9DS0 9DOF IMU for full-range motion sensing. This chip combines a 3-axis accelerometer, a 3-axis gyroscope, and a 3-axis magnetometer. By default, the IMU is connected to the Edison through the I2C bus. Each sensor in the LSM9DS0 supports a wide range of, well, ranges: the accelerometer’s scale can be set to ± 2, 4, 6, 8, or 16 g, the gyroscope supports ± 245, 500, and 2000 °/s, and the magnetometer has full-scale ranges of ± 2, 4, 8, or 12 gauss. Additionally, the LSM9DS0 includes an I2C serial bus interface supporting standard and fast mode (100 kHz and 400 kHz) and an SPI serial standard interface.
Note: While there are jumpers for SPI, it is not supported.
9dof_block SCH
9dof_block SCH
9dof_block PCB
EasyEDA项目链接:
https://easyeda.com/oshw/Block_for_Intel_Edison_9_Degrees_of_Freedom_Open_hardware-NBvN5ZhzR
EasyEDA链接 :
