// 功能描述: EN29LV160AB操作
// 硬件连接:
// 维护记录: 2016.3.9
// 实验结果: 没反应,有时等待很长(数十分钟)时间可能显示结果(实验基本失败)
#include "2440addr.h"
#include "def.h"
#include
#include "uart.h"
#include "gpio.h"
#define _ISR_STARTADDRESS 0x33ffff00
#define flash_base 0x00000000
#define CMD_ADDR0 *( (volatile U16 *)((0x555<<1)+flash_base) )
#define CMD_ADDR1 *( (volatile U16 *)((0x2aa<<1)+flash_base) )
#define sector_5_base ( ((0x20000<<1)+flash_base) )
#define sector_5_size 32000
#define sector_33_base ( ((0xf0000<<1)+flash_base) )
#define sector_33_size 32000
U8 en29lv160ab_check_toggle(void);
U8 en29lv160ab_sector_erase(U32 section_addr);
U8 en29lv160ab_chip_erase(void);
U8 en29lv160ab_program(U32 addr,U16 dat);
U16 en29lv160ab_read(U32 addr);
void en29lv160ab_reset(void);
U32 en29lv160ab_id(void);
void delay_ms(int t);
//测试
int Main(void)
//U16 i;
U32 id = 0;
U16 tem = 0;
Uart0_Init(115200);//串口初始化
Gpio_Init();
//读ID号
LED_ON;
id = en29lv160ab_id();
LED_OFF;
en29lv160ab_reset();
delay_ms(500);
Uart0Printf("EN29LV160AB的ID号为:%xrn",id);
//擦除sector
tem = en29lv160ab_sector_erase(sector_5_base);
if(tem == 0)
Uart0Printf("sector_5 擦除失败!rn");
else
Uart0Printf("sector_5 擦除成功!rn");
//写操作
tem = en29lv160ab_program(sector_5_base+(1<<1),0xaa);
if(tem == 0)
Uart0Printf("地址 %x 写失败!rn",sector_5_base+(1<<1));
else
//读
tem = en29lv160ab_read(sector_5_base+(1<<1));
Uart0Printf("%xrn",tem);
while(1) ;
return 0;
//check_toggle
volatile U16 newtoggle;
volatile U16 oldtoggle;
while(1)
newtoggle = *( (volatile U16 *)0x0 );
if( (oldtoggle&0x40) == (newtoggle&0x40) ) //DQ6
break;
if(newtoggle & 0x20)//DQ5
oldtoggle = *((volatile U16 *)0x0);
newtoggle = *((volatile U16 *)0x0);
if( (oldtoggle & 0x40) == (newtoggle & 0x40) )
break;
else
return 0;//错误
oldtoggle = newtoggle;
return 1;//正确
//sector擦除
CMD_ADDR0 = 0xaa;
CMD_ADDR1 = 0x55;
CMD_ADDR0 = 0x80;
CMD_ADDR0 = 0xaa;
CMD_ADDR1 = 0x55;
*( (volatile U16 *)(section_addr) ) = 0x30;
return en29lv160ab_check_toggle();
//chip擦除
CMD_ADDR0 = 0xaa;
CMD_ADDR1 = 0x55;
CMD_ADDR0 = 0x80;
CMD_ADDR0 = 0xaa;
CMD_ADDR1 = 0x55;
CMD_ADDR0 = 0x10;
//写操作
CMD_ADDR0 = 0xaa;
CMD_ADDR1 = 0x55;
CMD_ADDR0 = 0xa0;
*( (volatile U16 *)(addr) ) = dat;
//读操作
return *( (volatile U16 *)(addr) );
//软件复位
*( (volatile U16 *)0x0 ) = 0xf0;
//读取ID,高2个字节为设备ID,低两个字节为芯片ID
U32 temp = 0;
CMD_ADDR0 = 0xaa;
CMD_ADDR1 = 0x55;
CMD_ADDR0 = 0x90;
temp = (*( (volatile U16 *)(flash_base+(0x100<<1)) ))<<16;
CMD_ADDR0 = 0xaa;
CMD_ADDR1 = 0x55;
CMD_ADDR0 = 0x90;
temp |= (*(volatile U16 *)(flash_base+(0x1<<1)));
return temp;
//延时
int i,j;
for(i=0;i
for(j=0;j<1000;j++)
// 硬件连接:
// 维护记录: 2016.3.9
#include "def.h"
#include
#include "uart.h"
#include "gpio.h"
//测试
int Main(void)
//U16 i;
U32 id = 0;
U16 tem = 0;
Gpio_Init();
//读ID号
LED_ON;
LED_OFF;
delay_ms(500);
//擦除sector
if(tem == 0)
else
//写操作
if(tem == 0)
else
//读
while(1) ;
return 0;
//check_toggle
while(1)
break;
break;
else
return 0;//错误
return 1;//正确
//sector擦除
CMD_ADDR0 = 0xaa;
CMD_ADDR1 = 0x55;
CMD_ADDR0 = 0x80;
CMD_ADDR0 = 0xaa;
CMD_ADDR1 = 0x55;
//chip擦除
CMD_ADDR0 = 0xaa;
CMD_ADDR1 = 0x55;
CMD_ADDR0 = 0x80;
CMD_ADDR0 = 0xaa;
CMD_ADDR1 = 0x55;
CMD_ADDR0 = 0x10;
//写操作
CMD_ADDR0 = 0xaa;
CMD_ADDR1 = 0x55;
CMD_ADDR0 = 0xa0;
//读操作
//软件复位
U32 temp = 0;
CMD_ADDR0 = 0xaa;
CMD_ADDR1 = 0x55;
CMD_ADDR0 = 0x90;
CMD_ADDR0 = 0xaa;
CMD_ADDR1 = 0x55;
CMD_ADDR0 = 0x90;
return temp;
//延时
int i,j;
for(i=0;i
for(j=0;j<1000;j++)
