我做的项目是用激振锤锤击悬臂梁,DSP采集激振锤返回的
力信号的电压值和安装在悬臂梁上的加速度传感器返回的
加速度信号的电压值,将这两路信号做频响函数,但不知道这个程序能不能应用,各位大神有空的帮忙看看哈,万分感谢。我采样频率设置的是6K,采样点数是512个点。
程序如下:
#include
#include
#include
#include "msp.h"
void miirres(float a[],float b[],int lb,int la,complex h[],int n)
Routinue miirres:to obtain the frequence responce (Amplitude and phase)
H(exp(jw)) of system function H(z)=B(z)/A(z);
b(0)+b(1)z^(-1)+ ... + b(lb)z^(-lb)
H(z)=------------------------------------
1.0 +a(1)z^(-1)+ ... + a(la)z^(-la)
input parameters:
a :la+1 dimensioned real array. a(0)=1.0,
a(n) (n=1 to la) is the coef. of z^(-n).
b :lb+1 dimensioned real array. b(n) (n=0 to la) is the coef. of z^(-n).
n :data point number of frequency response from 0.0 to pi.the frequency
resolution is pi/n.
output parameters:
H :n dimensioned complex array. frequency response is stored in
H(0) to H(n-1), which is normalized from 0.0 to pi.
Note: If H(k)=0/0,then let H(K)=H(k+1) (This is for the case of that
H(exp(jw)) is a sinc function)
: If la=0: for FIR system.
in Chapter 2
complex z,bsum,asum;
int k,i;
int isign;
float pole,peak,pi,s,sf,sa,***,temp;
pole=1.e-10;
peak=1.e+10;
pi=4.*atan(1.);
s=pi/(float)(n);
isign=0;
for(k=0;k
sf=s*k;
bsum.real=b[0];bsum.imag=0.0;
if(lb>0)
for(i=1;i<=lb;i++)
***=sf*i;
z.real=cos(***);z.imag=-sin(***);
bsum.real+=b*z.real;
bsum.imag+=b*z.imag;
asum.real=1.;
asum.imag=0.0;
if(la!=0)
for(i=1;i<=la;i++)
sa=sf*i;
z.real=cos(sa);z.imag=-sin(sa);
asum.real+=a*z.real;
asum.imag+=a*z.imag;
if(mabs(asum)
if(mabs(bsum)
isign=1;
else
h[k].real=peak;
h[k].imag=0.0;
else
temp=pow(mabs(asum),2.0);
h[k].real=(bsum.real*asum.real+bsum.imag*asum.imag)/temp;
h[k].imag=(bsum.imag*asum.real-bsum.real*asum.imag)/temp;
if(isign==1)
h[k-1]=h[k];
isign=0;
return;
