STM32F4Discovery开发帮使用的STM32F407VGT6芯片,内部FLASH有1M之多。平时写的代码,烧写完之后还有大量的剩余。有效利用这剩余的FLASH能存储不少数据。因此研究了一下STM32F4读写内部FLASH的一些操作。
【STM32F4 内部Flash的一些信息】
STM32F407VG的内部FLASH的地址是:0x08000000,大小是0x00100000。
写FLASH的时候,如果发现写入地址的FLASH没有被擦出,数据将不会写入。FLASH的擦除操作,只能按Sector进行。不能单独擦除一个地址上的数据。因此在写数据之前需要将地址所在Sector的所有数据擦除。
在STM32F4的编程手册上可找到FLASH的Sector划分,我们现在只操作Main memory:
参考Demo中的例子,将FLASH的页的其实地址(基地址)可定义如下:
// void OwnFlashErasure()
void OwnFlashReady(uint32_t read_addr,uint8_t * read_buf,uint16_t read_number)
uint32_t Address_ready;
Address_ready = read_addr;
while (Address_ready < read_addr+read_number)
*read_buf++ = (*(__IO uint8_t*)Address_ready);
Address_ready = Address_ready + 1;
uint32_t GetSector(uint32_t Address)
uint32_t sector = 0;
if((Address < ADDR_FLASH_SECTOR_1) && (Address >= ADDR_FLASH_SECTOR_0))
sector = FLASH_Sector_0;
else if((Address < ADDR_FLASH_SECTOR_2) && (Address >= ADDR_FLASH_SECTOR_1))
sector = FLASH_Sector_1;
else if((Address < ADDR_FLASH_SECTOR_3) && (Address >= ADDR_FLASH_SECTOR_2))
sector = FLASH_Sector_2;
else if((Address < ADDR_FLASH_SECTOR_4) && (Address >= ADDR_FLASH_SECTOR_3))
sector = FLASH_Sector_3;
else if((Address < ADDR_FLASH_SECTOR_5) && (Address >= ADDR_FLASH_SECTOR_4))
sector = FLASH_Sector_4;
else if((Address < ADDR_FLASH_SECTOR_6) && (Address >= ADDR_FLASH_SECTOR_5))
sector = FLASH_Sector_5;
else if((Address < ADDR_FLASH_SECTOR_7) && (Address >= ADDR_FLASH_SECTOR_6))
sector = FLASH_Sector_6;
else if((Address < ADDR_FLASH_SECTOR_8) && (Address >= ADDR_FLASH_SECTOR_7))
sector = FLASH_Sector_7;
else if((Address < ADDR_FLASH_SECTOR_9) && (Address >= ADDR_FLASH_SECTOR_8))
sector = FLASH_Sector_8;
else if((Address < ADDR_FLASH_SECTOR_10) && (Address >= ADDR_FLASH_SECTOR_9))
sector = FLASH_Sector_9;
else if((Address < ADDR_FLASH_SECTOR_11) && (Address >= ADDR_FLASH_SECTOR_10))
sector = FLASH_Sector_10;
else
sector = FLASH_Sector_11;
return sector;
